查看: 1120|回复: 4
[提问] 指北针 的N 改为上边
发表于 2024-11-3 10:11:19 | 显示全部楼层 |阅读模式
这个指北针  N在下边,看这太别扭了,大哥们谁有空帮我改为上面
发表于 2024-11-3 10:20:50 | 显示全部楼层
指北针 的N 修改为上边
gaolei_gaolei + 1
发表于 2024-11-3 11:42:04 | 显示全部楼层
  1. ;|
  2. 命令:zbz
  3. 功能:自定义指北针大小及方向
  4. |;
  5. (defun c:zbz ( / &ang1 &ang2 &dis1 &ent1 &kw1 &p1 &p2 &p3 &p4 &p5 &pt1 &pt2 &r1 &r2 x)
  6. (setvar "cmdecho" 0)
  7. (setvar "blipmode" 0)
  8. (if (and (setq &p1 (getpoint "\n请指定圆心"))
  9.           (setq &r1 (getdist &p1 "\n请输入圆半径"))
  10.       )
  11.      (progn
  12.        (setq &r2 (* &r1 2))
  13.        (entmake (list '(0 . "CIRCLE")
  14.                        (cons 10 &p1)
  15.                        (cons 40 &r1)
  16.                  )
  17.         )
  18.     (setq &ent1 (entlast) &kw1 (ssadd) &kw1 (ssadd &ent1 &kw1))
  19.     (setq &p5 (cadr (grread t)))
  20.     (if (= (distance &p1 &p5) 0)
  21.            (setq &ang1 0)
  22.            (setq &ang1 (angle &p1 &p5))
  23.          )
  24.         (setq &p2 (polar &p1 &ang1 &r2)
  25.               &p3 (polar &p1 (+ &ang1 (* pi 0.8)) &r2)
  26.               &p4 (polar &p1 (- &ang1 (* pi 0.8)) &r2)
  27.          )
  28.         (entmake (list '(0 . "LWPOLYLINE")
  29.                        '(100 . "AcDbEntity")
  30.                        '(100 . "AcDbPolyline") (cons 90 3)
  31.                        '(70 . 1) (cons 10 &p1) (cons 10 &p2) (cons 10 &p3)
  32.                   )
  33.          )
  34.         (setq &ang2 (angle &p2 &p4)
  35.               &pt1 (polar &p2 &ang2 &r2)
  36.               &dis1 (distance &p1 &pt1)
  37.               &pt1 (mapcar '(lambda (x)(* x 0.5))(mapcar '+ &p1 &pt1))
  38.          )
  39.         (setq &pt2 (polar &p4 &ang2 (* &r2 -1))
  40.               &pt2 (mapcar '(lambda (x) (* x 0.5)) (mapcar '+ &p1 &pt2))
  41.          )
  42.         (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity")
  43.                        '(100 . "AcDbPolyline") (cons 90 4) (cons 10 &p2)
  44.                        '(40 . 0.0) (cons 41 &dis1) (cons 10 &pt1)(cons 10 &pt2) (cons 40 &dis1)
  45.                        '(41 . 0.0) (cons 10 &p4)
  46.                   )
  47.          )
  48.         (setq &p4 (polar &p1 &ang1 (+ &r2 &r1)) &ang2 (+ &ang1 (* pi 0.5))
  49.              )
  50.         (entmake (list '(0 . "TEXT") (cons 1 "N") (cons 10 &p4) (cons 40 (* &r1 0.8))
  51.                       '(41 . 0.6) (cons 50 &ang2)
  52.                       '(72 . 4) (cons 11 &p4)
  53.                    )
  54.          )
  55.         (while (setq &ent1 (entnext &ent1))
  56.                (setq &kw1 (ssadd &ent1 &kw1))
  57.          )
  58.         (command "ROTATE" &kw1 "" &p1 "R" &p1 &p2)
  59.     )
  60. )
  61. (princ)
  62. )
gaolei_gaolei + 1
发表于 2024-11-4 09:56:18 | 显示全部楼层
tooltip,指定基点粘贴!
sleep, 500
tooltip,
send,^+v
return
gaolei_gaolei + 1 很给力!
 楼主| 发表于 2024-11-4 10:00:29 | 显示全部楼层
感谢大哥,学习了
GMT+8, 2025-10-16 06:21 , Processed in 0.158691 second(s), 26 queries , Gzip On.
