查看: 1151|回复: 3
[提问] 关于命令提示显示乱码的问题(已经解决)
发表于 2024-11-5 19:31:31 | 显示全部楼层 |阅读模式
为什么运行程序后 指定插入点 命令提示栏显示乱码(鎸囧畾鎻掑叆鐐?)
代码如下:
  1. (defun c:tt (/ ss pt doc bn blks i obj lst);;;快速做块
  2.   (if (and (setq ss (ssget))
  3.            (setq pt (getpoint "\n指定插入点: "))
  4.       )
  5.     (progn
  6.       (setq doc         (vla-get-activedocument (vlax-get-acad-object))
  7.             blks (vla-get-blocks doc)
  8.             pt         (vlax-3d-point (trans pt 1 0))
  9.             bn         (strcat "LZ_" (rtos (* (getvar 'cdate) 1e6) 2 0))
  10.             mps         (if (= (getvar 'cvport) 1)
  11.                    (vla-get-paperspace doc)
  12.                    (vla-get-modelspace doc)
  13.                  )
  14.             blk         (vla-add blks pt bn)
  15.             i         (sslength ss)
  16.       )
  17.       (repeat i
  18.         (setq i          (1- i)
  19.               obj (vlax-ename->vla-object (ssname ss i))
  20.               lst (cons obj lst)
  21.         )
  22.         (vla-put-Lineweight obj acLnWtByBlock);;;;;;;;;;;线宽设为随块
  23.       )
  24.       (vlax-invoke doc 'copyobjects lst blk)
  25.       (vla-insertblock mps pt bn 1 1 1 0)
  26.       (mapcar 'vla-delete lst)
  27.     )
  28.   )
  29.   (princ)
  30. )
好奇怪截图怎么不显示  发表于 2024-11-5 19:32
发表于 2024-11-5 20:25:15 | 显示全部楼层
保存的时候选择gbk编码试试
GMT+8, 2025-10-16 06:21 , Processed in 0.155030 second(s), 26 queries , Gzip On.
