- 积分
- 66346
- 明经币
- 个
- 注册时间
- 2010-5-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2024-11-18 07:29:10
显示全部楼层
查宝典,上面是这么说的
Distance : Double; input-only
The distance to offset the object. The offset can be a positive or negative number, but it cannot equal zero. If the offset is negative, this is interpreted as being an offset to make a "smaller" curve (that is, for an arc it would offset to a radius that is "Distance less" than the starting curve's radius). If "smaller" has no meaning, then it would offset in the direction of smaller X, Y, and Z WCS coordinates.
