查看: 2108|回复: 10
[源码] 优化穿线孔到孔边的距离,节省线割路径
发表于 2024-11-19 13:39:53 | 显示全部楼层 |阅读模式
居然能用 distance 作变量  发表于 2024-11-27 09:42
发表于 2024-11-19 17:02:41 | 显示全部楼层
(defun c:qqq (/ ss n me en pt k)
  (setq ss (ssget '((0 . "CIRCLE"))))
  (repeat (setq n (sslength ss))
    (setq me (ssname ss (setq n (1- n))))
    (setq en (entget me))
    (setq pt (cdr (assoc 10 en)))
    (setq k (cdr (assoc 40 en)))
    (command "_CIRCLE" "none" (polar pt (* pi 0.25) (- k 3)) 1)
(defun c:qq (/ s1 s2 en1 en2 p1 p2 ang k)
  (while (and (setq s1 (entsel "\n选择第一个圆: "))
              (setq s2 (entsel "\n选择第二个圆: ")))
    (setq en1 (entget (car s1)))
    (setq en2 (entget (car s2)))
    (setq p1 (cdr (assoc 10 en1)))
    (setq p2 (cdr (assoc 10 en2)))
    (setq ang (angle p2 p1))
    (setq k (- (cdr (assoc 40 en2)) (cdr (assoc 40 en1)) 1))
    (setq en1 (subst (cons 10 (polar p2 ang k)) (cons 10 p1) en1))
    (entmod en1)
发表于 2024-11-19 14:04:02 | 显示全部楼层
直接出个画穿丝孔的不省事,这种圆的还是比较简单
 楼主| 发表于 2024-11-19 14:06:39 | 显示全部楼层
整套模具图纸3D转出来的穿线孔位置比较乱,分使用环境吧
发表于 2024-11-19 15:51:45 | 显示全部楼层
异型孔呢
发表于 2024-11-19 16:04:41 | 显示全部楼层
建议可以优化成框选模式,两个圆大小不一样,程序内部直接分析,谁是大圆谁是小圆,效率又提高了
发表于 2024-11-26 23:29:55 | 显示全部楼层
楼主 可以分享一下这个录屏GIF工具吗?
发表于 2024-11-27 10:02:37 | 显示全部楼层
  1. (defun c:tt ()
  2.   (defun dxf (code e) (cdr (assoc code (entget e))))
  3.   (defun subupd (e c v)
  4.     (entmod (subst (cons c v) (assoc c (entget e)) (entget e)))
  5.     (entupd e)
  6.   )
  7.   (while (and (setq ss (ssget '((0 . "circle"))))
  8.               (= (sslength ss) 2)
  9.          )
  10.     (setq s1 (ssname ss 0)
  11.           s2 (ssname ss 1)
  12.           p1 (dxf 10 s1)
  13.           r1 (dxf 40 s1)
  14.           p2 (dxf 10 s2)
  15.           r2 (dxf 40 s2)
  16.     )
  17.     (if (> r2 r1)
  18.       (setq pt (polar p2 (angle p2 p1) r2)
  19.             p1 (polar pt (angle p1 p2) (+ r1 2))
  20.             s1 (subupd s1 10 p1)
  21.       )
  22.       (setq pt (polar p1 (angle p1 p2) r1)
  23.             p2 (polar pt (angle p2 p1) (+ r2 2))
  24.             s2 (subupd s2 10 p2)
  25.       )
  26.     )
  27.   )
  28.   (princ)
  29. )
发表于 2025-3-4 05:01:54 | 显示全部楼层
谢谢大师分享
发表于 2025-3-8 11:09:11 | 显示全部楼层
感谢分享,学习学习用法
GMT+8, 2026-1-8 04:51 , Processed in 0.159833 second(s), 27 queries , Gzip On.
