查看: 1206|回复: 4
[提问] 定点坐标
发表于 2024-11-21 11:11:26 | 显示全部楼层 |阅读模式
((-180.0 8210.0) (0.0 8210.0) (0.0 8021.0) (-180.0 8021.0))
多段线顶点坐标,怎样把他单独提出来
发表于 2024-11-21 11:24:15 | 显示全部楼层
(MAPCAR 'CDR (VL-REMOVE-IF (FUNCTION(LAMBDA(X)(/=(CAR X) 10))) (ENTGET (CAR(ENTSEL)))))
发表于 2024-11-21 11:54:01 | 显示全部楼层
  1. (defun plxy(e / n pt)
  2.   (repeat(setq n(fix(+(vlax-curve-getendparam e)1.0001)))
  3.     (setq n(1- n)pt(cons(vlax-curve-getpointatparam e n)pt))))
  4. (if(setq e(ssget":E:S"'((0 . "lwpolyline"))))
  5.   (plxy(ssname e 0)))
发表于 2024-11-21 12:20:24 | 显示全部楼层
(plxy (S:tovla (car(entsel))))
发表于 2024-11-21 12:26:52 | 显示全部楼层
acet-geom-pline-point-list
acet-geom-object-point-list
acet-ent-curvepoints
;(acet-ent-curvepoints <ename> <max-error>)
http://www.mjtd.com/thread-183578-1-1.html
GMT+8, 2025-11-10 04:05 , Processed in 0.321638 second(s), 24 queries , Gzip On.
