查看: 971|回复: 1
[提问] 替换字体过滤掉0层或者只替换dim层
发表于 2024-11-21 18:01:02 | 显示全部楼层 |阅读模式
使用这个代码替换字体是连图框内的文字也替换了,打印比较丑,如何改成只替换dim层的或者不替换0层,或者不替换块内文字,
自己用AI生成的总是没反应    请教
(defun c:QQ (/ name D en)
(command "-STYLE" "txt" "txt.shx" "0" "0.8" "0" "N" "N" "N")
(command "-STYLE" "ma2" "ma2.shx" "0" "0.8" "0" "N" "N" "N")
  (while (setq D (tblnext "style" (null D)))
    (setq name (cdr (assoc 2 D)))
    (setq en (tblobjname "style" name))
    (ch_dxf en 3 "txt.shx") ;替换abcd123
    (ch_dxf en 4 "ma2.shx");替换汉字
   (command "REGEN")
  ;(alert "已替换字体")
(defun ch_dxf (en num ch / old new ent)
  (if (setq ent  (entget en)
      new  (cons num ch)
      old  (assoc num ent)
    (entmod (subst new old ent))
    (entmod (reverse (cons new (reverse ent))))
发表于 2024-11-21 20:03:04 | 显示全部楼层
修改style将会忽略layer作用于相应图元。要特定图层上的图元style不一样,需要定义两种style,然后根据图元所在图层设置。
GMT+8, 2025-11-10 04:05 , Processed in 0.127982 second(s), 24 queries , Gzip On.
