查看: 1301|回复: 9
[提问] 请问多个坐标点连线的简化代码如何写?谢谢~
发表于 2024-11-27 11:25:44 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ pt)
  2.     (setq p0 (getpoint "\n插入点: ") )
  3.     (setq p1 (mapcar '+ p0 '(0 10 0) ) )
  4.     (setq p2 (mapcar '+ p0 '(5 20 0) ) )
  5.     (setq p3 (mapcar '+ p0 '(40 40 0) ) )
  6.     (setq p4 (mapcar '+ p0 '(80 80 0) ) )
  7.     (setq p5 (mapcar '+ p0 '(150 90 0) ) )
  8.     (setq p6 (mapcar '+ p0 '(300 120 0) ) )
  9.
  10.   (setq lst (list p1 p2) )
  11.   (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(8 . "0") '(62 . 0) (cons 90 (length lst) ) '(70 . 1) )
  12.              (mapcar '(lambda (pt) (cons 10 pt) ) lst) ) )
  13.
  14.   (setq lst (list p3 p4) )
  15.   (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(8 . "0") '(62 . 0) (cons 90 (length lst) ) '(70 . 1) )
  16.              (mapcar '(lambda (pt) (cons 10 pt) ) lst) ) )
  17.
  18.   (setq lst (list p1 p5) )
  19.   (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(8 . "0") '(62 . 0) (cons 90 (length lst) ) '(70 . 1) )
  20.              (mapcar '(lambda (pt) (cons 10 pt) ) lst) ) )
  21. )
p1~p6为无规律的坐标点,需要两两连线,用以上代码的方式写下来的话会很冗长,求精简的写法,谢谢~
发表于 2024-11-27 16:11:51 | 显示全部楼层
  1. (defun c:tt(/ p0 p1 p2 p3 p4 p5 p6)
  2.   (setq p0(cons 10(getpoint "\n插入点: ")))
  3.   (setq p1(mapcar '+ p0 '(0 0 10 0) )
  4.         p2(mapcar '+ p0 '(0 5 20 0) )
  5.         p3(mapcar '+ p0 '(0 40 40 0) )
  6.         p4(mapcar '+ p0 '(0 80 80 0) )
  7.         p5(mapcar '+ p0 '(0 150 90 0) )
  8.         p6(mapcar '+ p0 '(0 300 120 0) ))
  9.   (vl-every(function(lambda(x)
  10.                       (entmakex(append'((0 . "LWPOLYLINE")(100 . "AcDbEntity")(100 . "AcDbPolyline")(90 . 2)(70 . 0))x))))
  11.            (list(list p1 p2)
  12.                 (list p3 p4)
  13.                 (list p1 p5))
  14.            )
  15.   )
发表于 2024-11-27 11:46:06 | 显示全部楼层
(defun c:tt1 (/ entmake-pl lst p0 p1 p2 p3 p4 p5 p6 pt)
  (defun entmake-pl(lst)
  (setq lst (list (list p1 p2)(list p3 p4)(list p1 p5)) )
(mapcar 'entmake-pl lst )
  (PRINC)
发表于 2024-11-27 11:49:14 | 显示全部楼层
重复的代码可以用自定义函数代替。
 楼主| 发表于 2024-11-27 11:56:30 | 显示全部楼层
wwwswallow 发表于 2024-11-27 11:49
重复的代码可以用自定义函数代替。
是的,就是不知道怎么自定义,因为没有规律,也不能用repeat函数代替~
把求各个点的这个写为函数,参数为 BasePoint, List<Point3d> , 有多少个点没关系,实际上在函数内你可以用 repeat的,最后就是 AppendEntity 到 Database。  发表于 2024-11-27 17:24
 楼主| 发表于 2024-11-27 11:58:34 | 显示全部楼层
谢谢啦~
发表于 2024-11-27 13:11:28 | 显示全部楼层
  1. (defun c:tt ()
  2.   (defun abc (lst c)
  3.     (entmakex (append (list '(0 . "LWPOLYLINE")
  4.                             '(100 . "AcDbEntity")
  5.                             '(100 . "AcDbPolyline")
  6.                             (cons 90 (length lst))
  7.                             (if c '(70 . 1) '(70 . 0))
  8.                       )
  9.                       (mapcar '(lambda (x) (cons 10 x)) lst)
  10.               )
  11.     )
  12.   )
  13.   (setq p0 (getpoint "\n插入点: "))
  14.   (setq p1 (mapcar '+ p0 '(0 10)))
  15.   (setq p2 (mapcar '+ p0 '(5 20)))
  16.   (setq p3 (mapcar '+ p0 '(40 40)))
  17.   (setq p4 (mapcar '+ p0 '(80 80)))
  18.   (setq p5 (mapcar '+ p0 '(150 90)))
  19.   (setq p6 (mapcar '+ p0 '(300 120)))
  20.   (abc (list p1 p2) nil)
  21.   (abc (list p3 p4) nil)
  22.   (abc (list p1 p5) nil)
  23.   (princ)
  24. )
 楼主| 发表于 2024-11-27 14:18:23 | 显示全部楼层
感谢版主指点,又学会了另一个写法~
 楼主| 发表于 2024-11-27 16:17:53 | 显示全部楼层
第二行这个写法给了我新的启发,感谢感谢~
GMT+8, 2025-11-10 04:06 , Processed in 0.148216 second(s), 31 queries , Gzip On.
