查看: 686|回复: 3
[提问] 请大佬帮忙看看
发表于 2024-12-4 11:08:28 | 显示全部楼层 |阅读模式
  1. (defun C:E1E (/ dcl_file tmp-dcl-file-name dcl_id AA AAZ)
  2.   ;; 创建临时DCL文件并写入对话框定义
  3.   (setq dcl_file (open (setq tmp-dcl-file-name (vl-filename-mktemp nil nil ".DCL")) "w"))
  4.   (foreach x
  5.     '(
  6.       "ZW:dialog {"
  7.       "  label = "测试窗体";"
  8.       "  :row {"
  9.       "    :edit_box { key = "AAZ"; height = 1; edit_width = 7; }"
  10.       "  }"
  11.       "  :row {"
  12.       "    :button { label = "测试"; key = "CESHI"; height = 1; }"
  13.       "  }"
  14.       "  ok_cancel;"
  15.       "}"
  16.     )
  17.     (write-line x dcl_file)
  18.   )
  19.   (close dcl_file)
  20.   ;; 加载并显示对话框
  21.   (setq dcl_id (load_dialog tmp-dcl-file-name))
  22.   (if (not (new_dialog "ZW" dcl_id))
  23.     (progn
  24.       (unload_dialog dcl_id)
  25.       (exit)
  26.     )
  27.   )
  28.   ;; 编辑框记忆功能
  29.   (if (setq AAZ (vl-bb-ref 'AAZ))
  30.     (set_tile "AAZ" AAZ) ; 对话框二次出现
  31.     (set_tile "AAZ" "1") ; 对话框首次出现
  32.   )
  33.
  34. (action_tile "AAZ"  (vl-prin1-to-string'(
  35.                         (lambda ( / itm )
  36.          (setq AAZ(get_tile "AAZ"))
  37.          (vl-bb-set 'AAZ AAZ);_保存原值
  38.         )
  39.                  )
  40.    )
  41. )
  42.   ;; 设置取消按钮的动作
  43.   (action_tile "cancel" "(done_dialog 0)")
  44.   ;; 设置测试按钮的动作
  45.   (action_tile "CESHI" "(done_dialog 1)")
  46.   ;; 启动对话框
  47.   (setq AA (start_dialog))
  48.   ;; 根据用户选择执行相应操作
  49.   (if (= AA 1)
  50.     (CHZ)
  51.   )
  52.   ;; 卸载对话框
  53.   (unload_dialog dcl_id)
  54.   ;; 清理临时文件
  55.   (vl-file-delete tmp-dcl-file-name)
  56.   (princ)
  57. )
  58. ;; 处理测试按钮点击后的逻辑
  59. (defun CHZ ()
  60.   (setq qws (* 5 (atof(get_tile "AAZ"))))
  61.   ;; 打印信息到命令行
  62.   (princ (strcat "\n数值:" qws " "))
  63.   (princ)
  64. )
  65. ;; 确保在加载时不会自动运行
  66. (princ)
这段代码点击测试按钮后,会提示类型错误,大佬们帮忙看看哪里出错了
发表于 2024-12-4 11:47:13 | 显示全部楼层
这里有问题:
      "ZW:dialog {"
      "  label = \"测试窗体\";"
      "  :row {"
      "    :edit_box { key = \"AAZ\"; height = 1; edit_width = 7; }"
      "  :row {"
      "    :button { label = \"测试\"; key = \"CESHI\"; height = 1; }"
      "  ok_cancel;"
 楼主| 发表于 2024-12-4 12:24:21 | 显示全部楼层
ssyfeng 发表于 2024-12-4 11:47
这里有问题:
原代码是有斜杠的,不知道为什么上传之后就不见斜杠了
发表于 2024-12-4 12:33:39 | 显示全部楼层
手写(vl-filename-mktemp nil nil ".DCL")临时对话框,确实容易出错。所以我发布了由程序读取DCL,这样就不容易出错了。
GMT+8, 2025-5-2 09:36 , Processed in 0.251216 second(s), 25 queries , Gzip On.
