查看: 688|回复: 4
[提问] 把每个矩形离指定点最近的端点与指定点连线
发表于 2024-12-6 14:20:47 | 显示全部楼层 |阅读模式
请教大家 可以帮忙修改这段代码吗
功能:把每个矩形离指定点最近的端点与指定点连线;
发表于 2024-12-6 15:03:19 | 显示全部楼层
  1. (defun c:tt(/ p p0 s e a)
  2.   (vl-load-com)
  3.   (and(setq s(ssget'((0 . "*polyline"))))
  4.       (setq p0(mapcar'+'(0 0)(getpoint"指定点")))
  5.       (while(setq e(ssname s 0))
  6.         (setq a(vlax-curve-getParamAtPoint e(vlax-curve-getclosestpointto e p0))
  7.               p(vlax-curve-getpointatparam e(+(if(>(- a(fix a))0.5)1 0)(fix a))))
  8.         (ssdel e s)
  9.         (entmakex(mapcar'cons'(0 100 100 8 62 90 70 10 10)(list"LWPOLYLINE""AcDbEntity""AcDbPolyline""连线"4 2 0 p p0))))))
带动态效果稍微麻烦些
  1. (defun c:tt(/ p0 s lst pts)
  2.   (vl-load-com)
  4.       (while(setq e(ssname s 0))(ssdel e s)
  5.   (setq lst(cons e lst)))
  6.       (or(while(/=(car(setq p0(grread 5)))3)(redraw)
  7.      (setq p0(List(caadr p0)(cadadr p0))pts nil)
  8.      (vl-some(function(lambda(e / a p)
  9.           (setq a(vlax-curve-getParamAtPoint e(vlax-curve-getclosestpointto e p0))
  10.           p(vlax-curve-getpointatparam e(+(if(equal(fix a)a 0.5)0 1)(fix a)))
  11.           pts(cons(list p p0)pts))
  12.           (grdraw p p0 1)))lst))
  13.    (redraw)
  14.    (vl-every(function(lambda(x)(entmakex(mapcar'cons'(0 100 100 8 62 90 70 10 10)(list"LWPOLYLINE""AcDbEntity""AcDbPolyline""连线" 3 2 0(car x)(cadr x))))))pts))))
 楼主| 发表于 2024-12-6 15:36:39 | 显示全部楼层
这也太棒了,非常感谢!
 楼主| 发表于 2024-12-7 15:21:18 | 显示全部楼层
llsheng_73 发表于 2024-12-6 15:03
带动态效果稍微麻烦些
已经很好了,感谢!
发表于 2024-12-7 15:28:46 | 显示全部楼层
带动态效果稍微麻烦些
利害,学习了。
GMT+8, 2025-4-9 09:52 , Processed in 0.164968 second(s), 27 queries , Gzip On.
