查看: 777|回复: 4
[提问] 帮忙改成记事本直接打开输出
发表于 2024-12-8 17:23:01 | 显示全部楼层 |阅读模式
三维多段线顶点提取,帮忙改成记事本直接打开输出结果
(defun c:3wzb() (vl-load-com) (if (setq ssa (ssget '((0 . "POLYLINE")))) (progn (setq i 0 n (sslength ssa) ptb nil no 0) (repeat n (setq obj (vlax-ename->vla-object (ssname ssa i)) pts (vlax-get-property obj "Coordinates") pts (vlax-safearray->list (vlax-variant-value pts)) i (1+ i) m (/ (length pts) 3) ) (repeat m (setq x (car pts) pts (cdr pts) y (car pts) pts (cdr pts) z (car pts) pts (cdr pts) pt (list x y z) ptb (cons pt ptb) no (1+ no) ) (princ (strcat "\nNo" (itoa no) " x=" (rtos x 2 3) " y=" (rtos y 2 3) " z=" (rtos z 2 3) ) ) ) ) (setq ptb (reverse ptb)) ) ) (princ))
发表于 2024-12-8 17:55:35 | 显示全部楼层
http://bbs.mjtd.com/thread-190406-1-1.html
这里应该就是你想要的。
 楼主| 发表于 2024-12-9 16:34:12 | 显示全部楼层
这个太复杂,有大佬帮忙修改1楼代码吗
发表于 2024-12-11 14:46:55 | 显示全部楼层
  1. (defun c:3wzb()
  2. (vl-load-com)
  3.    (setq filename0 (getfiled "请指定保存位置" "e:\\三维多段线坐标.txt" "txt" 1))
  4.     (setq txtfile (open filename0 "w"))
  5.
  6. (if (setq ssa (ssget '((0 . "POLYLINE"))))
  7. (progn
  8.     (setq i   0
  9.         n   (sslength ssa)
  10.         ptb nil
  11.       no  0
  12.   )
  13.     (repeat n
  14.         (setq obj (vlax-ename->vla-object (ssname ssa i))
  15.               pts (vlax-get-property obj "Coordinates")
  16.             pts (vlax-safearray->list (vlax-variant-value pts))
  17.             i   (1+ i)
  18.             m   (/ (length pts) 3)
  19.       )
  20.       (repeat m
  21.           (setq x (car pts)
  22.               pts (cdr pts)
  23.           y   (car pts)
  24.           pts (cdr pts)
  25.           z   (car pts)
  26.           pts (cdr pts)
  27.           pt  (list x y z)
  28.           ptb (cons pt ptb)
  29.           no  (1+ no)
  30.         )
  31.         (princ (strcat "\n顶点" (itoa no) " x=" (rtos x 2 3) " y=" (rtos y 2 3) " z=" (rtos z 2 3) ) )
  32.       (write-line (strcat "顶点" (itoa no) "," (rtos x 2 3) "," (rtos y 2 3) "," (rtos z 2 3)) txtfile)
  33.       )
  34.   )
  35.     (setq ptb (reverse ptb))
  36.     (close txtfile)
  37.     (startapp "notepad" filename0)
  38. )
  39. )
  40. (princ)
  41. )
 楼主| 发表于 2024-12-11 19:31:08 | 显示全部楼层
很实用,非常感谢
GMT+8, 2025-4-9 09:43 , Processed in 0.157568 second(s), 26 queries , Gzip On.
