查看: 1826|回复: 13
[源码] 选择圆,改成闭合多段线
发表于 2024-12-14 21:41:38 | 显示全部楼层 |阅读模式
3明经币
;选择圆,从左到右从上到下排序编号
(defun c:tt (/ FN FFILE SS I ENTS EN PT EN1 PTS PTLST STRLST)
        (initget 1 "Y N")
        (setq write (getkword "\n 是否加入前缀 (Y)是 (N)否:"))
        (if (wcmatch write "Y")
                (setq str (getstring "\n 请输入前缀"))
        (if (setq ss (ssget (list (cons 0 "CIRCLE"))))
                        (setq i -1 ents nil)
                        (while (setq en (ssname ss (setq i (1+ i))))
                                (setq pt (cdr (assoc 10 (entget en))))
                                (setq en1(list (car pt) (cadr pt) (cadr pt) en))
                                (setq ents (cons en1 ents))
                        (setq ents (mapcar '(lambda (x) (nth 3 x)) (vl-sort (vl-sort ents '(lambda (a b) (< (car a) (car b)))) '(lambda (c d) (> (cadr c) (cadr d))))))
                        (setq i 0)
        (setq pt (cdr (assoc 10 (entget x))))
        (entmakex
        (list '(0 . "text")
        (cons 1 (if (wcmatch write "Y") (strcat str (itoa (setq i (1+ i))))(itoa (setq i (1+ i)))))
        (cons 10 pt)
        (cons 62 3)
        (cons 40 2.5)
        (cons 11 pt)
        (cons 72 1)
        (cons 73 2)
        (setq pts (cons pt pts))
                                ents
这个功能是实现选择圆,从左到右从上到下排序编号,求助帮忙改成选成闭合多段线,从左到右从上到下排序编号。
最佳答案
查看完整内容
感谢大佬指导~
发表于 2024-12-14 21:41:39 | 显示全部楼层
llsheng_73 发表于 2024-12-15 13:00
(setq ss (ssget  '((0 . "LWPOLYLINE") (-4 . ">") (90 . 2)  (70 . 1))))
这样过滤是有问题的:因为2 ...
感谢大佬指导~
发表于 2024-12-15 01:46:19 | 显示全部楼层
  1. ;选择闭合多段线,从左到右从上到下排序编号
  2. (defun c:tt (/ FN FFILE SS I ENTS EN PT EN1 PTS PTLST STRLST)
  3. (VL-LOAD-COM )
  4.         (initget 1 "Y N")
  5.         (setq write (getkword "\n 是否加入前缀 (Y)是 (N)否:"))
  6.         (if (wcmatch write "Y")
  7.                 (setq str (getstring "\n 请输入前缀"))
  8.         )
  9.         (if <span style="background-color: rgb(255, 255, 255);">(setq ss (ssget  '((0 . "LWPOLYLINE") (-4 . "&") (70 . 1))))</span>
  10.                 (progn
  11.                         (setq i -1 ents nil)
  12.                         (while (setq en (ssname ss (setq i (1+ i))))
  13.                                 (setq pt (find-centerpoint en))
  14.                                 (setq en1(list (car pt) (cadr pt) (cadr pt) en))
  15.                                 (setq ents (cons en1 ents))
  16.                         )
  17.                         (setq ents (mapcar '(lambda (x) (nth 3 x)) (vl-sort (vl-sort ents '(lambda (a b) (< (car a) (car b)))) '(lambda (c d) (> (cadr c) (cadr d))))))
  18.                         (setq i 0)
  19.                         (mapcar '(lambda (x)
  20.                         (setq pt (find-centerpoint x))
  21.                         (entmakex
  22.                                 (list '(0 . "text")
  23.                                         (cons 1 (if (wcmatch write "Y") (strcat str (itoa (setq i (1+ i))))(itoa (setq i (1+ i)))))
  24.                                         (cons 10 pt)
  25.                                         (cons 62 3)
  26.                                         (cons 40 200)
  27.                                         (cons 11 pt)
  28.                                         (cons 72 1)
  29.                                         (cons 73 2)
  30.                                 )
  31.                         )
  32.                         (setq pts (cons pt pts))
  33.                                  )
  34.                                 ents
  35.                         )
  36.                                 )
  37.                 )
  38. )
  39. (defun find-centerpoint(en / po-li n y pc)
  40.   (setq entda(entget en)
  41.         ename(cdr(assoc 0 entda)))
  42.   (if(= ename "CIRCLE")
  43.     (setq pc(cdr(assoc 10 entda)))
  44.     (progn
  45.       (setq po-li (vl-remove-if 'not (mapcar '(lambda (x) (if (= (car x) 10) (cdr x))) entda)))
  46.       (setq n(length po-li))
  47.       (setq y(apply 'mapcar (cons '+ po-li)))
  48.       (setq pc(mapcar '/ y (list n n n)))
  49.       );progn
  50.     );end if
  51.   );end defun
 楼主| 发表于 2024-12-15 09:14:16 | 显示全部楼层
测试了一下,编号加不上去啊?
我用的是CAD2008
发表于 2024-12-15 09:23:15 | 显示全部楼层
tangweinbs 发表于 2024-12-15 09:14
测试了一下,编号加不上去啊?
方便图纸文件上传看看不?
你这图片看不到。
 楼主| 发表于 2024-12-15 09:23:40 | 显示全部楼层
测试了一下,编号加不上去啊?
我用的是CAD2008
发表于 2024-12-15 10:09:19 | 显示全部楼层
tangweinbs 发表于 2024-12-15 09:23
测试了一下,编号加不上去啊?
CAD2008可能版本太老了?
我在2014以上测试成功的。
 楼主| 发表于 2024-12-15 10:46:32 | 显示全部楼层
煮茗 发表于 2024-12-15 10:09
CAD2008可能版本太老了?
我在2014以上测试成功的。
我主要是用2004-2008的CAD,功能就是你测试的这个,我装了一个2010 也没成功
发表于 2024-12-15 13:00:58 | 显示全部楼层
这样过滤是有问题的:因为2个点也可以闭合,不过有凸度,闭合也不一定70组等于1,70组是按位编码的,只要含有1就是闭合,具体的数值可能有多种,比如1,129(+ 128 1)都是很常见的,也可能有其它数值
tangweinbs + 1 很给力!
 楼主| 发表于 2024-12-15 15:21:04 | 显示全部楼层
这样过滤是有问题的:因为2 ...
感谢大佬指导
GMT+8, 2025-5-1 03:05 , Processed in 0.190766 second(s), 29 queries , Gzip On.
