查看: 704|回复: 6
[提问] 请教一下组合代码
发表于 2024-12-23 08:57:05 | 显示全部楼层 |阅读模式
(defun c:Pq (/ b count ent ent-data ss)
(setq f1 "0")
  (command "LAYER")
  (command "off")
  (command "*")
  (command "y")
  (command "on")
  (command (EVAL F1))
  (command "")
  (c:HZQ-085)
   (setq user_input "A")
  (defun dcb (L)
    (cond
      ((null L) nil)
      ((atom L)(list L))
      ((atom (car L))(cons (car L) (dcb (cdr L))))
      ((append (dcb (car L))(dcb (cdr L))))
  (setq ss (ssget "X" '((0 . "DIMENSION")))) ; 选择所有标注
  (setq b nil)
  (if ss
      (setq count (sslength ss))
      (repeat count
        (setq ent (ssname ss (setq count (1- count))))
        (setq ent-data (entget ent))
        (setq b (dcb ent-data))
        (foreach str b
          (if
            (or
              (= str "AcDbRadialDimension")
              (= str "AcDbDiametricDimension")
            (entdel ent)
(command "layer")
  (command "on")
  (command "*")
  (command "")
  (command "LAYER")
  (command "THAW")
  (command "*")
  (command "")
  (command "LAYER")
  (command "U")
  (command "*")
  (command "")
  (c:HZQ-085)
   (setq user_input "A") 前面这个命令是第三方插件自带的命令,执行后让用户选着一个对象,然后输入栏提示指定基点或 [A(左下角)/B(左上角)/C(右下角)/(右上角)]如何默认执行A(左下角),我希望默认一个值即可,比如A,不再需要用户手动键入,需要怎么实现,谢谢
发表于 2024-12-23 10:28:30 | 显示全部楼层
想多了属于是
发表于 2024-12-23 10:58:11 | 显示全部楼层
左上、左下、右上、右下。我猜这是图元包围框的4个角点。
 楼主| 发表于 2024-12-23 11:33:18 | 显示全部楼层
好吧 谢谢
发表于 2024-12-23 11:44:14 | 显示全部楼层
要么改这个命令里的代码
  1. (c:HZQ-085)
要么处理变量
  1. (if (or (= user_input "") (null user_input))
  2.                 (setq user_input "A")
  3.         )
发表于 2024-12-23 13:05:14 | 显示全部楼层
把c:HZQ-085升格为命令,然后用vla-sendcommand模拟默认输入A
发表于 2024-12-25 13:39:13 | 显示全部楼层
这种command用法,只有反编译的代码中才会有。
GMT+8, 2025-4-7 05:47 , Processed in 0.180133 second(s), 24 queries , Gzip On.
