帖子
查看: 859|回复: 6
[提问] 怎么将多段线顶点DXF10组成表
发表于 2025-1-4 18:49:26 | 显示全部楼层 |阅读模式
怎么将多段线顶点DXF10组成表, ((10 299.934 -1500.9) (10 303.077 -1500)(10 303.077 -1502.3)  (10 305.177 -1502.3) (10 305.177 -1500.4) (10 308.25 -1500.4))
发表于 2025-1-4 18:52:18 | 显示全部楼层
(setq ptlst (mapcar 'cdr (vl-remove-if (function (lambda (e) (/= 10 (car e)))) (entget ename))))
发表于 2025-1-4 18:53:01 | 显示全部楼层
要的是?
(299.934 -1500.9)
发表于 2025-1-4 20:00:54 | 显示全部楼层
  1. (defun plxyz(e fuz / pt p n);多段线节点三维坐标,连续重合点只取一个,根据fuz阀值过滤接近点
  2.         (or(=(type e)'vla-object)(setq e(vlax-ename->vla-object e)))
  3.         (cond((=(setq n(vlax-get-property e'objectname))"AcDbLine")
  4.               (list(vlax-curve-getstartpoint e)(vlax-curve-getendpoint e)))
  5.              ((WCMATCH n"*Polyline")
  6.               (repeat(setq n(fix(+(vlax-curve-getendparam e)(if(=(vlax-get-property e'Closed):vlax-true)0 1))))
  7.                 (or(equal(setq n(1- n)p(vlax-curve-getpointatparam e n))(car pt)fun)
  8.                    (setq pt(cons p pt))))
  9.               pt)))
USER2128 + 1 很给力!
发表于 2025-1-4 23:15:43 | 显示全部楼层
(mapcar 'cdr lst)
发表于 2025-1-6 08:08:38 | 显示全部楼层
(cons(list         (assoc 10 (member (assoc 10 e) e))))
发表于 2025-1-6 08:12:23 | 显示全部楼层
(((10 -852.253 187.664) (42 . 0.0)) ((10 -544.534 187.664) (42 . -0.414214)) ((10 -524.534 167.664) (42 . 0.0)) ((10 -524.534 35.0234) (42 . -0.414214)) ((10 -544.534 15.0234) (42 . 0.0)) ((10 -852.253 15.0234) (42 . 0.0)))
GMT+8, 2025-4-11 14:44 , Processed in 0.175744 second(s), 25 queries , Gzip On.
