查看: 924|回复: 4
[提问] 找了个修改高程点字高的插件,但是不知道为什么这个点不会跟着一起变化
发表于 2025-1-11 13:03:09 | 显示全部楼层 |阅读模式
求大神改改
发表于 2025-1-11 14:39:23 | 显示全部楼层
  1. (defun c:tt ()
  2.   (or th (setq th 1.5))
  3.   (setq th (Udist 7 "" "字高<输入或鼠标直接量取>" th nil))
  4.   (setq i -1)
  5.   (if (setq ss (ssget '((0 . "INSERT") (8 . "GCD1") (66 . 1))))
  6.     (while (setq s1 (ssname ss (setq i (1+ i))))
  7.       (setq ob (vlax-ename->vla-object s1)
  8.             ob (vlax-variant-value (vla-GetAttributes ob))
  9.             ob (car (vlax-safearray->list ob))
  10.       )
  11.       (vla-put-height ob th)
  12.       (vla-update ob)
  13.     )
  14.   )
  15.   (princ)
  16. )
 楼主| 发表于 2025-1-11 14:52:05 | 显示全部楼层
Udist   这个函数是啥啦,大神
发表于 2025-1-11 15:56:48 | 显示全部楼层
  1. (defun udist (bit kwd msg def bpt / inp)
  2.   "UDIST 距离输入格式化"
  3.   ;; 应用:(setq dd(Udist 7 "" "距离<输入或鼠标直接量取>" dd nil))
  4.   (if def
  5.     (setq msg(strcat"\n"msg"<"(rtos def)">: ")
  6.           bit(* 2(fix(/ bit 2)))
  7.     )
  8.     (setq msg(strcat"\n"msg": "))
  9.   )
  10.   (initget bit kwd)
  11.   (setq inp(if bpt(getdist msg bpt)(getdist msg)))
  12.   (if inp inp def)
  13. )
发表于 2025-1-11 16:45:38 | 显示全部楼层
如果想要点位符号和高程注记同步大小,可以修改块参照的插入比例
GMT+8, 2025-6-30 06:01 , Processed in 0.245758 second(s), 25 queries , Gzip On.
