查看: 829|回复: 7
[提问] 求大神看看,我导出文字及坐标,为什么会有空行
发表于 2025-1-13 00:26:06 | 显示全部楼层 |阅读模式
(defun c:dcwzzb ()
  (setq i 0)
  (princ "\n选择需输出坐标的文字: ")
  (if (and (setq ss (ssget '((0 . "text"))))
                        (setq ff (open (getfiled "文件保存为" "C:/Users/Administrator/Desktop" "dat" 1) "w")) ;保存路径
    (repeat (sslength ss)
      (setq en (entget (ssname ss i))
                                sn (itoa (+ i 1))
                                pt (cdr (assoc 10 en))
                                x  (rtos (cadr pt) 2 4)
                                y  (rtos (car pt) 2 4)
                                z  (cdr (assoc 1 en))
                                i  (1+ i)
      (write-line (strcat sn ",," y "," x "," z) ff);;;sn是序号,不需要的话就删了
发表于 2025-1-13 08:32:13 | 显示全部楼层
文字中有换行符
发表于 2025-1-13 08:53:32 | 显示全部楼层
[i
 楼主| 发表于 2025-1-13 12:11:31 | 显示全部楼层
怎么修改代码能过滤掉文字本身的\n符号
发表于 2025-1-13 13:24:39 | 显示全部楼层
z (vl-string-subst "" "\n" (cdr (assoc 1 en)))
发表于 2025-1-13 13:28:42 | 显示全部楼层
yjpyjp 发表于 2025-1-13 12:11
怎么修改代码能过滤掉文字本身的\n符号
  1. (defun c:tt ()
  2.   (setq i 0)
  3.   (princ "\n选择需输出坐标的文字: ")
  4.   (if (and (setq ss (ssget '((0 . "text"))))
  5.            (setq ff (open (getfiled "文件保存为" "" "dat" 1) "w"))
  6.       )
  7.     (repeat (sslength ss)
  8.       (setq en (entget (ssname ss i))
  9.             sn (itoa (1+ i))
  10.             pt (cdr (assoc 10 en))
  11.             x  (rtos (cadr pt) 2 4)
  12.             y  (rtos (car pt) 2 4)
  13.             z  (cdr (assoc 1 en))
  14.             z (if (setq n(vl-string-search "\n" z))(substr z 1 n)z)
  15.             i  (1+ i)
  16.       )
  17.       (write-line (strcat sn "," y "," x "," z) ff);sn是序号
  18.     )
  19.   )
  20.   (princ)
  21. )
 楼主| 发表于 2025-1-13 13:34:31 | 显示全部楼层
发表于 2025-1-13 20:26:52 | 显示全部楼层
是86.25 后面有一个空格字符造成的,删出即可,不用修改代码。
GMT+8, 2025-5-1 21:18 , Processed in 0.199351 second(s), 26 queries , Gzip On.
