查看: 1326|回复: 5
[函数] 请问关于vla-offset函数的问题,新手求助
发表于 2025-2-19 16:48:25 | 显示全部楼层 |阅读模式
我新手一个,我用vla-offset函数,算是复制了一条直线,
现在需要从pt1到这条offset创建的直线的一个端点连起来,
该如何获取这个端点的参数呢,用(vlax-get osl 'startpoint)提示错误
参数类型错误: VLA-OBJECT (#<VLA-OBJECT IAcadLine 000001d640c92c08>)
感谢感谢!!
(defun c:ostest ()
  (vl-load-com)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq mds (vla-get-modelspace doc))
  (setq pt1 (vlax-3d-point '(0 0 0)))
  (setq pt2 (vlax-3d-point '(10 10 0)))
  (setq l1 (vla-addline mds pt1 pt2))
  (setq osline (vla-offset l1 20))
  (setq osl (vlax-safearray->list (vlax-variant-value osline)))
  ;; 请问如何取这个vla-offset创建的osl或者说osline的端点参数?能实现吗?
发表于 2025-2-19 17:16:06 | 显示全部楼层
  1. (defun c:tt ()
  2.   (vl-load-com)
  3.   (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  4.   (setq mds (vla-get-modelspace doc))
  5.   (setq pt1 (vlax-3d-point '(0 0 0)))
  6.   (setq pt2 (vlax-3d-point '(10 10 0)))
  7.   (setq l1 (vla-addline mds pt1 pt2))
  8.   (vla-offset l1 20)
  9.   (setq s1 (entlast))
  10.   (setq p1 (vlax-curve-getStartPoint s1)
  11.         p2 (vlax-curve-getEndPoint s1)
  12.   )
  13.   (princ)
  14. )
 楼主| 发表于 2025-2-19 17:26:39 | 显示全部楼层
大神大神! 感谢感谢!
实在是太感谢了!
发表于 2025-2-20 08:31:29 | 显示全部楼层
大神大神! 感谢感谢!
实在是太感谢了!
发表于 2025-2-20 08:55:55 | 显示全部楼层
  1. ; ;; 如此也可以
  2. (defun c:ostest ()
  3.   (vl-load-com)
  4.   (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  5.   (setq mds (vla-get-modelspace doc))
  6.   (setq pt1 (vlax-3d-point '(0 0 0)))
  7.   (setq pt2 (vlax-3d-point '(10 10 0)))
  8.   (setq l1 (vla-addline mds pt1 pt2))
  9.   (setq new (car (vlax-invoke l1 "offset" 20)))
  10.   (setq p1 (vlax-get new "StartPoint"))
  11.   (setq p2 (vlax-get new "EndPoint"))
  12.   (princ)
  13. )
 楼主| 发表于 2025-2-20 10:18:18 | 显示全部楼层
感谢感谢!又学了一招!
GMT+8, 2026-1-16 03:18 , Processed in 0.185942 second(s), 24 queries , Gzip On.
