查看: 1887|回复: 10
绘制管道程序。 DS
发表于 2025-2-26 13:55:49 | 显示全部楼层 |阅读模式
  1.   (defun pt ( /  p1 p2)
  2.   (setq oldecho (getvar "cmdecho"))
  3.   (setvar "cmdecho" 0)
  4.   (setq p1 nil
  5.   p2 nil
  6.   )
  7.   (while (or
  8.      (null p1)
  9.      (null p2)
  10.    )
  11.     (if (null p1)
  12.       (progn
  13.   (setq p1 (getpoint (strcat "\n<空格>重新开始OR<Esc>退出OR请点击第一个点:当前管外经:"
  14.            (rtos (* offset_distance 2) 2 2)
  15.          )
  16.      )
  17.   )
  18.   (if (null p1)
  19.     (progn
  20.       (princ "\n您重新输入偏移量。")
  21.       (C:djg)
  22.     )
  23.   )
  24.       )
  25.     )
  26.     (if (null p2)
  27.       (setq p2 (getpoint p1 "\n请点击第二个点:"))
  28.     )
  29.   )
  30.   (line p1 p2)
  31. )
  32. (defun line (p1 p2 / dx dy new_line1 new_line2 new_p1 new_p2 new_p3 new_p4  original_line perp_dx perp_dy  unit_perp_dy xiangliang)
  33.
  34.
  35.   (setq original_line (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))))
  36.   ; 计算直线的方向向量
  37.   (setq dx (- (car p2) (car p1)))
  38.   (setq dy (- (cadr p2) (cadr p1)))
  39.   ; 计算垂直方向向量(通过交换坐标并改变其中一个的符号)
  40.   (setq perp_dx (- dy))
  41.   (setq perp_dy dx)
  42.   ; 计算垂直方向的单位向量
  43.   (setq xiangliang (sqrt (+ (* perp_dx perp_dx) (* perp_dy perp_dy))))
  44.   (setq unit_perp_dx (/ perp_dx xiangliang))
  45.   (setq unit_perp_dy (/ perp_dy xiangliang))
  46.   ; 计算偏移后的端点坐标
  47.   (setq new_p1 (list (+ (car p1) (* offset_distance unit_perp_dx))
  48.                  (+ (cadr p1) (* offset_distance unit_perp_dy))))
  49.   (setq new_p2 (list (+ (car p2) (* offset_distance unit_perp_dx))
  50.                  (+ (cadr p2) (* offset_distance unit_perp_dy))))
  51.   (setq new_line1 (entmakex (list (cons 0 "LINE") (cons 10 new_p1) (cons 11 new_p2))))
  52.   (setq new_p3 (list (- (car p1) (* offset_distance unit_perp_dx))
  53.                  (- (cadr p1) (* offset_distance unit_perp_dy))))
  54.   (setq new_p4 (list (- (car p2) (* offset_distance unit_perp_dx))
  55.                  (- (cadr p2) (* offset_distance unit_perp_dy))))
  56.   (setq new_line2 (entmakex (list (cons 0 "LINE") (cons 10 new_p3) (cons 11 new_p4))))
  57.   ; 删除初始直线
  58.   (command "erase" original_line "")
  59.
  60.   (pt)
  61. )
  62. (defun C:djg( / offset_distance)
  63.
  64.   (setq offset_distance (getreal "\n请输入管外经: "))
  65.   (setq offset_distance (/ offset_distance 2 ))
  66.
  67.   (pt)
  68. )
 楼主| 发表于 2025-2-27 10:17:05 | 显示全部楼层
qwsss31 发表于 2025-2-27 09:37
哈哈,DS写的吧,嘿嘿嘿,还得调汗
,但确实前期自己写的一直没有完善,现在借助DS完善了。发上来借用平台保留一下
发表于 2025-2-26 14:03:14 | 显示全部楼层
感谢大佬分享
 楼主| 发表于 2025-2-26 14:10:46 | 显示全部楼层
闹着玩,程序比较简单,我谈不上大佬,刚学,就是小白一枚。
发表于 2025-2-27 09:37:00 | 显示全部楼层
哈哈,DS写的吧,嘿嘿嘿,还得调汗
发表于 2025-2-27 20:39:53 | 显示全部楼层
用来画双线倒是不错
发表于 2025-6-19 02:04:07 | 显示全部楼层
有木有弯头呢
发表于 2025-6-25 10:27:35 | 显示全部楼层
这个怎么用啊。直接保存lsp吗
 楼主| 发表于 2025-6-26 15:40:57 | 显示全部楼层
yangro 发表于 2025-6-25 10:27
这个怎么用啊。直接保存lsp吗
对的,功能还不完善,你在站里找一下其它的吧
GMT+8, 2025-10-6 03:32 , Processed in 0.162175 second(s), 24 queries , Gzip On.
