查看: 608|回复: 3
[提问] 各位大神帮我看看,吧这个文字提取到图形边上
发表于 2025-3-4 11:04:41 | 显示全部楼层 |阅读模式
各位大神帮我看看,吧这个文字提取到图形边上,属性的这个文字提取到边上,提取出来看下对不对
 楼主| 发表于 2025-3-4 15:16:59 | 显示全部楼层
(defun c:tt (/ a b e h i  p s ss)
    (setq bt
        (lambda (s k /  i ss l)
            (setq l (1+ (strlen k)))
            (while (setq i (vl-string-search k s))
                (setq ss (cons (substr s 1 i) ss))
                (setq s (substr s (+ i l)))
            (reverse (cons s ss))
    (and (setq s (ssget '((0 . "INSERT"))))
        (setq i -1)
        (setq ms (vla-get-ModelSpace (vla-get-ActiveDocument(vlax-get-acad-object))))
        (while (setq e (ssname s (setq i (1+ i))))
            (setq ss (cdr (cadr (cadr (assoc -3 (entget e '("*")))))))
            (setq ss (mapcar '(lambda(x)(apply 'cons (bt x ":")))(cdr (bt ss "|"))))
            (setq ss
                (cdr
                    (assoc (cdr (assoc "WayType" ss))
                        (mapcar 'cons (list "OneWay" "TwoWay")(bt (cdr (assoc "WaySpacte"  ss)) "$"))
            (setq h 300)
            (setq p
                    (vla-GetBoundingBox (vlax-ename->vla-object e) 'a 'b)
                    (setq a (vlax-safearray->list a)
                        b (vlax-safearray->list b)
                        p (vlax-3D-point (mapcar '+ (list (car a)(cadr b)(caddr a)) (list 0 h 0)))
            (vla-put-Layer (vla-AddText ms ss p h) "KZ")
)波总的代码
写得太复杂了  发表于 2025-3-10 22:58
发表于 2025-3-10 22:57:16 | 显示全部楼层
;; 非源码
GMT+8, 2025-5-1 04:22 , Processed in 0.174542 second(s), 27 queries , Gzip On.
