查看: 1149|回复: 3
发一个添加标注前缀φ的程序,之前社区有一些不太适合自己用。
发表于 2025-3-7 13:25:37 | 显示全部楼层 |阅读模式
  • 情况1:标注已含%%C前缀情况(跳过操作)
  • 情况2:标注文字被用户修改过(非测量值)添加φ
  • 情况3:标注为原始测量值(未被修改)添加φ
    1. (defun c:tt (/ ss i ent obj currText)
    2.   (vl-load-com)
    3.   (setq ss (ssget '((0 . "DIMENSION")))) ; 选择所有标注对象
    4.   (if ss
    5.     (progn
    6.       (vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
    7.       (setq i 0)
    8.       (repeat (sslength ss)
    9.         (setq ent (ssname ss i))
    10.         (setq obj (vlax-ename->vla-object ent))
    11.         (setq currText (vla-get-TextOverride obj))
    12.         (cond
    13.           ;; 情况1:标注已含%%C前缀(跳过操作)
    14.           ((wcmatch currText "%%C*")
    15.             nil ; 不执行任何操作
    16.           )
    17.           ;; 情况2:标注文字被用户修改过(非测量值)
    18.           ((/= currText "")
    19.             (vla-put-TextOverride obj (strcat "%%C" currText))
    20.           )
    21.           ;; 情况3:标注为原始测量值(未被修改)
    22.           (t
    23.             (vla-put-TextOverride obj "%%C<>")
    24.           )
    25.         )
    26.         (setq i (1+ i))
    27.       )
    28.       (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) ; 结束撤销标记
    29.       (princ (strcat "\n已处理 " (itoa i) " 个标注。"))
    30.     )
    31.     (princ "\n未选中任何标注。")
    32.   )
    33.   (princ)
    34. )
发表于 2025-3-7 13:44:30 | 显示全部楼层
好几年前,我也写过,也分享下
  1. ;;说明:标注批量添加直径符号
  2. (defun C:DDAD(/ dxfstr edata ent i n obj ss)
  3.   (vl-load-com)
  4.   (command "UNDO" "be")
  5.   (if (setq ss (ssget '((0 . "DIMENSION"))))
  6.     (progn
  7.       (setq n -1 i 0)
  8.       (while (setq ent (ssname ss (setq n (1+ n))))
  9.         (setq obj (vlax-ename->vla-object ent) edata (entget ent) dxfstr (assoc 1 edata))
  10.         (if (not (or (vl-string-search "%%C" (strcase (cdr dxfstr))) (and (equal (vl-string-trim "(< >)" (cdr dxfstr)) "") (equal (strcase (vl-string-trim " " (vla-get-TextPrefix obj))) "%%C"))))
  11.           (progn
  12.             ;;(vla-put-TextPrefix obj "%%C")
  13.             (entmod (subst (cons 1 (strcat "%%c" (if (= "" (cdr dxfstr)) "<>" (cdr dxfstr)))) dxfstr edata))
  14.             (setq i (1+ i))
  15.           )
  16.         )
  17.       )
  18.       (princ (strcat "\n选择了" (itoa (sslength ss)) "个图元;处理了" (itoa i) "个图元!" ))
  19.     )
  20.   )
  21.   (command "UNDO" "e")
  22.   (prin1)
  23. )
  24. ;;说明:标注批量删除直径符号
  25. (defun C:DDCD(/ dxfstr edata ent i idx n obj ss)
  26.   (vl-load-com)
  27.   (command "UNDO" "be")
  28.   (if (setq ss (ssget '((0 . "DIMENSION"))))
  29.     (progn
  30.       (setq n -1 i 0)
  31.       (while (setq ent (ssname ss (setq n (1+ n))))
  32.         (setq obj (vlax-ename->vla-object ent) edata (entget ent) dxfstr (assoc 1 edata))
  33.         (if (= (setq idx (vl-string-search "%%C" (strcase (cdr dxfstr)))) 0)
  34.           (progn
  35.             (entmod (subst (cons 1 (substr (cdr dxfstr) 4)) dxfstr edata))
  36.             (setq i (1+ i))
  37.           )
  38.           (if (equal (strcase (vl-string-trim " " (vla-get-TextPrefix obj))) "%%C")
  39.             (vla-put-TextPrefix obj "")
  40.           )
  41.         )
  42.       )
  43.       (princ (strcat "\n选择了" (itoa (sslength ss)) "个图元;处理了" (itoa i) "个图元!" ))
  44.     )
  45.   )
  46.   (command "UNDO" "e")
  47.   (prin1)
  48. )
发表于 2025-3-10 11:59:48 来自手机 | 显示全部楼层
感谢两位大神的分享
发表于 2025-3-10 16:10:34 | 显示全部楼层
太棒了,感谢两位大神的分享
GMT+8, 2025-5-25 00:33 , Processed in 0.168987 second(s), 22 queries , Gzip On.
