查看: 2399|回复: 24
[源码] 将各种线型反向——多选版
发表于 2025-3-8 17:26:26 | 显示全部楼层 |阅读模式
(defun C:FS (/ ss i ent ENT1 Q Q2 cp r os)
  (prompt "\n将各种线型反向——多选版")
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  ;; 多选对象
  (if (setq ss (ssget '((0 . "LINE,ARC,CIRCLE,LWPOLYLINE,SPLINE"))))
      (repeat (setq i (sslength ss))
        (setq ent (ssname ss (setq i (1- i)))
              ENT1 ent
              ENT (entget ENT1))
        (cond
          ;;━━━━━━ 多段线处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "LWPOLYLINE")
           (reverseLwp ENT1))
          ;;━━━━━━ 直线处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "LINE")
           (setq Q (cons 10 (cdr (assoc 11 ENT)))
                 Q2 (cons 11 (cdr (assoc 10 ENT))))
           (entmod (subst Q2 (assoc 11 ENT) (subst Q (assoc 10 ENT) ENT)))
          ;;━━━━━━ 样条曲线处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "SPLINE")
           (command "SPLINEDIT" ENT1 "E" "")
           (command "")
          ;;━━━━━━ 圆弧处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "ARC")
           (command "pedit" ENT1 "y" "")
           (reverseLwp (entlast))
           (entdel ENT1)
          ;;━━━━━━ 圆处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "CIRCLE")
           (setq cp (cdr (assoc 10 ENT))
                 r (cdr (assoc 40 ENT)))
           (entmake
             (list
               '(0 . "LWPOLYLINE")
               '(100 . "AcDbEntity")
               '(67 . 0)
               '(410 . "Model")
               '(100 . "AcDbPolyline")
               '(90 . 2)
               '(70 . 129)
               (cons 10 (polar cp 0 r))
               '(40 . 0)
               '(41 . 0)
               '(42 . -1)
               (cons 10 (polar cp pi r))
               '(40 . 0)
               '(41 . 0)
               '(42 . -1)
           (command "_matchprop" ENT1 (entlast) "")
           (entdel ENT1)
    (prompt "\n未选择有效对象")
  (setvar "osmode" os)
;;; 多段线反转子程序(保持不变)
(defun reverseLwp (ent1 / a pl how li1 li2 li3)
  (setq pl (entget ent1 '("*")) how nil)
  (foreach an pl
    (if (setq a (member (car an) '(10 40 41 42)))
      (setq how t))
    (cond
      ((not how)
       (setq li1 (cons an li1)))
      ((and how a)
       (cond
         ((= (car an) 40) (setq an (cons 41 (cdr an))))
         ((= (car an) 41) (setq an (cons 40 (cdr an))))
         ((= (car an) 42) (setq an (cons 42 (- 0 (cdr an)))))
         (t an)
       (setq li2 (cons an li2))
      ((and how (not a))
       (setq li3 (cons an li3)))
  (entmod (append (reverse li1)
                  (append (cdddr li2) (list (car li2) (cadr li2) (caddr li2)))
                  (reverse li3)))
(command "SPLINEDIT" ENT1 "E" "") 后面似乎多了一个 (command "")  发表于 2025-3-8 20:23
参与人数 2明经币 +2 金钱 +5 收起 理由
tigcat + 1 + 5
xyp1964 + 1
发表于 2025-7-25 16:43:31 | 显示全部楼层
修改后的完整程序。(defun C:FS (/ ss i ent ENT1 Q Q2 cp r os)
  (setvar "osmode" 0)
  ;; 多选对象
              ENT1 ent
              ENT (entget ENT1))
        (cond
           (reverseLwp ENT1))
           (command "SPLINEDIT" ENT1 "r" "")
           (command "pedit" e "x" "")
           ;;(command "")暂时注释
           (command "pedit" ENT1 "y" "n")
           (entdel ENT1)
          ;;━━━━━━ 圆处理 ━━━━━━
           (entmake
             (list
               '(0 . "LWPOLYLINE")
               '(67 . 0)
               '(410 . "Model")
               '(90 . 2)
               '(70 . 129)
               '(40 . 0)
               '(41 . 0)
               '(42 . -1)
               '(40 . 0)
               '(41 . 0)
               '(42 . -1)
           (entdel ENT1)
;;; 多段线反转子程序(保持不变)
  (foreach an pl
      (setq how t))
    (cond
      ((not how)
      ((and how a)
       (cond
         (t an)
      ((and how (not a))
                  (reverse li3)))
发表于 2025-3-9 12:15:06 | 显示全部楼层
qazxswk 发表于 2025-3-9 05:11
这个依然不起作用。
  1. (defun c:tt ()
  2.   (while (setq e (car (entsel "\n选择圆弧<退出>: ")))
  3.     (cond ((= (cdr (assoc 0 (entget e))) "ARC")
  4.            ;(xyp-Put-Mark (vlax-curve-getStartPoint e) 1 0)
  5.            (setvar "PEDITACCEPT" 1)
  6.            (command "pedit" e "")
  7.            (setq e (entlast))
  8.            (command "pedit" e "r" "")
  9.            ;(xyp-Put-Mark (vlax-curve-getStartPoint e) 2 0)
  10.           )
  11.     )
  12.   )
  13.   (princ)
  14. )
发表于 2025-7-25 16:41:44 | 显示全部楼层
     样条曲线这样就对了。
           ;;(command "")暂时注释
发表于 2025-3-8 17:58:35 | 显示全部楼层
我也写过这个功能,目前对圆弧不起作用。试了你这个,也是一样。
发表于 2025-3-8 20:16:09 | 显示全部楼层
  1. ;多段线反向
  2. (command "pedit" e "r" "")
 楼主| 发表于 2025-3-8 21:56:04 | 显示全部楼层
           (entdel ENT1)
这个不起作用,请教版主!谢谢
发表于 2025-3-8 23:08:21 | 显示全部楼层
           (comm ...
  1. ((= (cdr (assoc 0 (entget e))) "ARC")
  2.   (setvar "PEDITACCEPT" 1)
  3.   (command "pedit" e "")
  4.   (setq e (entlast))
  5.   (command "pedit" e "r" "")
  6. )
发表于 2025-3-9 05:11:52 | 显示全部楼层
这个依然不起作用。
 楼主| 发表于 2025-3-9 09:49:08 | 显示全部楼层
试了,的确不行!
  (setq e (entlast))
发表于 2025-3-9 11:52:21 | 显示全部楼层
我试用了DS,也没有帮我解决这个问题。
发表于 2025-3-9 12:51:57 | 显示全部楼层
你试试把这文件中的线型反向,如果反向成功,文字会调方向的。
GMT+8, 2025-8-12 04:28 , Processed in 0.237930 second(s), 29 queries , Gzip On.
