- 积分
- 33953
- 明经币
- 个
- 注册时间
- 2016-9-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
焊缝编号递增复制 快捷键《 DZFZ 》
多关键字[增(W)/减(S)/步减(Q)/步增(E)/括号(B) or 常规(R)/子级(D) or 父级(A)]
适用范围:A-Z单个字母开头,后面只有数字或者数字后面跟着-,-后面只有数字的字符串
如:B1;A10;D101;B1-1;A10-5;D101-50等等
 - ;;说明
DZFZ)焊缝编号递增复制
- (defun C:DZFZ(/ dxf dxflst endstr ent fnum index iskh iskhchange issub keywords matchstr prfix promptstr pt pt0 refpt setp snum startstr str tempstr txthig vet)
- (defun dxf(ent code)
- (if ent
- (progn
- (cond
- ((equal (type ent) 'ENAME) (setq ent (entget ent)))
- ((equal (type ent) 'VLA-OBJECT) (setq ent (entget (vlax-vla-object->ename ent))))
- (cdr (assoc code ent))
- (progn
- (princ "\n对象传入错误,传入图原名、组码表或VLA-OBJECT对象!")
- nil
- (setq matchstr "[A-Z]#,[A-Z]##,[A-Z]###,[A-Z]#-#,[A-Z]#-##,[A-Z]#-###,[A-Z]##-#,[A-Z]##-##,[A-Z]##-###,[A-Z]###-#,[A-Z]###-##,[A-Z]###-###,([A-Z]#),([A-Z]##),([A-Z]###),([A-Z]#-#),([A-Z]#-##),([A-Z]#-###),([A-Z]##-#),([A-Z]##-##),([A-Z]##-###),([A-Z]###-#),([A-Z]###-##),([A-Z]###-###)")
- (if (and
- (progn
- (initget "E")
- (setq ent (entsel "\n拾取文字[输入内容(E)]:"))
- (if ent (if (= (type ent) 'STR) (setq ent (getstring "\n输入内容:")) (setq ent (car ent))))
- (wcmatch
- (setq str
- (if (= (type ent) 'ENAME)
- (progn
- (setq pt0 (dxf ent 11) refpt (getpoint "\n拾取参考点:"))
- (setq vet (mapcar '- pt0 refpt))
- (setq dxflst (entget ent))
- (setq dxflst (vl-remove (assoc 5 dxflst) dxflst))
- (dxf ent 1)
- (progn
- (setq
- refpt (getpoint "\n拾取参考点:")
- pt0 (getpoint refpt "\n拾取相对放置点:")
- vet (mapcar '- pt0 refpt)
- txthig (if (setq txthig (getreal "\n输入文字高度<3.5>:")) txthig 3.5)
- dxflst (list '(0 . "TEXT") (cons 1 ent) (cons 10 pt0) (cons 11 pt0) (cons 40 txthig) '(41 . 0.7) '(71 . 0) '(72 . 4))
- ent
- matchstr
- (progn
- (setq
- iskh (wcmatch str "(*)")
- issub (wcmatch str "*-*")
- prfix (substr str (if iskh 2 1) 1)
- setp 1
- startstr (if iskh "(" "")
- endstr (if iskh ")" "")
- (setq tempstr (vl-string-trim (strcat startstr prfix endstr) str))
- (if issub
- (setq
- index (vl-string-search "-" tempstr)
- fnum (atoi (substr tempstr 1 index))
- snum (atoi (substr tempstr (+ index 2)))
- (setq fnum (atoi tempstr) snum 1)
- (setq str
- (strcat startstr prfix
- (if issub
- (strcat (itoa fnum) "-" (itoa (setq snum (+ snum setp))))
- (itoa (setq fnum (+ fnum setp)))
- endstr
- (cond
- ((and iskh issub) (setq promptstr "[增(W)/减(S)/步减(Q)/步增(E)/常规(R)/父级(A)]" keywords "W S Q E R A"))
- ((and iskh (not issub)) (setq promptstr "[增(W)/减(S)/步减(Q)/步增(E)/常规(R)/子级(D)]" keywords "W S Q E R D"))
- ((and issub (not iskh)) (setq promptstr "[增(W)/减(S)/步减(Q)/步增(E)/括号(B)/父级(A)]" keywords "W S Q E B A"))
- (t (setq promptstr "[增(W)/减(S)/步减(Q)/步增(E)/括号(B)/子级(D)]" keywords "W S Q E B D"))
- (setq iskhchange nil)
- (while (progn (initget keywords) (setq pt (getpoint refpt (strcat "\n拾取放置点" promptstr "步长<" (itoa setp) ">,当前<" str ">:"))))
- (if (= (type pt) 'STR)
- (progn
- (setq pt (strcase pt))
- (cond
- ((equal pt "W") (if issub (setq snum (+ snum setp)) (setq fnum (+ fnum setp))))
- ((equal pt "S") (if issub (setq snum (if (< (- snum setp) 1) 1 (- snum setp))) (setq fnum (if (< (- fnum setp) 1) 1 (- fnum setp)))))
- ((equal pt "Q")
- (setq setp (1- setp))
- (if issub
- (setq snum (if (< (1- snum) 1) 1 (1- snum)))
- (setq fnum (if (< (1- fnum) 1) 1 (1- fnum)))
- ((equal pt "E")
- (setq setp (1+ setp))
- (if issub (setq snum (1+ snum)) (setq fnum (1+ fnum)))
- ((equal pt "R") (setq iskh nil)
- (if iskhchange
- (progn
- (if issub
- (setq snum (+ snum setp))
- (setq fnum (+ fnum setp))
- ((equal pt "B") (setq iskh T)
- (if (not iskhchange)
- (progn
- (if issub
- (setq snum (if (< (- snum setp) 1) 1 (- snum setp)))
- (setq fnum (if (< (- fnum setp) 1) 1 (- fnum setp)))
- (setq iskhchange t)
- ((equal pt "A") (setq issub nil fnum (+ fnum setp)))
- ((equal pt "D") (setq issub T))
- (setq
- startstr (if iskh "(" "") endstr (if iskh ")" "")
- str
- (if issub
- (strcat (itoa fnum) "-" (itoa snum))
- (itoa fnum)
- endstr
- (progn
- (if (not issub) (setq snum 1))
- (setq dxflst (subst (cons 1 str) (assoc 1 dxflst) dxflst))
- (setq pt (mapcar '+ pt vet))
- (setq dxflst (subst (cons 10 pt) (assoc 10 dxflst) dxflst))
- (setq dxflst (subst (cons 11 pt) (assoc 11 dxflst) dxflst))
- (entmake dxflst)
- (setq str
- (if issub
- endstr
- (cond
- (prin1)
- (princ "\n焊缝编号递增复制 快捷键《 DZFZ 》\n适用范围:A-Z单个字母开头,后面只有数字或者数字后面跟着-,-后面只有数字的字符串\n如:B1;A10;D101;B1-1;A10-5;D101-50;等等")
- (prin1)
