在中望CAD2014中,旋转角度后,右中对齐
添加 (command "none" (car ps)),使多段线闭口
 - (vl-load-com)
- ;(setq e(car(entsel)))
- ;取得多行文本各单行包围框
- ;有缩进/自然换行的炸取配合取得
- (defun Mtextsubboxs (e / ang ang0 boxs czmstr2stri czmstr2text czreplacestr d d0 d1 e1 es exp1 explodedata getmtextbox h hids hids1 mstr ob p01 p02 p03 p04 p1 p11 p12 p2 polarps pos ps putstr2getbox sjd str1 verrot2d)
- (progn
- (vl-load-com)
- ;正则表达式字符串替换
- ;lst: (list(list n1 o1)(list n2 o2))
- (defun CZReplacestr (str lst / regex)
- (if lst
- (progn
- (setq regex (vlax-create-object "Vbscript.RegExp")) ;引用正则表达式控件
- (vlax-put-property regex "IgnoreCase" 0) ;不忽略大小写
- (vlax-put-property regex "Global" 1) ;匹配方式,全文字匹配
- (foreach x lst
- (vlax-put-property regex "Pattern" (cadr x))
- (setq str (vlax-invoke-method regex "Replace" str (car x))) ;匹配替换
- (vlax-release-object regex)
- str
- ;多行文本取得单行字符(类似炸开后取得的结果-自然换行没识别)
- (defun CZmstr2text (str / a l2 text1)
- (setq str
- (CZReplacestr
- str
- '(("\001" "\\\\\\\\")
- ("\002" "\\\\{")
- ("\003" "\\\\}")
- ("\t" "\\\\p(.[^;]*);")
- ("$2\t" "\\\\S(\\^|#)(.[^;]*);")
- ("$1\t" "\\\\S(.[^;]*)(\\^|#);")
- ("\t" "(\\\\F|\\\\f|\\\\C|\\\\H|\\\\T|\\\\Q|\\\\W|\\\\A)(.[^;]*);")
- ("\t" "(\\\\L|\\\\O|\\\\l|\\\\o)")
- ("\t" "\\\\~")
- ("\t" "\\\\P")
- ("\t" "\n")
- ("\t" "\r")
- ("\t" "({|})")
- ("\\" "\\x01")
- ("{" "\\x02")
- ("}" "\\x03")
- (while (setq a (vl-string-search "\t" str))
- (if
- (and (> a 0)
- (/= "" (vl-string-right-trim " " (setq text1 (substr str 1 a))))
- (setq l2 (cons text1 l2))
- (setq str (substr str (+ 2 a)))
- (if (> (strlen str) 1) (setq l2 (cons str l2)))
- (reverse l2)
- ;获取各行单行正文文本及在母文本的位置信息
- ;(CZmstr2stri mstr(CZmstr2text mstr))
- (defun CZmstr2stri (mstr strs / dd flag2 hp hstr i k m n n1 ns ps ps1 str str1)
- (setq i 0
- k 0
- hstr ""
- m 0
- (foreach str strs
- (if (listp str)
- (setq ps (cadr str)
- str (car str)
- ;str为lst特殊用法-炸取的子串可获取自然换行
- (setq dd (strlen str)
- n1 0
- m (1+ m)
- (while (setq n1 (vl-string-search str mstr n1))
- (if
- (wcmatch (substr mstr 1 n1) ",*[};{],*\\P,*\t,*\r,*\n,*\\L,*\\O,*\\o,*\\~")
- (setq n n1
- n1 (strlen mstr)
- (setq n1 (+ dd n1))
- (if n
- (progn
- (setq str1 (substr mstr 1 n))
- (setq mstr (substr mstr (+ 1 dd n)))
- (setq i (+ n k i)) ;括号内-k上一次单行长i上次单行位置
- (setq k dd)
- (if
- (or (vl-string-search "\\P" str1)
- (vl-string-search "\n" str1)
- ;下面2项是判断自然换行
- (and hp (= i (+ (caar hp) (cadar hp))) (setq flag2 t))
- (and ps
- ps1
- (abs
- (car
- (trans (mapcar '- (car ps) (car ps1))
- 0
- (mapcar '- (cadr ps1) (car ps1))
- (* 1.2 (caddr ps))
- (setq flag2 t)
- ) ;行首判断
- (setq ns (if hp (cons (cons hstr (reverse hp)) ns))
- hp (cond
- ((not ps) (list (list i dd)))
- (t
- (if flag2
- (list (list i dd (car ps) "\n"))
- (list (list i dd (car ps)))
- ) ;自然换行标记"\n"另用
- flag2 nil
- hstr str
- (setq hp
- (if (and ps (= 1 m))
- (cons (list i dd (car ps)) hp)
- (cons (list i dd) hp)
- hstr (strcat hstr str)
- (setq ps1 ps)
- (reverse (cons (cons hstr (reverse hp)) ns))
- ;炸取MTEXT字串数据
- (defun explodedata (e / ang e0 el es h l1 p str)
- (setq el (entlast) es (entget e))
- (setq ang (cdr (assoc 50 es)))
- (vla-Copy (vlax-ename->vla-object e))
- ((if command-s command-s vl-cmdf) "_explode" (entlast))
- (while (setq el (entnext el))
- (setq es (entget el))
- (setq e0 (cdr (assoc 0 es)))
- (if
- (and
- (= e0 "TEXT")
- (/= "" (vl-string-right-trim " " (setq str (cdr (assoc 1 es)))))
- (setq
- p (cdr (assoc 10 es))
- h (cdr (assoc 40 es))
- l1 (cons (list str (list p (polar p ang (* 10 h)) h)) l1)
- (entdel el)
- (reverse l1)
- (defun getMtextbox (e / a es l l1 p1 p2 w w1 z)
- (setq
- es (entget e)
- a (cdr (assoc 50 es))
- l (cdr (assoc 42 es))
- w (cdr (assoc 43 es))
- z (cdr (assoc 71 es))
- w1 (if (member z '(4 5 6)) (* 0.5 w) (if (member z '(7 8 9)) 0 w))
- l1 (if (member z '(2 5 8)) (* 0.5 l) (if (member z '(1 4 7)) 0 l))
- p1 (polar (polar (verRot2D (cdr (assoc 10 es)) (- 0 a)) pi l1)
- (* 1.5 pi)
- w1
- p1 (verRot2D p1 a)
- p2 (polar p1 a l)
- a (+ a (* 0.5 pi))
- (list p1 p2 (polar p2 a w) (polar p1 a w))
- (defun verRot2D (v a / c s x y)
- (setq
- c (cos a)
- s (sin a)
- x (car v)
- y (cadr v)
- (list (- (* x c) (* y s)) (+ (* x s) (* y c)))
- );;; 旋转向量到指定角度 by高飞
- (defun polarps (ps ang d)
- (mapcar (function (lambda (p) (polar p ang d))) ps)
- ) ;点集按向移位
- (defun putstr2getbox (e str)
- (Vlax-Put (vlax-ename->vla-object e) 'TextString str)
- (entupd e)
- (setq ps (getMtextbox e))
- (setq ob (vlax-ename->vla-object e))
- (setq es (entget e))
- (setq pos (cdr (assoc 71 es)))
- (setq mstr (Vlax-Get ob 'TextString))
- (setq p01 (car ps)
- p02 (cadr ps)
- p03 (caddr ps)
- p04 (cadddr ps)
- (setq d0 (cdr (assoc 41 es)))
- (setq h (* 1.35 (cdr (assoc 40 es))))
- (if
- (and
- (or (= 0 d0) (> d0 (+ h (distance p01 p02))))
- ;+h是确保无自然换行
- (not (wcmatch mstr "*\\pxi#*,*\\pxi-#*,*\\pi#*,*\\pi-#*")) ;无缩进
- (setq hids (reverse (CZmstr2stri mstr (CZmstr2text mstr))))
- ;可以不炸取的情况
- (setq hids (reverse (CZmstr2stri mstr (explodedata e))))
- ;有自然换行或缩进,炸取单行文本也是高效的
- (setq d0 (distance p01 p04))
- (setq ang0 (cdr (assoc 50 es))
- ang (+ (* 0.5 pi) ang0)
- (setq hids1 hids)
- (foreach id hids
- (setq e1 (entlast))
- ;复制可减少最后一次(entupd e)效率近乎倍增
- (setq str1 mstr)
- (setq str1 (substr str1 1 (+ (car (last id)) (cadr (last id)))))
- ;删除该行以后--不影响格式
- (if (cadddr (cadr id))
- (setq str1 (strcat
- (substr str1 1 (caadr id))
- "\n"
- (substr str1 (1+ (caadr id)))
- ) ;炸取数据有自然换行l临时加入换行符-取包围框
- (if (setq p1 (caddr (cadr id)))
- (setq sjd (car (trans (mapcar '- p1 p04) 0 (mapcar '- p01 p04))))
- (setq sjd 0)
- ) ;炸取数据取得的行首基点-计算缩进
- (setq ps (putstr2getbox e1 str1))
- (if (member pos '(7 8 9))
- (setq p1 (cadddr ps)
- p2 (caddr ps)
- (setq p1 (car ps)
- p2 (cadr ps)
- d1 (distance (car ps) (cadddr ps))
- ) ;比对基线点
- (foreach subid (setq hids1 (cdr hids1))
- (foreach a (reverse (cdr subid))
- (substr str1 1 (car a))
- (substr str1 (+ 1 (car a) (cadr a)))
- ) ;改行以前有效字符全换为""
- (entdel e1)
- (setq p11 (car ps)
- p12 (cadr ps)
- ) ;比对基线点
- (setq exp1 '(list p11 p12 (polar p12 ang h) (polar p11 ang h)))
- (setq ps (eval exp1)
- d (car (trans (mapcar '- (caddr ps) p1) 0 (mapcar '- p2 p1)))
- ps (polarps ps ang (+ d d0 (- 0 h)))
- (setq d (car (trans (mapcar '- p11 p2) 0 (mapcar '- p1 p2)))
- p11 (polar p11 ang d)
- p12 (polar p12 ang d)
- ps (eval exp1)
- ps (if (member pos '(1 2 3))
- ps
- (polarps ps ang (* 0.5 (- d0 d1)))
- (setq ps (polarps ps ang0 sjd))
- (setq boxs (cons (list (caadr id) (strlen (car id)) ps) boxs))
- ;(setq boxs(cons ps boxs))
- boxs
- ;测试
- (defun c:tt66 (/ e)
- (if (setq e (ssget ":s:e" '((0 . "mtext"))))
- (foreach ps (mapcar 'caddr (Mtextsubboxs (ssname e 0)))
- (command "pline")
- (foreach p ps (command "none" p))
- (command "none" (car ps))
- (command "")
