查看: 465|回复: 4
[提问] vla选择集activeselectionset如何使用?
发表于 2025-5-5 08:39:46 | 显示全部楼层 |阅读模式
;为什么这个vla-get-activeselectionset有时候会失灵?
例如:原因:Automation 错误。未提供说明。
Automation 错误。 调用方法 AddItems (接口 IAcadSelectionSet) 失败
  1. (defun c:dc(/ doc objss ss)
  2.         (vl-load-com)
  3.         (if(setq ss(ssget))
  4.                 (progn
  5.                         (setq doc(vla-get-ActiveDocument(vlax-get-acad-object)))
  6.                         (setq objss(vla-get-activeselectionset doc))
  7.                         (vla-wblock doc "D:/Temp.dwg" objss)
  8.                         (print "文件导出成功!")
  9.                 )
  10.         )
  11.         (princ)
  12. )
发表于 2025-5-6 09:39:05 | 显示全部楼层
或者
  1. <div class="blockcode"><blockquote>(defun c:dca(/ ssa doc setss ents objss ssetObj)
  2.     (vl-load-com)
  3.      (if (setq ssa (ssget))
  4.          (progn
  5.        (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  6.        (setq setss (vla-get-SelectionSets doc))
  7.        (setq ents (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssa))))
  8.        (setq objss (vlax-make-safearray vlax-vbObject (cons 0 (1- (length ents)))))
  9.        (vlax-safearray-fill objss (mapcar 'vlax-ename->vla-object ents))
  10.        (if (vl-catch-all-error-p (setq ssetObj (vl-catch-all-apply 'vla-Add (list setss "WBLOCKSET"))))
  11.            (vla-Delete (vla-item setss "WBLOCKSET"))
  12.        )
  13.        (setq ssetObj (vla-Add setss "WBLOCKSET"))
  14.        (vla-AddItems ssetObj objss)
  15.              (vla-wblock doc "D:\\Temp.dwg" ssetObj)
  16.              (vla-Delete ssetObj)
  17.        (print "文件导出成功!")
  18.           )
  19.      )
  20.      (princ)
  21. )
发表于 2025-5-6 09:20:13 | 显示全部楼层
(defun c:dc(/ ssa doc ssetObj objss ni)
    (vl-load-com)
             (setq ssetObj (vla-Add (vla-get-SelectionSets doc) "WBLOCKSET"))
             (setq objss (vlax-make-safearray vlax-vbObject (cons 0 (1- (sslength ssa)))))
             (repeat (setq ni (sslength ssa))
                 (setq ni (1- ni))
                 (vlax-safearray-put-element objss ni (vlax-ename->vla-object (ssname ssa ni)))
             (print "文件导出成功!")
 楼主| 发表于 2025-5-6 20:17:04 | 显示全部楼层
感谢长老回复,不过我还是想了解那个vla-get-activeselectionset函数为什么不能和ssget进行配合?
我那个程序,有时候灵,有时候不灵,不太稳定,我很纳闷
发表于 2025-5-7 16:11:16 | 显示全部楼层
看来还是用wblock命令简洁啊
GMT+8, 2025-6-1 16:11 , Processed in 0.176862 second(s), 26 queries , Gzip On.
