查看: 870|回复: 7
[提问] 合并标注
发表于 2025-5-5 21:25:24 | 显示全部楼层 |阅读模式
还是不能实现,请大佬们修正完善
;;; 合并标注工具(兼容所有CAD版本)- 修正版
(defun c:dmrg (/ *error* ss dims ptlst old_osm old_dimzin old_dimstyle)
  ;; 错误处理函数
  (defun *error* (msg)
    (if old_osm (setvar "osmode" old_osm))
    (if old_dimzin (setvar "dimzin" old_dimzin))
    (if old_dimstyle (setvar "dimstyle" old_dimstyle))
    (princ (strcat "\n错误: " msg))
    (princ))
  ;; 保存系统变量
  (setq old_osm (getvar "osmode")
        old_dimzin (getvar "dimzin")
        old_dimstyle (getvar "dimstyle"))
  ;; 选择标注集合并检查
  (princ "\n选择要合并的标注: ")
  (if (not (setq ss (ssget '((0 . "DIMENSION")))))
    (progn (princ "\n未选择标注!") (exit)))
  ;; 初始化参数(修复列表处理)
  (setvar "osmode" 0)
  (setvar "dimzin" 0)
  (setq dims (vl-remove-if-not '(lambda(x) (eq (type x) 'ENAME)) (mapcar 'cadr (ssnamex ss)))
        ptlst (vl-remove nil (mapcar 'get_dim_points dims))) ; 过滤无效标注
  ;; 检查有效数据
  (if (null ptlst)
    (progn (princ "\n未找到有效标注数据!") (exit)))
  ;; 检查标注类型和方向
  (if (not (check_alignment ptlst))
    (progn (princ "\n标注不在同一直线!") (exit)))
  ;; 排序标注点(增加空列表保护)
  (setq ptlst (sort_points ptlst))
  ;; 创建新标注(增加容错处理)
  (cond
    ((= (getvar "users1") "BASELINE")
      (create_baseline_dim ptlst))
    (t (create_continue_dim ptlst)))
  ;; 删除原标注(增加存在性检查)
  (if (= (getvar "users2") "1")
    (mapcar '(lambda(x) (if (entget x) (entdel x))) dims))
  ;; 恢复系统变量
  (princ "\n标注合并完成!")
  (princ))
;;; 获取标注关键点(增加数据有效性检查)
(defun get_dim_points (ent / data p1 p2)
  (cond
    ((null ent) nil)
    ((not (entget ent)) nil)
    (t
      (setq data (entget ent))
      (if (and (assoc 13 data) ; 增加关键组码检查
               (assoc 14 data)
               (assoc 10 data))
        (list
          (cdr (assoc 13 data))  ; 标注点1
          (cdr (assoc 14 data))  ; 标注点2
          (cdr (assoc 10 data))  ; 文字位置
          (cdr (assoc 1 data))   ; 标注文字
          (cdr (assoc 3 data)))   ; 标注样式
        nil)))) ; 返回nil代替无效数据
;;; 检查标注对齐方式(增加空列表保护)
(defun check_alignment (ptlst / ang tolerance)
  (setq tolerance 0.0001)
  (cond
    ((< (length ptlst) 2) t)
    ((vl-every
       '(lambda (a b)
          (and a b (< (abs (- (angle (car a) (cadr a))
                               (angle (car b) (cadr b))))
                       tolerance)))
       ptlst
       (cdr ptlst)))
    (t nil)))
;;; 排序标注点(增强鲁棒性)
(defun sort_points (ptlst / basept)
  (if (and ptlst (car ptlst) (caar ptlst))
      (setq basept (caar ptlst))
      (vl-sort ptlst
        '(lambda (a b)
           (and a b (< (distance basept (car a))
                       (distance basept (car b))))))
    ptlst)))
;;; 创建连续标注(增加命令容错)
(defun create_continue_dim (ptlst / p1 p2 txt)
  (if (car ptlst)
      (command "_.dimstyle" "r" (cadddr (car ptlst)))
      (foreach dim ptlst
        (if (and dim (car dim) (cadr dim))
            (setq p1 (car dim)
                  p2 (cadr dim)
                  txt (caddr dim))
            (if (not (eq dim (car ptlst)))
                (command "_.dimcontinue")
                (command (trans p1 0 1) (trans p2 0 1))
                (if (/= txt "") (command "_text" txt)))
                (command "_.dimlinear"
                  (trans p1 0 1)
                  (trans p2 0 1)
                  "_none"
                  (trans (caddr dim) 0 1))
                (command txt)))))))))
;;; 创建基线标注(增加坐标系转换)
(defun create_baseline_dim (ptlst / basept p1 p2)
  (if (car ptlst)
      (setq basept (trans (caar ptlst) 0 1))
      (foreach dim ptlst
            (setq p1 (trans (car dim) 0 1)
                  p2 (trans (cadr dim) 0 1))
            (if (eq dim (car ptlst))
              (command "_.dimlinear" p1 p2 "_none" (trans (caddr dim) 0 1))
                (command "_.dimbaseline")
                (command p1 p2 "_none" (trans (caddr dim) 0 1))))))))))
;;; 加载提示
(princ "\n合并标注工具已加载,输入 DMRG 启动。")
发表于 2025-5-5 21:28:36 | 显示全部楼层
你这是拿AI的代码训练大佬呢。自己都不先钻研尝试一下。
发表于 2025-5-5 22:33:29 | 显示全部楼层
风趣幽默的
发表于 2025-5-5 23:11:48 | 显示全部楼层
感谢大佬的分享
发表于 2025-5-6 09:04:37 | 显示全部楼层
正确的中肯的一阵见血的
发表于 2025-5-6 09:15:55 | 显示全部楼层
就拿这个考验老干部?
发表于 2025-5-6 12:23:26 | 显示全部楼层
哪里有问题就继续问 是在不行就换个思路重新开始
发表于 2025-5-8 14:42:29 | 显示全部楼层
合并标注需要这么复杂吗?
GMT+8, 2025-6-1 16:10 , Processed in 0.187964 second(s), 26 queries , Gzip On.
