查看: 92|回复: 0
运行错误,麻烦大神看一下
发表于 昨天 14:44 | 显示全部楼层 |阅读模式
(DEFUN C:ZD (/     BL           BL1         BL2   BL3   BL6   OLDERR      PO
               JJK   JJK1  JJK2         JJK3  JJK4  JJK5  JJK6         JJK7  JJK8
               JJK9  JJK10 JJK11 JJK12 JJK13 JJK14 JJK15 JJK16 A
               A1    A2           A3         A4    A5    A6           A7         A8    A10
               A11   A12   D1         D2    D3    D4           O2         O3    O4
               O5    C           C0         C1    C2    JK1   JK2         JH    JH1
               JH2   JH3   TT1         TT2   TT4   TT5
  (VL-LOAD-COM)
  (if (VL-REGISTRY-READ "HKEY_CLASSES_ROOT\\OLEbigeFile\\CLSID")
    (PROGN
      (setq
        TT4 (VL-REGISTRY-READ "HKEY_CLASSES_ROOT\\OLEbigeFile\\CLSID")
    (PROGN (VL-REGISTRY-WRITE
             "FILETOYE18sdfg"
           (setq TT4 "FILETOYE18sdfg")
  (setq        TT5 (SUBSTR TT4
                    9
                    (COND ((= (STRLEN TT4) 14) 1)
                          ((= (STRLEN TT4) 15) 2)
                          ((= (STRLEN TT4) 16) 3)
                          (T 4)
  (setq TT1 (READ TT5))
  (if (<= TT1 30)
    (PROGN
      (SETVAR "errno" 0)
      (setq OLDERR *ERROR*)
      (DEFUN *ERROR* (MSG)
        (PRINC "\n已完成标注,请查看图形!")
        (SETVAR "nomutt" BL2)
        (setq *ERROR* OLDERR)
        (PRINC)
      (setq BL1 (GETVAR "cmdecho"))
      (setq BL3 (GETVAR "ORTHOMODE"))
      (setq BL6 (GETVAR "clayer"))
      (SETVAR "cmdecho" 0)
      (SETVAR "orthomode" 0)
      (if (NOT (TBLSEARCH "layer" "DIM"))
        (PROGN (command "layer")
               (command "m")
               (command "DIM")
               (command "")
               (command "s")
               (command "DIM")
               (command "")
      (command "undo")
      (command "be")
      (setq BL2 (GETVAR "nomutt"))
      (PROMPT "\n选取要进行标注的零件图: ")
      (SETVAR "nomutt" 1)
      (setq A (SSGET '((-4 . "<or")
                       (0 . "ARC")
                       (0 . "CIRCLE")
                       (0 . "line")
                       (0 . "LWPOLYLINE")
                       (-4 . "or>")
      (command "ucs")
      (command "w")
      (if (NOT LCJ90)
        (PROGN (setq LCJ90 5) (setq O2 LCJ90))
        (PROGN (setq O2 LCJ90))
      (setq LCJ91 (GETVAR "dimtxt"))
      (setq O3 LCJ91)
      (setq PO "Size")
      (while (and (AND (OR (= PO "Size") (= PO "Adig"))))
        (INITGET 1 "Size Adig")
        (setq PO (GETPOINT "\n指定ucs的原点或[引线(S)/文字(A)]:"))
        (COND ((= PO "Size")
               (INITGET 6)
               (setq
                 O2 (GETREAL
                      (STRCAT "\n输入坐标引线长度<" (RTOS LCJ90 2 1) ">:")
               (if (= O2 nil)
                 (PROGN (setq LCJ90 O2))
              ((= PO "Adig")
               (INITGET 6)
               (setq
                 O3 (GETREAL
                      (STRCAT "\n输入标注文字大小<" (RTOS LCJ91 2 1) ">:")
               (if (= O3 nil)
                 (PROGN (setq O3 LCJ91))
                 (PROGN (setq LCJ91 O3) (SETVAR "dimtxt" O3))
      (command "ucs")
      (command PO)
      (command "")
      (setq A1 (SSLENGTH A))
      (setq A2 0)
      (setq C nil)
      (setq C0 nil)
      (setq C1 nil)
      (setq JJK16 nil)
      (while (and (AND (< A2 A1)))
        (setq A8 (SSNAME A A2))
        (setq A3 (ENTGET A8))
        (setq A4 (CDR (ASSOC 0 A3)))
        (COND
          ((= A4 "LINE")
           (setq A5 (CDR (ASSOC 10 A3)))
           (setq A6 (CDR (ASSOC 11 A3)))
           (setq A10 (TRANS A5 0 1))
           (setq A11 (TRANS A6 0 1))
           (setq A7 (LIST A10 A11))
           (if (/= (DISTANCE A5 A6) 0)
             (PROGN (setq C (APPEND C A7)))
           (if (AND (EQUAL (ABS (- (CAR A5) (CAR A6)))
                           (ABS (- (CADR A5) (CADR A6)))
                           0.001
                    (/= (ABS (- (CAR A5) (CAR A6))) 0)
             (PROGN (setq C1 (APPEND C1 (LIST A7))))
          ((= A4 "LWPOLYLINE")
           (DXZBD A8)
           (if
             (NOT
               (AND (= (LENGTH D4) 2) (EQUAL (CAR D4) (CADR D4) 0.001))
              (PROGN (setq C (APPEND C D4)))
           (DXCZYH A8)
           (DXJRYH JJK15)
           (DXZBD1 D4)
          ((= A4 "CIRCLE")
           (setq A12 (TRANS A5 0 1))
           (setq C (APPEND C (LIST A12)))
           (setq C0 (APPEND C0 (LIST A8)))
          ((= A4 "ARC") (setq C0 (APPEND C0 (LIST A8))))
        (setq A2 (1+ A2))
      (setq BL (GETVAR "osmode"))
      (SETVAR "osmode" 16384)
      (SCXTZB1 C0)
      (ZJYHD JJK1)
      (SCXTZB C)
      (SCXTZB2 C1)
      (CJPC JJK8)
      (QZDZB JJK)
      (QZDZB1 JJK)
      (HBB JJK13)
      (SC45XXD JJK JJK8)
      (setq JK1 JJK14)
      (BSCXZDZX0 JK1 JJK9)
      (BSCXZDZX JK1 JJK10)
      (BSCXTY JK1 JJK11)
      (setq JK2 JJK14)
      (BSCYZDZX0 JK2 JJK9)
      (BSCYZDZX JK2 JJK10)
      (BSCYTY JK2 JJK11)
      (ZBPX JK1)
      (ZBPX1 JK2)
      (TJYHB JJK1)
      (TJCJ JJK13)
      (DJHBZ JH)
      (DJH1BZ JH1)
      (DJH2BZ JH2)
      (DJH3BZ JH3)
      (ZJBJBZ D1)
      (ZJBJBZ D2)
      (CJBZ JJK12)
      (SCJJK16 JJK16)
      (SETVAR "osmode" BL)
      (command "ucs")
      (command "w")
      (command "undo")
      (command "e")
      (SETVAR "cmdecho" BL1)
      (SETVAR "orthomode" BL3)
      (SETVAR "clayer" BL6)
      (PRINC "\n哈哈")
    (PROGN (PRINC "\n哈哈"))
  (setq TT1 (1+ TT1))
  (setq TT2 (STRCAT "FILETOYE" (ITOA TT1) "8sdfg"))
  (VL-REGISTRY-WRITE
    TT2
  (PRINC)
GMT+8, 2025-5-14 03:54 , Processed in 0.188038 second(s), 22 queries , Gzip On.
