查看: 691|回复: 7
[源码] 合并图纸lsp,不能多选,麻烦大佬们帮忙看看
发表于 2025-5-22 08:41:26 | 显示全部楼层 |阅读模式
  1. (defun c:CD (/ *error* filelst cols colgap rowgap i x y pmax pmin dx dy cdy rows)
  2.   (vl-load-com)
  3.
  4.   (defun *error* (msg)
  5.     (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
  6.       (princ (strcat "\n错误: " msg))
  7.     )
  8.     (setvar "CMDECHO" 1)
  9.     (setvar "OSMODE" 0)
  10.     (princ)
  11.   )
  12.   (defun GetSingleFile (/ fname)
  13.     (setvar "FILEDIA" 1)
  14.     (setq fname (getfiled "选择要合并的图纸" "" "dwg;dxf" 1)) ; 0表示单选模式
  15.     (if fname (list fname))
  16.   )
  17.   (setvar "CMDECHO" 0)
  18.   (command "._UNDO" "_BEGIN")
  19.
  20.   (if (setq filelst (GetSingleFile))
  21.     (progn
  22.       (initget 7)
  23.       (setq cols (getint "\n请输入列数: "))
  24.
  25.       (initget 6)
  26.       (setq colgap (getdist "\n列间距<10000>: "))
  27.       (if (not colgap) (setq colgap 10000))
  28.
  29.       (initget 6)
  30.       (setq rowgap (getdist "\n行间距<10000>: "))
  31.       (if (not rowgap) (setq rowgap 10000))
  32.
  33.       (setq i 0 x 0 y 0 cdy 0
  34.             rows (fix (1+ (/ (length filelst) cols)))
  35.       )
  36.
  37.       (foreach file filelst
  38.         (if (and (< i (* cols rows)) (findfile file))
  39.           (progn
  40.             (princ (strcat "\n正在插入: " (vl-filename-base file)))
  41.             (command "_.INSERT" file (list x y) "" "" "")
  42.
  43.             (if (entlast)
  44.               (progn
  45.                 (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'mi 'ma)
  46.                 (setq pmax (vlax-safearray->list ma)
  47.                       pmin (vlax-safearray->list mi)
  48.                       dx (- (car pmax) (car pmin))
  49.                       dy (- (cadr pmax) (cadr pmin))
  50.                 )
  51.                 (if (> dy cdy) (setq cdy dy))
  52.
  53.                 (setq i (1+ i))
  54.                 (if (= (rem i cols) 0)
  55.                   (setq x 0 y (- y cdy rowgap) cdy 0)
  56.                   (setq x (+ x dx colgap))
  57.                 )
  58.               )
  59.             )
  60.           )
  61.         )
  62.       )
  63.       (princ (strcat "\n成功插入 " (itoa i) " 个文件"))
  64.     )
  65.     (princ "\n取消文件选择")
  66.   )
  67.
  68.   (command "._UNDO" "_END")
  69.   (princ)
  70. )
ai生成得,有大佬帮忙看下不 哪里的问题 现在选择文件只能单选无法多选。谢谢
发表于 2025-5-22 09:00:40 | 显示全部楼层
lisp原生不支持多选
发表于 2025-5-22 09:21:06 | 显示全部楼层
可以用opendcl的选择框,大海哥等大神都分享过多选对话框,可以自行搜索。
发表于 2025-5-22 09:50:08 | 显示全部楼层
帮你找ai的错误?
发表于 2025-5-22 17:22:22 | 显示全部楼层
借力Doslib--->dos_getfilem
Example
Command: (dos_getfilem "Select a file" "C:\\Program Files\\Autocad 2010\\" "Drawing files (*.dwg)|*.dwg|All files (*.*)|*.*||")
("C:\\Program Files\\AutoCAD 2010\\Sample\\" "A-01.dwg" "A-02.dwg" "A-03.dwg" "A-04.dwg" "A-05.dwg")
发表于 2025-5-23 08:58:03 | 显示全部楼层
不能选择一个包含DWG文件的文件夹吗
 楼主| 发表于 2025-5-23 09:25:03 | 显示全部楼层
Example
Doslib函数库可以选择文件了 但是还有其他问题 我再研究研究 感谢提醒
 楼主| 发表于 2025-5-23 09:26:12 | 显示全部楼层
liunian0524 发表于 2025-5-23 08:58
不能选择一个包含DWG文件的文件夹吗
选择整个文件夹内所有文件可以合并 我想要得是选择其中部分文件 还在研究
GMT+8, 2025-6-24 04:21 , Processed in 0.152427 second(s), 24 queries , Gzip On.
