查看: 744|回复: 6
[源码] 计算交叉连续多段的外轮廓
发表于 2025-6-13 00:39:21 | 显示全部楼层 |阅读模式
  1. (defun c:getOuterBoundary ()
  2.   (setq s (car (entsel)))
  3.   (setq pts (getPlinePts s))
  4.   (entmakeLWPOLYLINE (getOuterBoundary pts))
  5.   (princ)
  6. )
  7. (defun entmakeLWPOLYLINE (pts)
  8.   (entmake
  9.     (append
  10.       (list
  11.   '(0 . "LWPOLYLINE")
  12.   '(100 . "AcDbEntity")
  13.   '(100 . "AcDbPolyline")
  14.   '(62 . 1)
  15.   (cons 90 (length pts))    ; 点的数量
  16.           ; 闭合标志
  17.   (if (equal (caar pts) (car (last pts)) 1e-8)
  18.     (cons 70 1)
  19.     (cons 70 0)
  20.   )
  21.       )
  22.       (mapcar '(lambda (a) (cons 10 a)) pts)
  23.     )
  24.   )
  25. )
  26. (defun getPlinePts (ent)
  27.   (vl-remove-if
  28.     'null
  29.     (mapcar
  30.       '(lambda (x)
  31.    (if (= (car x) 10)
  32.      (cdr x)
  33.    )
  34.        )
  35.       (entget ent)
  36.     )
  37.   )
  38. )
  39. (defun getOuterBoundary  (pointList / pts ptxList ptmin tmp p0 p1)
  40.   (setq PIx2 (+ pi pi))
  41.   (setq tmp (mapcar '1- (apply 'mapcar (cons 'min pointList)))) ;最下点
  42.   (setq p0 (last (sortByDistance tmp pointList))) ;最下点近点
  43.   (setq pts (getNextIntsitepts tmp p0 pointList))
  44.   (setq tmp p0)
  45.   (while (and
  46.      (setq pts (getNextIntsitepts (car pts) (cadr pts) pointList))
  47.      (setq p0 (car pts))
  48.      (setq p1 (cadr pts))
  49.      (setq ptxList (cons p0 ptxList))
  50.      (not (equal p0 tmp 1e-6))  ;回到起点退出循环
  51.    )
  52.   )
  53.           ;补起点
  54.   (setq ptxList (cons tmp ptxList))
  55.   (if (not (equal (last ptxList) (car ptxList) 1e-6))
  56.     (setq ptxList (cons (last ptxList) ptxList))
  57.   )
  58.   ptxList
  59. )
  60. ;;;是否包含点
  61. (defun ContainsEqual (lst pts / i e return)
  62.   (setq i -1)
  63.   (while (setq e (nth (setq i (1+ i)) lst))
  64.     (if  (equal e pts 1e-6)
  65.       (setq return t
  66.       i     (length lst)
  67.       )
  68.     )
  69.   )
  70.   return
  71. )
  72. ;;;计算下一点位置
  73. (defun getNextIntsitepts
  74.        (p1 p2 pointList / lst ptx ptn minLen tmp y x ptxlst)
  75.   (setq  ptn    p2
  76.   minLen (1+ (distance p1 p2))
  77.   y      (last pointList)
  78.   )
  79.   (foreach x pointList
  80.     (if  (and (setq ptx (Inters p1 p2 x y))
  81.        (not (equal p1 ptx 1e-6))
  82.   )        ;计算交点
  83.       (progn
  84.   (setq tmp (Distance p1 ptx))
  85.   (if (equal tmp minLen 1e-6)
  86.     ;;防止交点重复
  87.     (setq  lst (cons x lst)
  88.     lst (cons y lst)
  89.     )
  90.     (if (< tmp minLen)
  91. ;;;取最近交点
  92.       (setq minLen tmp
  93.       ptn   ptx
  94.       lst   (list x y p2)
  95.       )
  96.     )
  97.   )
  98.       )
  99.       (if (checkOnline p1 p2 x y)  ;检查是否共线
  100.   (setq lst (cons x lst)
  101.         lst (cons y lst)
  102.   )
  103.       )
  104.     )
  105.     (setq y x)
  106.   )
  107.   (setq ptxlst (removeEqual ptn (removeEqual p1 lst)))
  108.   (cons ptn (sortByAngle p1 ptn (sortByDistance ptn ptxlst)))
  109.   ;;交点最小角度
  110. )
  111. (defun checkOnline (p1 p2 l1 l2 / ang)
  112.   (and
  113.     (or  (equal (setq ang (getangles p1 p2 l1)) PIx2 1e-8)
  114.   (equal ang pi 1e-8)
  115.     )
  116.     (or  (equal (setq ang (getangles p1 p2 l2)) PIx2 1e-8)
  117.   (equal ang pi 1e-8)
  118.     )
  119.   )
  120. )
  121. (defun sortByAngle (pt0 pt1 ptxlst / angb anga ang0)
  122.   (vl-sort ptxlst
  123.      '(lambda (a b)
  124.         (< (getAngles pt0 pt1 a) (getAngles pt0 pt1 b))
  125.       )
  126.   )
  127. )
  128. (defun sortByDistance (p ptxlst)
  129.   (vl-sort ptxlst
  130.      '(lambda (a b) (> (distance p a) (distance p b)))
  131.   )
  132. )
  133. (defun getAngles (pt1 pt2 pt3 / ang a1 a2)
  134.   (if (or (equals pt2 pt1 1e-6) (equals pt2 pt3 1e-6))
  135.     (+ pi pi)
  136.     (progn
  137.       (setq ang (- (Angle pt2 pt3) (Angle pt2 pt1)))
  138.       (if (< ang 0)
  139.   (setq ang (+ ang pi pi))
  140.       )
  141.       (if (equal ang 0 1e-6)
  142.   (+ pi pi)
  143.   ang
  144.       )
  145.     )
  146.   )
  147. )
  148. (defun equals (a b p)
  149.   (vl-every '(lambda (x y) (equal x y p)) a b)
  150. )
  151. (defun removeEqual (ptn ptxlst / lst)
  152.   (vl-remove-if
  153.     'null
  154.     (mapcar '(lambda (x)
  155.          (if (equal ptn x 1e-6)
  156.      nil
  157.      x
  158.          )
  159.        )
  160.       ptxlst
  161.     )
  162.   )
  163. )
发表于 2025-6-19 09:51:35 | 显示全部楼层
最简单的方法是  直接外面画个矩形   然后用bpoly 命令  就可生成 线的轮廓了
发表于 2025-6-13 06:26:17 | 显示全部楼层
不封闭的多段线,按封闭计算,逻辑有问题。
 楼主| 发表于 2025-6-13 07:41:00 来自手机 | 显示全部楼层
对就是按封闭的算的
发表于 2025-6-18 12:52:55 | 显示全部楼层
  1. (defun c:tt ()
  2.   "相交多段线外轮廓"
  3.   (if (and (setq s1 (car (entsel "\n选择多段线<退出>: ")))
  4.            (xyp-Etype s1 "*polyline")
  5.            (xyp-Self-Intersect s1)
  6.       )
  7.     (progn
  8.       (xyp-MkLaCo "外轮廓" 6)
  9.       (setq s2 (xyp-Line (vlax-curve-getStartPoint s1)(vlax-curve-getEndPoint s1)))
  10.       (xyp-Get-Bpoly (xyp-List2ss (list s1 s2)))
  11.       (entdel s2)
  12.     )
  13.   )
  14.   (princ)
  15. )
发表于 2025-6-19 11:57:23 | 显示全部楼层
挺好的方法。
GMT+8, 2025-7-14 16:43 , Processed in 0.176604 second(s), 26 queries , Gzip On.
