- 积分
- 13544
- 明经币
- 个
- 注册时间
- 2018-8-12
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2025-7-7 13:34:13
显示全部楼层
(defun c:cc (/ *error* ent lastEnt basePt nextPt dist ang ss userError)
(princ "动态多重复制\n")
(defun *error* (msg)
(command ".UNDO" "E")
(setvar "osmode" oldSnap);;这里的oldSnap改成0,或者这行都删掉
(setq *error* userError))
(setq oldSnap (getvar "osmode")
userError *error*
*error* *error*
cmdEcho (getvar "cmdecho"))
(setvar "cmdecho" 0)
(if (and (setq ss (ssget))
(setq basePt (getpoint "\n指定基点: ")))
(command ".UNDO" "BE")
(setq dist nil ang 0)
(while (princ "\n指定下一点或距离: ")
(if dist (princ (strcat "<" (rtos dist) ">: ")))
(setq lastEnt (entlast))
(command ".copy" ss "" basePt pause)
(setq nextPt (getvar "lastpoint"))
(command ".erase" (ssdelDraft lastEnt) "")
(if (equal basePt nextPt 1e-8)
(setq nextPt (polar basePt ang dist))
(setq dist (distance basePt nextPt)
ang (angle basePt nextPt)))
(command ".copy" ss "" basePt nextPt)
(setq ss (ssdelDraft lastEnt)
basePt nextPt))
(command ".UNDO" "E")))
(princ))
(defun ssdelDraft (ent / ss entData)
(setq ss (ssadd))
(while (setq ent (entnext ent))
(setq entData (entget ent))
(if (not (wcmatch (cdr (assoc 0 entData)) "ATTRIB,VERTEX,SEQEND"))
(ssadd ent ss)))ss)
请问是否这样修改
以下修改是完全没有捕捉设置,复制对象捕捉不到点,已经失去功能的意义
(defun c:cc (/ *error* ent lastEnt basePt nextPt dist ang ss userError oldSnap)
(princ "动态多重复制\n")
(if oldSnap (setvar "osmode" oldSnap)) ; 确保恢复捕捉设置
(princ))
(setq userError *error*
(setvar "osmode" 0) ; 关键修改:关闭对象捕捉
basePt nextPt))
(setvar "osmode" oldSnap) ; 恢复原始捕捉设置
(princ))
(setq ss (ssadd))
(ssadd ent ss)))ss)
