查看: 1320|回复: 21
[源码] 哪位有支持中望cad自动加载LSP、dll文件的源码吗?
发表于 2025-7-21 18:03:21 | 显示全部楼层 |阅读模式
群里有很多ACAD自动加载lsp、dll并自动加入自启动的程序,但是找了一圈没有支持中望cad自动加载LSP、dll这些文件并加入自启动的源码。下面这个源码我改了很久,就是不行,有哪位大神能帮帮忙吗?
                  子函数
;功能描述:自动加载kk-Autoload.lsp 所处文件夹下的文件及其子文件夹下的文件。支持lsp、vlx、fas、arx、dll(netload方式加载)。
;功能:拖拽文件进入cad中,返回拖拽的文件路径
(defun kk-getdragpath (/ str_path n1 n2)
  (while (/= 0 (getvar "cmdactive")) (command))
  (princ "\n")
  (setq str_path (getvar "lastprompt"))
  (setq n1 (vl-string-search "(LOAD \"" str_path))
  (if (/= nil n1)
      (setq n2 (vl-string-search "\")" str_path)
            str_path (substr str_path (+ n1 8) (- n2 n1 7))
            str_path (vl-filename-directory str_path)
    nil
;功能:返回表中缺失的文字标签(tag)
(defun kk-strtag (int_i int_pat str_para list_para / list_r i temp_str)
  (setq i int_i)
  (repeat (length list_para)
    (if (= int_pat 0)
      (setq temp_str (strcat (itoa i) str_para))
      (setq temp_str (strcat str_para (itoa i)))
    (if (not (member temp_str list_para))
      (setq list_r (cons temp_str list_r))
    (setq i (1+ i))
  (reverse list_r)
;功能:文件添加至AutoCAD启动组
(defun kk-file2startup (str_file / str_startup str_appload list_regvalue x bool_temp)
  (setq str_startup (strcat
                      "HKEY_CURRENT_USER\\"
                      (vlax-product-key)
                      "\\Profiles\\"
                      (vla-get-activeprofile
                        (vla-get-profiles (vla-get-preferences (vlax-get-acad-object)))
                      "\\Dialogs\\Appload\\Startup"
  (setq str_appload (strcat
                      (vlax-product-key)
                      "\\Applications\\AcadAppload"
  (setq list_regvalue (vl-registry-descendents str_startup ""))
  ; 检查是否已存在
  (cond
    ((= list_regvalue nil) (= nil bool_temp))
    ((/= list_regvalue nil)
     (foreach x list_regvalue
       (if (= (strcase str_file) (strcase (vl-registry-read str_startup x)))
         (setq bool_temp t)
  ; 添加到启动组
  (cond
    ((= nil bool_temp)
     (vl-registry-write
       str_startup
       "NumStartup"
       (vl-princ-to-string
         (1+ (read (vl-registry-read str_startup "NumStartup")))
     (vl-registry-write
       str_startup
       (car (kk-strtag 1 0 "Startup" list_regvalue))
       str_file
     (vl-registry-write str_appload "LOADCTRLS" 15)
;功能:获取路径下的文件夹及子文件夹
(defun kk-getFolds (str_path int_pat / list_fold)
  (defun _temp_getsonFold (sonpath)
    (setq list_fold (cons sonpath list_fold))
    (foreach x (cddr (vl-directory-files sonpath nil -1))
      (_temp_getsonFold (strcat sonpath "\\" x))
  (cond
    ((= 0 int_pat)
     (if (findfile str_path)
         (setq list_fold (cons str_path list_fold))
         (foreach x (cddr (vl-directory-files str_path nil -1))
           (setq list_fold (cons (strcat str_path "\\" x) list_fold))
    ((= 1 int_pat) (if (findfile str_path) (_temp_getsonFold str_path)))
  (cdr (reverse list_fold))
;功能:获取路径下的文件
(defun kk-getfiles (str_path str_pat int_pat / list_folds x y list_filename list_file)
  (cond
    ((= 0 int_pat) (setq list_folds (cons str_path list_folds)))
    ((= 1 int_pat) (setq list_folds (cons str_path (kk-getFolds str_path 1))))
  (foreach x list_folds
    (setq list_filename (vl-directory-files x str_pat 1))
    (if (/= list_filename nil)
      (foreach y list_filename
        (setq list_file (cons (strcat x "\\" y) list_file))
  (reverse list_file)
;功能:加载文件列表
(defun kk-loadfile (list_files int_debug / i inf x tempstr)
  (setq i 0)
  (foreach x list_files
    (setq tempstr (strcase x))
    (setq inf nil)
    (cond
      ((or
         (vl-string-search ".VLX" tempstr)
         (vl-string-search ".FAS" tempstr)
         (vl-string-search ".LSP" tempstr)
       (setq inf (vl-catch-all-apply 'load (list x)))
      ((vl-string-search ".DLL" tempstr)
       (vl-cmdf "netload" x)
      ((or
         (vl-string-search ".ARX" tempstr)
         (vl-string-search ".DVB" tempstr)
         (vl-string-search ".DBX" tempstr)
       (setq inf (vl-catch-all-apply 'arxload (list x)))
    (if (and (vl-catch-all-error-p inf) (= 1 int_debug))
        (setq i (1+ i))
        (princ
          (strcat "\n("
                  (itoa i)
                  " 的加载error反馈:"
                  (vl-catch-all-error-message inf)
;功能:字符串替换
(defun kk-strreplace (str_new str_old str_father / i)
  (setq i 0)
  (while (vl-string-search str_old str_father i)
    (setq str_father (vl-string-subst str_new str_old str_father i))
    (setq i (+ i 1 (strlen str_new) (- (strlen str_old))))
  str_father
                  主函数
;全局变量
(vl-bb-set
  'regpath_startup
  (strcat "HKEY_CURRENT_USER\\"
          (vlax-product-key)
          "\\Profiles\\"
            (vla-get-profiles
(vl-bb-set
  'regpath_appload
  (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Applications\\AcadAppload")
(vl-bb-set 'regpaht_autoload "HKEY_CURRENT_USER\\Autoloadpath\\Paths")
(vl-bb-set 'regpaht_autoload_debug "HKEY_CURRENT_USER\\Autoloadpath\\Debug")
(vl-bb-set 'str_autoload_filename "拖入CAD绘图界面加载 自动批量自启动加载.lsp")
;主程序入口
(defun kk-autoload (/ int_oldsl str_name1 x list_reg_valuename list_files)
  (setvar "cmdecho" 0)
  ;/// 新增:判断是否为ZWCAD,跳过secureload设置 ///
  (if (not (wcmatch (strcase (getvar "PROGRAM")) "*ZWCAD*"))
    (setvar "secureload" 0)
  (setq str_name1 (kk-getdragpath))
  (cond
    ((/= str_name1 nil)
     (setq str_name1 (kk-strreplace "\\" "/" (kk-getdragpath)))
     (kk-file2startup (strcat str_name1 "\\" (vl-bb-ref 'str_autoload_filename)))
    ((= str_name1 nil)
     (setq list_reg_valuename (vl-registry-descendents
                                (vl-bb-ref 'regpath_startup)
     (foreach x list_reg_valuename
       (setq list_reg_valuedata (vl-registry-read (vl-bb-ref 'regpath_startup) x))
       (if (vl-string-search (vl-bb-ref 'str_autoload_filename) list_reg_valuedata)
         (setq str_name1 (vl-string-subst ""
                                          (strcat "\\"
                                          list_reg_valuedata
  (setq list_files (kk-getfiles str_name1 "*.*" 0))
  (setq list_files (vl-remove
                     list_files
  (if (/= nil list_files) (kk-loadfile list_files 0))
;加载主程序
(kk-autoload)
(print "工具箱加载成功!")
 楼主| 发表于 2025-7-25 09:49:08 | 显示全部楼层
寒潮大冬瓜 发表于 2025-7-25 08:47
自动加入启动组的代码我自己在中望里还没实现!按照测试提示,主要是注册表路径方面的问题……工作中!以 ...
我研究了一下,启动组注册表添加成功,但第二次启动自动删除,不知道什么原因。而且启动组注册表添加成功,但是软件的启动组面板看不到条目,应该哪里还有一步没搞对。
发表于 2025-7-24 21:42:18 | 显示全部楼层
寒潮大冬瓜 发表于 2025-7-23 21:07
(load "C:\\XCAD\\自动加载文件夹中的lsp-fas-vlx-vls文件.lsp")
请拼音输入法帮忙就行!
把‘jiazai’ ...
加載後..還要自動執行命令.
发表于 2025-7-23 21:07:13 | 显示全部楼层
szhorse 发表于 2025-7-23 20:35
能搞成输入命令的时候才加载就爽了
请拼音输入法帮忙就行!
把‘jiazai’拼音定义为词语!
;Y223***
(DEFUN C:Y223()
(princ))
发表于 2025-7-23 12:01:13 | 显示全部楼层
菜鸟初来乍到 发表于 2025-7-23 10:09
大佬,请教一下,我这个好像自动加载很多次,这是为啥呢?好卡好卡
你把下载的这个文档也放进拟加载的文件夹了吧?那就是死循环哟!
菜鸟初来乍到 + 1 很给力!
发表于 2025-7-21 18:34:01 | 显示全部楼层
顶起来,期待大佬出手解决
发表于 2025-7-21 22:21:13 | 显示全部楼层
菜鸟初来乍到 发表于 2025-7-21 18:34
顶起来,期待大佬出手解决
直接问中望客服,会很快解决你的问题。
菜鸟初来乍到 + 1 很给力!
发表于 2025-7-21 23:04:21 | 显示全部楼层
检查当前OSMODE值如不是15871则将其重置为15871重置对象捕捉模式(OSMODE)为锁定值(...
http://bbs.mjtd.com/plugin.php?i ... DE4NjMxfDE5MzAyMw==
我在这个地址下载的一个文件能把文件夹内的文件都加载了!
自动加载文件夹中的lsp-fas-vlx-VLS文件
修改这句代码:(load_Folder_app "C:\\XCAD\\0JIAZAI"),为自己的需要加载的代码保存路径就行了!兼容中望cad!
另外注意:这个“自动加载文件夹中的lsp-fas-vlx-VLS文件”不能放在拟加载的文件夹里哟!否则会出现死循环现象!
检查当前OSMODE值如不是15871则将其重置为15871重置对象捕捉模式(OSMODE)为锁定值(除最近点以外的捕捉)
此代码放入自动加载文件夹中,效果杠杠的!
菜鸟初来乍到 + 1 很给力!
 楼主| 发表于 2025-7-22 08:14:41 | 显示全部楼层
寒潮大冬瓜 发表于 2025-7-21 23:04
http://bbs.mjtd.com/plugin.php?id=imc_attachplug:attachdown&aid=MTQzMzE3fDM1MDIzNzI5fDE3NTA2NjMzNzR8 ...
在中望能运行吗?
发表于 2025-7-22 08:42:40 | 显示全部楼层
437271963 发表于 2025-7-21 22:21
直接问中望客服,会很快解决你的问题。
好的,感谢大佬的回答
发表于 2025-7-22 09:36:00 来自手机 | 显示全部楼层
中望CAD启动组放一个lisp子文件,然后此lisp加载其他孙文件
发表于 2025-7-22 10:01:30 | 显示全部楼层
这个方法是可行的,我就是按照这个方法做的:
  1. ;; 定义一个函数,用于加载DLL文件。
  2. (defun load-dll ()
  3.   (setq lsp-file-path (findfile "LittleBirdToolBox.ZWCAD.Net.dll")) ; DLL文件名
  4.   (if lsp-file-path
  5.     (progn
  6.       (setq lsp-file-dir (substr lsp-file-path 1 (- (strlen lsp-file-path) (strlen "LittleBirdToolBox.ZWCAD.Net.dll"))))
  7.       (setq full-dll-path (strcat lsp-file-dir "LittleBirdToolBox.ZWCAD.Net.dll")) ;DLL文件名的完整路径。
  8.       (princ "\n")
  9.       (command "netload" full-dll-path)
  10.     )
  11.     (princ "\n未找到DLL文件。")
  12.   )
  13. )
  14. ;; 调用函数加载DLL
  15. (load-dll)
  16. ;;定义一个打开工具箱的命令。
  17. (princ "欢迎使用小鸟工具箱!!输入“xx”命令加载工具箱!")
  18. (defun c:xx()
  19. (setvar "cmdecho" 0)
  20. (command "littlebirdbox")
  21. (setvar "cmdecho" 1)
  22. (princ)
  23. )
 楼主| 发表于 2025-7-22 11:06:03 | 显示全部楼层
那lisp文件怎么自动加入到启动组呢?
发表于 2025-7-22 11:07:40 | 显示全部楼层
lxl304712346 发表于 2025-7-22 11:06
那lisp文件怎么自动加入到启动组呢?
手动添加。
GMT+8, 2025-8-12 04:17 , Processed in 0.196320 second(s), 28 queries , Gzip On.
