查看: 1140|回复: 10
求助:把图案填充编辑中把透明度指定值改为80
发表于 2025-7-23 17:16:45 | 显示全部楼层 |阅读模式
(defun c:HM (/ *error* acadDoc ms pts nextpt pline hatch obj area len txt ins th
                acadVer hasTransparency mtextObj finalPline finalHatch)
  (vl-load-com)
  ;; 定义AutoCAD常量
  (if (not (boundp 'acHatchPatternTypePredefined))
    (setq acHatchPatternTypePredefined 0))
  ;; 检查AutoCAD版本是否支持透明度属性
  (setq acadVer (atoi (getvar "ACADVER")))
  (setq hasTransparency (>= acadVer 18)) ; 2010及以上版本支持
  ;; ---------- 错误处理 ----------
  (defun *error* (msg)
    (if (and msg (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")))
      (princ (strcat "\n错误: " msg)))
    ;; 只清理临时对象,保留最终对象
    (if (and pline (not (eq pline finalPline)))
      (vla-delete (vlax-ename->vla-object pline)))
    (if (and hatch (not (eq hatch finalHatch)))
      (vla-delete hatch))
    (princ))
  ;; ---------- 初始化 ----------
  (setq acadDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (setq ms      (vla-get-ModelSpace acadDoc))
  (setq pts     nil
        pline   nil
        hatch   nil
        finalPline nil
        finalHatch nil)
  ;; ---------- 主循环:实时绘制 ----------
  (while
    (setq nextpt
      (if pts
        (getpoint (last pts) "\n下一点(回车结束): ")
        (getpoint "\n起点: ")))
    (setq pts (append pts (list nextpt)))
    ;; 删除临时对象(保留最终对象)
      (vla-delete hatch))
    ;; 创建新的闭合多段线
    (setq pline
      (entmakex
        (append
          (list
            '(0 . "LWPOLYLINE")
            '(100 . "AcDbEntity")
            '(100 . "AcDbPolyline")
            (cons 90 (length pts))
            '(70 . 1)                 ; 闭合
            '(40 . 0.0)               ; 线宽
            '(62 . 1)                 ; 颜色设为红色,确保可见
          (mapcar '(lambda (p) (cons 10 p)) pts))))
    ;; 若点数≥3,立即生成填充
    (if (and pline (>= (length pts) 3))
        (setq hatch
          (vla-AddHatch ms
                        "SOLID"
                        :vlax-true))
        ;; 设置填充为颜色252(浅黄)
        (vla-put-Color hatch 251)
        ;; 设置透明度为80(仅支持版本)
        (if hasTransparency
          (vl-catch-all-apply
            '(lambda ()
               (vla-put-Transparency hatch 80)
        (vla-AppendOuterLoop
          hatch
          (vlax-make-variant
            (vlax-safearray-fill
              (vlax-make-safearray vlax-vbObject '(0 . 0))
              (list (vlax-ename->vla-object pline)))))
        (vla-Evaluate hatch))))
  ;; ---------- 保存最终对象引用 ----------
  (setq finalPline pline)
  (setq finalHatch hatch)
  ;; ---------- 结束:标注面积/周长 ----------
  (if (and finalPline (>= (length pts) 3))
      (setq obj  (vlax-ename->vla-object finalPline))
      (setq area (/ (vlax-get-property obj 'Area) 1e6))   ; mm² → m²
      (setq len  (/ (vlax-get-property obj 'Length) 1e3)) ; mm  → m
      (setq txt  (strcat "面积=" (rtos area 2 3) "m²"
                         "/周长=" (rtos len  2 3) "m"))
      (if (setq ins (getpoint "\n标注位置: "))
          (initget 6)
          (setq th (getreal "\n文字高度<100>: "))
          (if (not th) (setq th 100.0))
          ;; 创建标注文字
          (setq mtextObj
            (vla-AddMText ms
                          (vlax-3d-point ins)
                          0.0  ; 宽度
                          txt))
          ;; 设置文字属性
          (vla-put-Height mtextObj th)
          (vla-put-AttachmentPoint mtextObj 1)  ; 居中对齐
          (vla-put-HorizontalAlignment mtextObj 1)
          (princ "\n图形、填充和标注已全部创建完成。"))
        (princ "\n未指定标注位置,仅保留图形和填充。")))
    (princ "\n未形成闭合区域,已取消。"))
    修改:        ;; 设置透明度为80(仅支持版本)
        (if hasTransparency
          (vl-catch-all-apply
            '(lambda ()
修改:这设置透明度为80没起作用(CAD2025,图案填充编辑中把透明度指定值改为80)求老师修改一下,我在AI中修改总是不行。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
发表于 2025-7-24 17:40:06 | 显示全部楼层
ketxu 发表于 2025-7-24 11:45
您可以将(列表 (cons 440 33554495))附加到实体数据中,以将填充线透明度设置为 80 :)
不同原始颜色,不同透明度的440数值是不一样的。只有提前预知,才能直接用440
发表于 2025-7-23 21:10:41 | 显示全部楼层
不能用vla-put改透明度,需要用(setpropertyvalue obj "Transparency" val)
yanshengjiang + 1
 楼主| 发表于 2025-7-24 08:56:08 | 显示全部楼层
谢谢,老师牛,OK了
发表于 2025-7-24 09:59:22 | 显示全部楼层
用 change 命令更改属性就可以了。
(command "change" (car (entsel)) "" "P" "TR" 80 "")(princ)
发表于 2025-7-24 11:45:18 | 显示全部楼层
发表于 2025-7-24 12:58:14 | 显示全部楼层
大佬,打印照片设置成透明度打印,图片为什么是倾斜拉伸变形的?
发表于 2025-7-24 21:31:00 | 显示全部楼层
看你们好多用lisp,目前只会arx,lisp有必要学吗?
发表于 2025-7-25 14:39:30 | 显示全部楼层
lisp能干的arx都能干,只要没有嫌分发ARX麻烦的,还是保持ARX更好。
发表于 2025-7-25 21:33:50 | 显示全部楼层
谢谢大佬,感觉,现在用c#的挺活跃的
GMT+8, 2025-11-26 18:41 , Processed in 0.230997 second(s), 28 queries , Gzip On.
