查看: 189|回复: 2
【K:SendToBack】块内目标对象置底
发表于 昨天 14:45 | 显示全部楼层 |阅读模式
源码来自Lee mac,仅做一些小修改
用法:
  1. ;填充和区域覆盖置底
  2. (K:SendToBack BlkNam (list "AcDbHatch" "AcDbWipeout"))
  1. (defun K:SendToBack (BlkNam TypNam / LM:SortentsTable obj objLst)
  2.     ;重新排序的空间
  3.     (defun LM:SortentsTable (space / dict result)
  4.       (cond
  5.         ((not
  6.           (vl-catch-all-error-p
  7.             (setq result (vl-catch-all-apply
  8.                             'vla-item
  9.                             (list (setq dict (vla-GetExtensionDictionary space)) "ACAD_SORTENTS")
  10.                           )
  11.             )
  12.           )
  13.         )
  14.         result
  15.         )
  16.         ((vla-AddObject dict "ACAD_SORTENTS" "AcDbSortentsTable"))
  17.       )
  18.     )
  19.     (vlax-for obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) BlkNam)
  20.         (if (member (vla-get-objectname obj) TypNam)
  21.             (setq objLst (cons obj objLst))
  22.         )
  23.     );收集目标对象
  24.     (if objLst
  25.         (vla-movetobottom
  26.           (LM:SortentsTable (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) BlkNam))
  27.           (vlax-make-variant
  28.             (vlax-safearray-fill
  29.                 (vlax-make-safearray vlax-vbobject (cons 0 (1- (length objLst))))
  30.                 objLst
  31.             )
  32.           )
  33.       )
  34.     );置底
  35. )
hi7720 + 1 赞一个!
发表于 昨天 15:05 | 显示全部楼层
感谢大嘴巴苦茶大神
 楼主| 发表于 昨天 15:46 | 显示全部楼层
czb203 发表于 2025-8-11 15:05
感谢大嘴巴苦茶大神
GMT+8, 2025-8-12 09:34 , Processed in 0.171479 second(s), 24 queries , Gzip On.
