查看: 888|回复: 2
[提问] 请帮助,改为批量框选
发表于 2025-8-11 18:58:16 | 显示全部楼层 |阅读模式
5明经币
(defun c:ht (/ ent ht)
   (setq ent (car (entsel "\n选择多行文字: ")))
    (setq ht (cdr (assoc 40 (entget ent))))
    (entmod (append (entget ent) (list (cons 41 (* ht 20.0)) (cons 46 (* ht 10.0)))))
最佳答案
查看完整内容
(defun c:ht (/ ss i ent entdata ht) (setq ss (ssget '((0 . "MTEXT")))) ; 选择多个多行文字对象 (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq entdata (entget ent)) (setq ht (cdr (assoc 40 entdata))) ; 获取文字高度 ; 更新宽度(41)和行距(46),并确保行距类型为精确距离(73=2) (entmod (subst (cons 41 ...
发表于 2025-8-11 18:58:17 | 显示全部楼层
  (if ss
      (setq i 0)
        (entmod (subst (cons 41 (* ht 20.0)) ; 宽度=高度×20
                      (assoc 41 entdata)
                      (subst (cons 46 (* ht 10.0)) ; 行距=高度×10
                             (assoc 46 entdata)
                             (subst (cons 73 2) ; 设置精确行距类型
                                    (assoc 73 entdata)
                                    entdata))))
        (setq i (1+ i))
      (princ (strcat "\n成功修改 " (itoa (sslength ss)) " 个文字对象"))
    (princ "\n未选择对象")
发表于 2025-8-11 19:46:31 | 显示全部楼层
  1. (defun c:11 (/ ss ent ht)
  2. (setq ss (ssget '((0 . "MTEXT"))))
  3.   (if ss
  4.   (repeat (setq i (sslength ss))
  5.      (setq ent (ssname ss (setq i (1- i))))
  6.     (setq ht (cdr (assoc 40 (entget ent))))
  7.     (entmod (append (entget ent) (list (cons 41 (* ht 20.0)) (cons 46 (* ht 10.0)))))
  8. )
  9. )
  10. (princ))
wgij007 + 1 很给力!
GMT+8, 2025-12-12 07:53 , Processed in 0.148085 second(s), 26 queries , Gzip On.
