查看: 3392|回复: 34
修改版-快速拉线标注--带捕捉-免费等高手解决
发表于 2025-9-7 13:04:45 | 显示全部楼层 |阅读模式
修改版,取消S设置逻辑,增加总尺,但是总标尺有问题,等高手解决,另外想增加一个识别折线忽略折线进行标尺,柜体标尺是没有问题的,测试平台AutoCAD 2007,其他版本也可以试试,适合这2年的全屋定制,命令:DDF
源码:
说明-有问题存在,等高手解决
演示操作
1028695446原版在这里:http://bbs.mjtd.com/forum.php?mod=viewthread&tid=180410&highlight=%BF%EC%CB%D9%C0%AD%CF%DF%B1%EA%D7%A2
花了不少时间修改好了-展示一下
; DDF标注命令 - 修正横向标尺位置,仅显示标尺无文字
(defun c:DDF (/ pt1 pt2 ss intlist lds olden pts1 pts2 n ens code i ptx endata dist
                total-dist total-pt1 total-pt2 dir-ang offset-dist total-dim-obj
                base-dim-pt orig-offset-ang orig-offset-dist)
    ; 配置参数
    (setq filter-sizes (vl-sort '( 0 36 1) '<)
          tolerance 0.01
          offset-dist 120)  ; 固定距离120mm
    ; 获取标注起始点
    (setq pt1 (getpoint "\n指定标注起始点: "))
    (if (null pt1) (progn (princ "\n命令取消") (return)))
    ; 获取标注方向点
    (setq pt2 (getpoint pt1 "\n指定标注方向: "))
    (if (null pt2) (progn (princ "\n命令取消") (return)))
    ; 选择过滤实体
    (if (setq ss (ssget "F" (list pt1 pt2) '((0 . "*E,CIRCLE,ARC")(6 . "BYLAYER"))))
            (setq intlist nil
                  endata (ssnamex ss))
            ; 提取并净化交点列表(去重)
            (foreach x endata
                (foreach y (cdddr x)
                    (setq pt (cadr y))
                    (if (not (vl-some '(lambda (p) (equal p pt tolerance)) intlist))
                        (setq intlist (cons pt intlist))
            ; 过滤并排序点
            (setq lds (+ 10 (distance pt1 pt2))
                  intlist (vl-remove-if-not
                            '(lambda (x) (<= (distance x pt1) lds))
                            intlist)
                  intlist (vl-sort
                            intlist
                            '(lambda (x y) (< (distance pt1 x) (distance pt1 y)))))
            (if (< (length intlist) 2)
                (progn (princ "\n有效交点不足,无法标注") (return))
            ; 创建普通标注(无文字)
            (setq olden (entlast)
                  ss (ssadd))
            (setq n 0)
            (repeat (- (length intlist) 1)
                (setq pts1 (nth n intlist)
                      pts2 (nth (1+ n) intlist)
                      dist (distance pts1 pts2))
                ; 过滤标注逻辑
                (if (and (> dist tolerance)
                         (not (vl-some
                                '(lambda (s)
                                    (and (>= dist (- s tolerance))
                                         (<= dist (+ s tolerance))))
                                filter-sizes)))
                    (ddf_entmakedim pts1 pts2)  ; 调用无文字标注函数
                (setq n (1+ n))
            ; 收集普通标注并记录基准点
            (while (setq ens (entnext olden))
                (setq ss (ssadd ens ss)
                      olden ens)
            (if (> (sslength ss) 0)
                (setq base-dim-pt (cdr (assoc 10 (entget (ssname ss 0)))))
                (setq base-dim-pt (midpoint pt1 pt2))  ;  fallback基准点
            ; -------------------- 总长标注逻辑 --------------------
            ; 计算总长参数
            (setq total-pt1 (car intlist)
                  total-pt2 (last intlist)
                  total-dist (distance total-pt1 total-pt2)
                  dir-ang (angle total-pt1 total-pt2))  ; 标注方向角度
            ; 修正横向标注偏移方向(解决上移问题)
            ; 横向(水平)标注时强制向下偏移,其他方向按原逻辑
            (setq orig-offset-ang
                (if (or (equal dir-ang 0 0.001) (equal dir-ang pi 0.001))  ; 水平方向判断
                    (+ dir-ang (/ pi 1.5))  ; 横向向下偏移(避免上移)
                    (+ dir-ang (/ pi 2))    ; 其他方向正常外侧偏移
                orig-offset-dist offset-dist
            ; 初始位置:基于原标注基准点偏移120mm
            (setq total-dim-pt (polar base-dim-pt orig-offset-ang orig-offset-dist))
            ; 创建总长标注(无任何文字,仅标尺)
            (entmake
                (list
                    '(0 . "DIMENSION")
                    '(100 . "AcDbEntity")
                    '(100 . "AcDbDimension")
                    (cons 10 total-dim-pt)
                    '(70 . 32)
                    '(1 . "")  ; 空文字
                    '(100 . "AcDbAlignedDimension")
                    (cons 13 total-pt1)
                    (cons 14 total-pt2)
                    '(100 . "AcDbRotatedDimension")
            (setq total-dim-obj (entlast))
            ; 拖动逻辑:保持总长与原标注120mm距离
            (while (and (setq code (grread T 8))
                        (/= 11 (car code))
                        (/= 25 (car code))
                        (/= 3 (car code))
                        (= 5 (car code)))
                (redraw)
                (setq ptx (cadr code)
                      i 0)
                ; 1. 移动原标注到新位置
                (repeat (sslength ss)
                    (setq endata (entget (ssname ss i)))
                    (entmod (subst (cons 10 ptx) (assoc 10 endata) endata))
                    (setq i (1+ i))
                ; 2. 计算总长标注新位置(保持偏移关系)
                (setq new-total-pt (polar ptx orig-offset-ang orig-offset-dist)
                      total-endata (entget total-dim-obj))
                ; 3. 移动总长标注
                (entmod (subst (cons 10 new-total-pt) (assoc 10 total-endata) total-endata))
        (princ "\n未找到符合条件的实体")
    (princ "\n标注完成(横向标尺已修正,无文字)")
    (prin1)
; 辅助函数:计算两点中点
(defun midpoint (p1 p2)
    (list (/ (+ (car p1) (car p2)) 2.0)
          (/ (+ (cadr p1) (cadr p2)) 2.0)
          0.0)
; 创建标注实体的函数(无文字版本)
(defun ddf_entmakedim (pt1 pt2 / ang)
    (setq ang (angle pt1 pt2))
    (cond
        ((or (equal 0 ang 0.001) (equal pi ang 0.001))  ; 水平
            (entmake
                (list
                    '(0 . "DIMENSION")
                    (cons 10 pt1)
                    '(70 . 32)
                    '(1 . "")  ; 空文字
                    (cons 13 pt1)
                    (cons 14 pt2)
        ((or (equal (/ pi 2) ang 0.001) (equal (* pi 1.5) ang 0.001))  ; 垂直
            (entmake
                (list
                    '(0 . "DIMENSION")
                    (cons 10 pt1)
                    '(70 . 33)
                    '(1 . "")  ; 空文字
                    (cons 13 pt1)
                    (cons 14 pt2)
        (T  ; 其他角度
            (entmake
                (list
                    '(0 . "DIMENSION")
                    (cons 10 pt1)
                    '(70 . 33)
                    '(1 . "")  ; 空文字
                    (cons 13 pt1)
                    (cons 14 pt2)
(princ "\nDDF标注命令加载完成,输入DDF启动(横向修正版)")
(prin1)
很给力  发表于 2025-9-8 10:12
1028695446 + 1 很给力!
发表于 2025-9-7 21:58:02 | 显示全部楼层
很强大的批量标注,可以适用于家具,室内设计  建筑设计标注,方便施工使用,感谢分享!
发表于 2025-9-8 22:31:57 | 显示全部楼层
楼主有心了
在下也改进了拉线标注,初衷只是想用在布局空间,(在布局里标注的网友不怎么多,布局里标注会因为线性测量比例的问题而出错...),功能:仅使用一个标注样式--拖动定点--定的第三点为尺寸偏移点(而不是尺寸线的位置点)--增加总标--自动识别视口比例--自动赋于线性测量比例和全局标注比例--尺寸避让等等;
后来越改进适用范围就越多一些,不局限于布局空间,扩展到布局里的模型空间(浮动空间),实现在模型空间、布局空间、布局里的模型空间都能标;
随着不断的测试,发现只能在WCS坐标系下标注,感觉不爽。又扩展了在UCS坐标系下也能标注,关于坐标的空间转换,一个头两个大,只学了前辈们的皮毛。
尺寸标注的角度,学院长用了50组码,省去分析各种角度条件。
测试中,也遇到跟楼主一样的问题,交点有时会莫名的分段,是不是ssget "F"获取交点本身就有待完善
有时还有尺寸没有拖动效果
发表于 2025-9-15 23:18:13 | 显示全部楼层
似乎, 还得继续改改...
 楼主| 发表于 2025-9-24 15:03:03 | 显示全部楼层
dingtiedt 发表于 2025-9-8 22:31
楼主有心了!
在下也改进了拉线标注,初衷只是想用在布局空间,(在布局里标注的网友不怎么多,布局 ...
(setq filter-sizes (vl-sort '( 0 36 1) '<)        这段修改你需要过滤的尺寸,这里比如是0,36,1,颜色过滤没写在里面,可以自己增加过滤颜色的语句,另外就是捕捉方向有问题,还有总尺寸是不能拉伸变尺,我在模型空间测试的,布局里没有试过,先把这几个问题解决掉就会很好用加油
&#65532; 管理
点评回复 编辑支持 反对使用道具 评分
  123&#65532; / 3 页下一页返回列表&#65532;&#65532;
&#65532;
 楼主| 发表于 2025-9-24 15:11:17 | 显示全部楼层
22693766 发表于 2025-9-15 23:18
似乎, 还得继续改改...
是的是的,这个版本需要优化,源码嘛,只是给一个你想要的开头,最后需要达到一个什么效果,需要自己去添加修改
发表于 2025-9-9 09:55:02 | 显示全部楼层
我可以把我修改的发你这里不~
回复 支持 2 反对 0
发表于 2025-9-10 01:19:39 | 显示全部楼层
一直想回复这个拉线标注,就是不知说个明白:
拉线标注啊,确实不错,重要的是它里面的两个标注函数。而不是拉线本身。
为什么要拉线?这是画图的习惯吗?应该是选择线类实体吗,不拉线,这不是常规的画法,
如果大家要这么画图,拉线?这个操作是你特有的特例,对不对,
应该不拉线,选实体,这个解决了,才是最终归途。。。。
对了,我开发的 SLdesign (三领设计)早已解决了这个问题。
发表于 2025-9-7 13:38:45 | 显示全部楼层
太酷了 很好用
发表于 2025-9-7 14:33:39 | 显示全部楼层
感谢楼主分享!!
发表于 2025-9-7 14:42:46 | 显示全部楼层
多谢分享下来看看
发表于 2025-9-7 15:58:23 | 显示全部楼层
感谢楼主分享!!
发表于 2025-9-7 17:31:24 | 显示全部楼层
又升级了 感谢分享
 楼主| 发表于 2025-9-7 17:49:49 | 显示全部楼层
qifeifei 发表于 2025-9-7 17:31
又升级了 感谢分享
你研究一下,PL画的折线和直线画的斜线能不能过滤掉
发表于 2025-9-7 18:07:06 | 显示全部楼层
花一个币下载试一试
发表于 2025-9-7 20:45:12 | 显示全部楼层
过滤一下颜色就好了呀.
 楼主| 发表于 2025-9-7 21:29:23 | 显示全部楼层
丶俗人 发表于 2025-9-7 20:45
过滤一下颜色就好了呀.
嗯,是的,已经弄好了
GMT+8, 2025-11-26 17:09 , Processed in 0.511082 second(s), 27 queries , Gzip On.
