- 积分
- 27884
- 明经币
- 个
- 注册时间
- 2003-8-26
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
grread对垂足,圆和圆弧的圆心以及切线点的捕捉一直是不太友好
以前发布一版grread捕捉子函数,现在更新一下
可以支持捕捉垂足,圆和圆弧的圆心,切线点了,也支持正交切换
样例中给出了一个简单的使用方法,支持键盘输入数值
有需要grread捕捉的可以拿去用用
;;; grread捕捉子函数(支持捕捉垂足,圆和圆弧的圆心,切线,支持正交)
;;; ss为移动的图元名或选择集,pt为光标点
;;; 返回值:如果有捕捉点则返回捕捉点,无则返回光标点
(defun osnappt (ss pt / color d h i k lst nearpt nearpt2 osmo pt1 pt10 pt11 pt12 pt13 pt2 pt3 pt4 pt5 pt6 pt7 pt8 ptc1 ptc2 ptc3 ptc4
ptc5 ptc6 ptc7 ptc8 ptx pty ss1 x
) ; 捕捉子函数:ss为移动的图元名或选择集,pt为光标点;$pt001有值则捕捉垂足和切线
(if (= (type ss) 'ename)
(entdel ss)
(if (= (type ss) 'pickset)
(repeat (setq i (sslength ss))
(entdel (ssname ss (setq i (1- i))))
(redraw)
(if $pt001
(setvar "lastpoint" $pt001)
(if (= (getvar "ORTHOMODE") 1) ; 区分象限
(cond
((or
(<= (* 0.25 pi) (angle $pt001 pt) (* 0.75 pi))
(<= (* 1.25 pi) (angle $pt001 pt) (* 1.75 pi))
(setq pt (list (car $pt001) (+ (cadr $pt001) (* (distance $pt001 pt) (sin (angle $pt001 pt))))))
(t
(setq pt (list (+ (car $pt001) (* (distance $pt001 pt) (cos (angle $pt001 pt)))) (cadr $pt001)))
(if (< (getvar "osmode") 16384)
(setq color (vla-get-autosnapmarkercolor (vla-get-drafting (vla-get-preferences (vlax-get-acad-object))))
h (/ (getvar "viewsize") (cadr (getvar "screensize")))
d (getvar "pickbox")
lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h))
k (* 1.5 d h)
(if (setq nearpt (osnap pt "_NEA")) ; 接近
(setq osmo 1)
(if (and
(setq nearpt2 (osnap pt "_END,_NOD,_INS,_EXT")) ; 端点
(equal nearpt nearpt2 k)
(setq osmo 2
nearpt nearpt2
(if (and
(setq nearpt2 (osnap pt "_MID")) ; 中点
(setq osmo 3
nearpt nearpt2
(if (and
(setq nearpt2 (osnap pt "_INT")) ; 交点
(setq osmo 4
nearpt nearpt2
(if (and
$pt001
(setq nearpt2 (osnap pt "_PER")) ; 垂足
(setq osmo 5
nearpt nearpt2
(if (and
(setq nearpt2 (osnap pt "_QUA")) ; 象限点
(setq osmo 6
nearpt nearpt2
(if (and
$pt001
(setq nearpt2 (osnap pt "_TAN")) ; 切点
(setq osmo 7
nearpt nearpt2
(if nearpt
(setq ptx (car nearpt)
pty (cadr nearpt)
(foreach x lst
(setq pt1 (list (- ptx x) (- pty x))
pt2 (list (+ ptx x) (- pty x))
pt3 (list (+ ptx x) (+ pty x))
pt4 (list (- ptx x) (+ pty x))
pt5 (list ptx (+ pty x))
pt6 (list ptx (- pty x))
pt7 (list (- ptx x) pty)
pt8 (list (+ ptx x) pty)
pt10 (list (- ptx (* 0.7 x)) (+ pty (* 0.7 x)))
pt11 (list (- ptx (* 0.7 x)) (- pty (* 0.7 x)))
pt12 (list (+ ptx (* 0.7 x)) (- pty (* 0.7 x)))
pt13 (list (+ ptx (* 0.7 x)) (+ pty (* 0.7 x)))
(cond
((= osmo 1) ; 接近画俩三角
(grvecs (list color pt1 pt2 pt2 pt4 pt3 pt4 pt3 pt1))
((= osmo 2) ; 端点画正方形
(grvecs (list color pt1 pt2 pt2 pt3 pt3 pt4 pt4 pt1))
((= osmo 3) ; 中点画三角
(grvecs (list color pt1 pt2 pt2 pt5 pt5 pt1))
((= osmo 4) ; 交点画交叉
(grvecs (list color pt1 pt3 pt2 pt4))
((= osmo 5) ; 垂足画垂足l
(grvecs (list color pt1 pt2 pt1 pt4))
((= osmo 6) ; 象限点画菱形
(grvecs (list color pt5 pt7 pt7 pt6 pt6 pt8 pt8 pt5))
((= osmo 7) ; 切点画圆加横
(grvecs (list color pt5 pt10 pt10 pt7 pt7 pt11 pt11 pt6 pt6 pt12 pt12 pt8 pt8 pt13 pt13 pt5 pt3 pt4))
(if (setq ss1 (ssget "C" nearpt nearpt '((0 . "CIRCLE,ARC")))) ; 如果捕捉到圆或者圆弧,则提取圆心坐标和半径
(setq $yan (list (cdr (assoc 10 (entget (ssname ss1 0)))) (cdr (assoc 40 (entget (ssname ss1 0))))))
(setq pt nearpt)
(if $yan ; $yan为全局变量,用于判断是否找到圆
(if (<= (distance (car $yan) pt) (+ (cadr $yan) k))
(setq ptc1 (list (car (car $yan)) (+ (cadr (car $yan)) k))
ptc2 (list (car (car $yan)) (- (cadr (car $yan)) k))
ptc3 (list (- (car (car $yan)) k) (cadr (car $yan)))
ptc4 (list (+ (car (car $yan)) k) (cadr (car $yan)))
ptc5 (list (- (car (car $yan)) (* 0.7 k)) (+ (cadr (car $yan)) (* 0.7 k)))
ptc6 (list (- (car (car $yan)) (* 0.7 k)) (- (cadr (car $yan)) (* 0.7 k)))
ptc7 (list (+ (car (car $yan)) (* 0.7 k)) (- (cadr (car $yan)) (* 0.7 k)))
ptc8 (list (+ (car (car $yan)) (* 0.7 k)) (+ (cadr (car $yan)) (* 0.7 k)))
(grvecs (list color ptc1 ptc2 ptc3 ptc4)) ; 画圆心十字
(if (<= (distance (car $yan) pt) k) ; 距离接近圆心时,在圆心处画圆
(redraw)
(grvecs (list color ptc1 ptc5 ptc5 ptc3 ptc3 ptc6 ptc6 ptc2 ptc2 ptc7 ptc7 ptc4 ptc4 ptc8 ptc8 ptc1))
(setq pt (car $yan))
(setq $yan nil)
(entdel ss)
pt
;;; 示例:动态画直线
;;; 支持捕捉,支持键盘输入数值,支持f8正交切换
(defun c:aa (/ $pt001 code code1 dis ent gr gr1 loop loop1 lx name pt pt0 r s stl)
(if (setq pt0 (getpoint "\n指定第一个点:"))
(entmake (list '(0 . "LINE") (cons 10 pt0) (cons 11 pt0)))
(setq name (entlast))
(setq ent (entget name))
(setq $pt001 pt0) ; $pt001为初始点坐标,有值时候,捕捉时候能捕捉过这个点的垂足和切线。
(setq loop t) ; $pt001无值则不捕捉垂足和切线。
(while loop
(setq gr (grread t 15 0)
code (car gr)
pt (cadr gr)
(cond
((= code 2) ; 键盘输入
(if (= pt 15) ; f8切换正交
(setvar "ORTHOMODE" 0)
(princ "<正交 关>")
(setvar "ORTHOMODE" 1)
(princ "<正交 开>")
(if (member pt '(48 49 50 51 52 53 54 55 56 57)) ; 键盘输入数字
(setq s (chr pt))
(princ (strcat s))
(setq loop1 t)
(while loop1
(setq gr1 (grread)
code1 (car gr1)
lx (cadr gr1)
(cond
((= code1 2)
(cond
((member lx '(13)) ; 键盘输入数字回车;大于0时候退出所有循环更新图元
(setq loop1 nil)
(if (> (strlen s) 0)
(setq loop nil)
(setq dis (atof s)) ; dis为键盘输入的数值
(entmod (subst
(cons 10 (polar pt0 r dis))
(assoc 10 ent)
ent
((member lx '(46 48 49 50 51 52 53 54 55 56 57 8))
(if (and
(> (setq stl (strlen s))
0
(= lx 8)
) ; 当键盘输入按了退格; 删除一个字符并换行
(setq s (substr s 1 (1- stl)))
(princ (strcat "\n指定下一点,或输入长度:<" (rtos dis 2 2) ">" s))
(if (not (member lx '(8 13 32)))
(setq s (strcat s (chr lx)))
(princ (strcat (chr lx)))
(if (= (strlen s) 0) ; 当键盘输入退格为0时候退出键盘输入循环
(setq loop1 nil)
((member code1 '(3)) ; 键盘输入鼠标左击退出键盘输入循环
(setq loop1 nil)
((member code1 '(11 25)) ; 鼠标右击大于0时候退出所有循环更新图元
(setq loop1 nil)
(setq loop nil)
(setq dis (atof s))
(entmod (subst
(assoc 10 ent)
ent
((= code 3) ; 鼠标左键
(redraw)
(setq loop nil)
(setq pt (osnappt name pt)) ; 调用捕捉子函数
(entmod (subst
(cons 10 pt)
(assoc 10 ent)
ent
((= code 5) ; 鼠标移动
(setq r (angle pt0 pt))
(setq dis (distance pt0 pt)) ; 调用捕捉子函数
(princ (strcat "\n指定下一点,或输入长度:<" (rtos dis 2 2) ">"))
(entmod (subst
(cons 10 pt)
(assoc 10 ent)
ent
((member code '(11 25)) ; 鼠标右击
(redraw)
(entdel name)
(setq loop nil)
