- 积分
- 1281
- 明经币
- 个
- 注册时间
- 2025-8-24
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2025-10-27 23:32:06
显示全部楼层
挺好用的========试着优化了一下
(defun c:FV (/ old_osmode old_cmdecho pt1 pt2 lineA line_angle ss i ent intersections found)
(vl-load-com)
(setq old_osmode (getvar "osmode") old_cmdecho (getvar "cmdecho"))
(setvar "osmode" 0) (setvar "cmdecho" 0)
(setq pt1 (getpoint "\n请指定直线的起点: "))
(if (not pt1) (progn (princ "\n操作已取消。") (exit)))
(setq pt2 (getpoint pt1 "\n请指定直线的终点: "))
(if (not pt2) (progn (princ "\n操作已取消。") (exit)))
; 绘制临时直线A
(setq lineA (entmakex (list (cons 0 "LINE") (cons 10 pt1) (cons 11 pt2))))
(setq line_angle (get_line_angle pt1 pt2))
(princ (strcat "\n线A的角度: " (rtos line_angle 2 2) " 度"))
(setq construction_type (get_construction_type line_angle))
(princ (strcat "\n将绘制 " construction_type " 构造线"))
(princ "\n正在检查与其他线的交叉点...")
(setq ss (ssget "X" '((0 . "LINE,LWPOLYLINE,POLYLINE"))))
(create_construction_layer)
(setq found nil)
(if ss
(setq i 0)
(repeat (sslength ss)
(setq ent (ssname ss i))
(if (not (equal ent lineA))
(setq intersections (get_intersections lineA ent))
(if intersections
(princ (strcat "\n找到交叉点数量: " (itoa (length intersections))))
(setq found T)
(draw_construction_lines intersections construction_type)
(setq i (1+ i))
(princ "\n图中没有其他直线或多段线。")
; 删除临时直线A
(if lineA (entdel lineA))
(if (not found)
(princ "\n没有找到交叉点。")
(princ "\n构造线绘制完成,原始线A已删除。")
; 恢复系统变量
(setvar "osmode" old_osmode) (setvar "cmdecho" old_cmdecho)
; 计算直线角度(度,0-360范围)
(defun get_line_angle (pt1 pt2 / dx dy angle_rad angle_deg)
(setq dx (- (car pt2) (car pt1)) dy (- (cadr pt2) (cadr pt1)))
(setq angle_rad (atan dy dx) angle_deg (* angle_rad (/ 180.0 pi)))
(if (< angle_deg 0) (setq angle_deg (+ angle_deg 360.0)))
angle_deg
; 根据角度判断构造线类型(垂直/水平)
(defun get_construction_type (angle)
(setq normalized_angle (rem angle 180.0))
(if (< normalized_angle 0) (setq normalized_angle (+ normalized_angle 180.0)))
(cond
((or (<= normalized_angle 45) (>= normalized_angle 135)) "垂直")
((and (> normalized_angle 45) (< normalized_angle 135)) "水平")
(T "水平和垂直")
; 创建构造线图层(CONSTRUCTION,红色虚线)
(defun create_construction_layer ()
(setq layer "CONSTRUCTION")
(if (not (tblsearch "LAYER" layer))
(command "_.-LAYER" "_M" layer "_C" "1" "" "_L" "DASHED" "" "")
; 获取两实体交叉点(支持LINE/LWPOLYLINE/POLYLINE)
(defun get_intersections (ent1 ent2 / obj1 obj2 points result)
(setq obj1 (vlax-ename->vla-object ent1) obj2 (vlax-ename->vla-object ent2))
(if (and obj1 obj2)
(setq points (vlax-invoke obj1 'IntersectWith obj2 acExtendNone) result '())
(if points
(while (>= (length points) 3)
(setq result (cons (list (car points) (cadr points) (caddr points)) result))
(setq points (cdddr points))
(reverse result)
; 绘制构造线(指定交叉点+类型,赋值图层/颜色)
(defun draw_construction_lines (intersections construction_type / point lastEnt)
(foreach point intersections
(cond
((= construction_type "垂直")
(command "_.XLINE" "_V" point "")
(setq lastEnt (entlast))
(if lastEnt (progn
(vla-put-layer (vlax-ename->vla-object lastEnt) "CONSTRUCTION")
(vla-put-color (vlax-ename->vla-object lastEnt) 1)
((= construction_type "水平")
(command "_.XLINE" "_H" point "")
(if lastEnt (progn
(T
; 绘制水平+垂直构造线
(if lastEnt (progn
(if lastEnt (progn
(princ (strcat "\n在 " (itoa (length intersections)) " 个交叉点处绘制了" construction_type "构造线。"))
; 帮助命令(FVHELP)
(defun c:FVHELP ()
(princ "\n=== FV 命令使用说明 ===")
(princ "\n功能: 绘制直线并自动在交叉点创建构造线")
(princ "\n使用: 1.输入FV 2.指定直线起点 3.指定直线终点")
(princ "\n逻辑: 水平基准线→垂直构造线;垂直基准线→水平构造线")
(princ "\n辅助命令: FVCLEAN(清理构造线)、FVDEBUG(调试交叉点)")
(princ "\n========================")
; 清理命令(FFV)
(defun c:fvqc ()
(setq ss (ssget "X" '((8 . "CONSTRUCTION"))))
(if ss
(progn (command "_.ERASE" ss "") (princ (strcat "\n已删除 " (itoa (sslength ss)) " 个构造线对象。")))
(princ "\n没有找到构造线对象。")
; 调试命令(FFVV)
(defun c:FFVV (/ pt1 pt2 lineA line_angle construction_type ss i ent intersections objType)
(vl-load-com)
(if (not pt1) (exit))
(if (not pt2) (exit))
(if ss
(setq i 0)
(setq ent (ssname ss i) objType (cdr (assoc 0 (entget ent))))
(princ (strcat "\n" objType " " (itoa i) ": "))
(if intersections
(princ (strcat "找到 " (itoa (length intersections)) " 个交叉点"))
(foreach pt intersections
(princ (strcat "\n 点: " (rtos (car pt) 2 2) "," (rtos (cadr pt) 2 2)))
(princ "没有交叉点")
(setq i (1+ i))
; 加载提示
(princ "\nFV 命令已加载。输入 FV 开始使用,FFV 清理构造线,FFVV调试交叉点。")
(princ) |
