查看: 158|回复: 5
[源码] 小菜的选择易 用AI修复下,应该是1.2版本
发表于 昨天 20:29 | 显示全部楼层 |阅读模式
  • ;原版小菜,(setq fjflt (list 'and)) ;; 修复: 使用 list 构造初始列表
  • (defun c:TT (/       slent   f       dcl_name       lst2    lst1
  •               color   tmp     index_value     flag    entl    lst3
  •               lst4    code    ktmp    klst    hand    fjflt
  •               filter  kl_pre
  •               ss       fjlst   ssl     attdis  strtmp
  •   (vl-load-com)
  •   (setq  attdis "Y"
  •     kl_pre (last ss_saved_lst)
  •     slent  "N"
  •   (while (= slent "N")
  •     (initget "N")
  •     (setq
  •       slent (entsel
  •               (strcat "\n请选择样板实体(N-关闭块属性显示,当前状态:"
  •                 (if (= "Y" attdis)
  •                   "打开"
  •                   "关闭"
  •     (if  (= slent "N")
  •       (setq attdis "N")
  •       (setq slent (car slent))
  •   (if slent
  •     (progn
  •       (setq fjflt  nil
  •         filter nil
  •         entl   (entget slent)
  •       (setq lst2
  •            ("通用"
  •              ((0 "实体类型")
  •                (6 "实体线型")
  •                (8 "所在图层")
  •                (48 "线型比例")
  •                (62
  •                  "实体颜色"
  •                  ((256 "随层")
  •                    (0 "随块")
  •                    (1 "红色")
  •                    (2 "黄色")
  •                    (3 "绿色")
  •                    (4 "青色")
  •                    (5 "蓝色")
  •                    (6 "紫色")
  •                    (7 "黑白")
  •                (370 "实体线宽")
  •            ("ARC"
  •              ((-4 "圆弧")
  •                (10 "圆心坐标")
  •                (40 "圆弧半径")
  •                (39 "实体厚度")
  •                (50 "起点角度")
  •                (51 "终点角度")
  •              ("FJ" ("FJ1" "圆弧长度" (len slent)))
  •            ("CIRCLE"
  •              ((-4 "圆形")
  •                (10 "圆心坐标")
  •                (40 "圆形半径")
  •                (39 "实体厚度")
  •            ("SOLID" ((-4 "SOLID") (39 "实体厚度")))
  •            ("POINT"
  •              ((-4 "点")
  •                (10 "点的位置")
  •                (39 "实体厚度")
  •                (50 "旋转角度")
  •            ("LINE"
  •              ((-4 "直线段")
  •                (10 "起点坐标")
  •                (11 "终点坐标")
  •                (39 "实体厚度")
  •              ("FJ"
  •                ("FJ1" "线段长度" (len slent))
  •                ("FJ2"
  •                  "线段角度"
  •                  (REM
  •                    (ATOF (ANGTOS (ANGLE (DXF 10 slent) (DXF 11 slent))))
  •                    180
  •            ("ELLIPSE"
  •              ((-4 "椭圆")
  •                (10 "椭圆中心")
  •                (11 "长轴端点")
  •                (40 "长短轴比")
  •                (41 "开始参数")
  •                (42 "结束参数")
  •            ("INSERT"
  •              ((-4 "图块")
  •                (10 "图块位置")
  •                (2 "图块名称")
  •                (41 "X 轴比例")
  •                (42 "Y 轴比例")
  •                (43 "Z 轴比例")
  •                (50 "旋转角度")
  •            ("LWPOLYLINE"
  •              ((-4 "轻多义线")
  •                (38 "复线标高")
  •                (43 "固定宽度")
  •                (90 "顶点个数")
  •                (39 "复线厚度")
  •                (70 "是否闭合" ((0 "不闭合") (1 "闭合")))
  •              ("FJ" ("FJ1" "曲线长度" (len slent)))
  •            ("POLYLINE"
  •              ((-4 "重多义线")
  •            ("HATCH"
  •              ((-4 "图案填充")
  •                (2 "填充图案")
  •                (41 "填充比例")
  •                (52 "填充角度")
  •                (71 "边界关联" ((0 "不关联") (1 "关联")))
  •                (76 "图案类型" ((0 "用户定义") (1 "预定义") (2 "自定义")))
  •            ("TEXT"
  •              ((-4 "文字")
  •                (1 "文字内容")
  •                (7 "文字样式")
  •                (10 "插入位置")
  •                (40 "文字高度")
  •                (41 "宽度系数")
  •                (50 "旋转角度")
  •                (51 "倾斜角度")
  •                (71
  •                  "文字镜像"
  •                  ((0 "默认") (2 "文字反向") (4 "文字倒置") (6 "反向倒置"))
  •                (72
  •                  "水平对齐"
  •                  ((0 "左对齐")
  •                    (1 "居中对齐")
  •                    (2 "右对齐")
  •                    (3 "对齐")
  •                    (4 "中间")
  •                    (5 "拟合")
  •                (73
  •                  "垂直对齐"
  •                  ((0 "基线对齐")
  •                    (1 "底端对齐")
  •                    (2 "居中对齐")
  •                    (3 "顶端对齐")
  •              ("FJ" ("FJ1" "文字数值" (ATOF (DXF 1 slent))))
  •            ("ATTDEF"
  •              ((-4 "属性定义")
  •                (2 "属性标记")
  •                (7 "字型样式")
  •                (10 "插入位置")
  •                (40 "文字高度")
  •                (50 "旋转角度")
  •                (51 "倾斜角度")
  •                (71
  •                  "文字镜像"
  •                (72
  •                  "水平对齐"
  •                  ((0 "左对齐")
  •                    (1 "居中对齐")
  •                    (2 "右对齐")
  •                    (3 "对齐")
  •                    (4 "中间")
  •                    (5 "拟合")
  •                (73
  •                  "垂直对齐"
  •                  ((0 "基线对齐")
  •                    (1 "底端对齐")
  •                    (2 "居中对齐")
  •                    (3 "顶端对齐")
  •              ("FJ" ("FJ1" "标记数值" (ATOF (DXF 2 slent))))
  •            ("MTEXT"
  •              ((-4 "多行文字")
  •                (10 "插入位置")
  •                (1 "文字内容")
  •                (7 "文字样式")
  •                (40 "文字高度")
  •                (50 "旋转角度")
  •            ("SPLINE"
  •              ((-4 "样条曲线")
  •                (70 "曲线标志")
  •                (71 "曲线阶数")
  •                (72 "节点数量")
  •                (73 "控制点数")
  •                (74 "拟合点数")
  •                (42 "节点公差")
  •                (43 "控点公差")
  •                (44 "拟合公差")
  •            ("DIMENSION"
  •              ((-4 "尺寸标注")
  •                (1 "标注文字")
  •                (42 "测量值")
  •                (3 "标注样式")
  •                (70
  •                  "标注类型"
  •                  ((32 "水平垂直")
  •                    (33 "对齐标注")
  •                    (34 "角度标注")
  •                    (35 "直径标注")
  •                    (36 "半径标注")
  •                    (37 "三点角度")
  •                    (38 "坐标标注")
  •       (if (and (= attdis "Y") (= "INSERT" (dxf 0 slent)))
  •         (kldc_1)
  •       (setq lst3 (car (dxf "通用" lst2))
  •         lst5 (dxf (dxf 0 entl) lst2)
  •         lst4 (car lst5)
  •         lst5 (cadr lst5)
  •       (foreach tmp lst3
  •         (if (and (not (dxf (car tmp) entl)) (/= (car tmp) 62) (/= (car tmp) 370))
  •           (setq lst3 (vl-remove tmp lst3))
  •       (setq dcl_name (strcat (getenv "temp") "\\sel" ".dcl")
  •         f       (OPEN dcl_name "w")
  •       (write-line "sl:dialog{label=\"我的选择易--By 小菜\";" f)
  •       (write-line ":column{" f)
  •       (write-line ":boxed_column{label=\"过滤条件\";" f)
  •       (write-line ":boxed_column{label=\"通用\";" f)
  •       (foreach tmp lst3
  •         (write-line ":row{fixed_width=true;" f)
  •         (write-line
  •           (strcat ":toggle{key=\""
  •             (itoa (car tmp))
  •             "\";label=\""
  •             (cadr tmp)
  •             "\";width=12;}"
  •           f
  •         (write-line
  •           (strcat ":popup_list{edit_width=5;key=\"pop"
  •             (itoa (car tmp))
  •           f
  •         (setq
  •           ktmp (list (strcat "pop" (itoa (car tmp))) (itoa (car tmp)))
  •         (if (/= 62 (car tmp))
  •           (progn
  •             (setq
  •               ktmp (write f
  •                      ktmp
  •                      (car tmp)
  •                      (vl-princ-to-string (dxf (car tmp) entl))
  •                      "txt"
  •                      "16"
  •             (if  (= 48 (car tmp))
  •               (setq ktmp (write f ktmp 48 "容差" "txta" "7"))
  •           (progn
  •             (setq color (dxf 62 entl))
  •             (if  (not color)
  •               (setq color 256)
  •             (setq ktmp (write f ktmp 62 (itoa color) "txt" "16"))
  •             (write-line
  •               (strcat ":edit_box{value=\""
  •                 (vl-princ-to-string (car (dxf color (caddr tmp))))
  •                 "\";edit_width=7 ;allow_accept=true;}"
  •               f
  •         (write-line "}" f)
  •         (setq klst (cons (reverse ktmp) klst))
  •       (write-line
  •         (strcat  ":boxed_column{label=\""
  •           (vl-princ-to-string (car (dxf -4 lst4)))
  •         f
  •       (setq lst4 (cdr lst4))
  •       (foreach tmp lst4
  •         (setq code (car tmp)
  •           ktmp nil
  •         (if (dxf code entl)
  •           (progn
  •             (setq ktmp (list (strcat "pop" (itoa code)) (itoa code)))
  •             (write-line
  •                 (itoa code)
  •                 "\";label=\""
  •                 (vl-princ-to-string (cadr tmp))
  •                 "\";width=12;}"
  •               f
  •             (write-line
  •                 (itoa code)
  •               f
  •             (cond
  •               ((or (= code 10) (= code 11))
  •                 (setq ktmp
  •                   (write f
  •                     ktmp
  •                     code
  •                     (vl-princ-to-string (car (dxf code entl)))
  •                     "txt_x"
  •                     "6.5"
  •                 (setq ktmp
  •                   (write f
  •                     ktmp
  •                     code
  •                     (vl-princ-to-string (cadr (dxf code entl)))
  •                     "txt_y"
  •                     "6"
  •                 (setq ktmp
  •                   (write f
  •                     ktmp
  •                     code
  •                     (vl-princ-to-string (caddr (dxf code entl)))
  •                     "txt_z"
  •                     "7"
  •               ((member code
  •                  '(1 2 3 7 90 38 39 40 41  42 43 44 50 51 52 70 71
  •                     72 73 74 76)
  •                 (setq strtmp (vl-princ-to-string (dxf code entl)))
  •                 (if (= code 1)
  •                   (foreach tmp '("\r\n" "\\P" "\\")
  •                     (while (vl-string-search tmp strtmp)
  •                       (setq strtmp (vl-string-subst " " tmp strtmp))
  •                 (setq ktmp (write f ktmp code strtmp "txt" "16"))
  •                 (cond
  •                   ((member code '(38 39 40 41 42 43 44 50 51 52))
  •                     (setq ktmp (write f ktmp code "容差" "txta" "7"))
  •                   ((member code '(70 71 72 73 74 76))
  •                     (if
  •                       (car (dxf (dxf code entl) (cadr (dxf code lst4))))
  •                       (write-line
  •                         (strcat
  •                           ":edit_box{value=\""
  •                             (car
  •                               (dxf (dxf code entl) (cadr (dxf code lst4)))
  •                           "\";edit_width=7;allow_accept=true;}"
  •                         f
  •         (if ktmp
  •       (if lst5
  •         (progn (setq lst5 (cdr lst5))
  •           (write-line ":boxed_column{label=\"附加过滤\";" f)
  •           (foreach  tmp lst5
  •             (write-line
  •                 (car tmp)
  •                 "\";label=\""
  •                 (cadr tmp)
  •                 "\";width=12;}"
  •               f
  •             (write-line
  •                 (car tmp)
  •               f
  •             (setq ktmp (list (strcat "pop" (car tmp)) (car tmp)))
  •                          ktmp
  •                          (car tmp)
  •                          (vl-princ-to-string (eval (caddr tmp)))
  •                          "txt"
  •                          "16"
  •             (setq ktmp (write f ktmp (car tmp) "容差" "txta" "7"))
  •             (setq fjlst (cons (reverse ktmp) fjlst))
  •       (write-line "}:row{:boxed_radio_row{label=\"过滤范围\";" f)
  •       (write-line
  •         ":radio_button{label=\"手选\";key=\"hand\";value=\"1\";}"
  •         f
  •       (write-line ":radio_button{label=\"预选\";key=\"pre\";}" f)
  •       (write-line ":radio_button{label=\"全图\";key=\"all\";}" f)
  •       (write-line "}}:row{ok_cancel;}}}" f)
  •       (close f)
  •       (setq klst (reverse klst))
  •       (setq index_value (load_dialog dcl_name))
  •       (new_dialog "sl" index_value)
  •       (foreach tmp klst
  •         (cond ((member (car tmp) '("0" "1" "2" "3" "6" "7" "8"))
  •                 (show_list (cadr tmp) '("=" "<>"))
  •           ((member (car tmp)
  •              '("10"  "11"   "38"   "39"   "40"   "41"
  •                 "42"  "43"   "44"   "48"   "50"   "51"
  •                 "52"
  •             (show_list (cadr tmp) '("=" "<" ">" "<=" ">=" "<>"))
  •              '("62" "70" "71" "72" "73" "74" "76" "90" "370")
  •       (if fjlst
  •         (foreach tmp fjlst
  •       (if kl_pre
  •         (foreach tmp (cdr kl_pre)
  •           (if (= (dxf 0 entl) (car kl_pre))
  •             (set_tile (car tmp) "1")
  •             (if  (member (car tmp) '("0" "6" "8" "48" "62" "370"))
  •       (action_tile "accept" "(get_filter) (done_dialog 1)")
  •       (setq flag (start_dialog))
  •       (unload_dialog index_value)
  •     (setq hand   (car ss_saved_lst)
  •       fjflt   (cadr ss_saved_lst)
  •       filter (caddr ss_saved_lst)
  •   (if filter
  •     (progn (princ "\n使用过滤器:")
  •       (prin1 filter)
  •       (cond ((= hand "1") (setq ss (ssget filter)))
  •         ((= hand "2") (setq ss (ssget "p" filter)))
  •         ((= hand "3") (setq ss (ssget "x" filter)))
  •   (if (and (setq ssl (chsget ss)) fjflt)
  •     (foreach slent ssl
  •       (if (not (eval fjflt))
  •         (setq ss (ssdel slent ss))
  •   (setq ss_saved_lst (list hand fjflt filter kl_pre))
  •   (if ss
  •     (progn
  •       (princ (strcat "\n共选中了" (itoa (sslength ss)) "个实体。")
  •       (if (= 0 (getvar "cmdactive"))
  •         (command "select" ss "" "pselect" ss "")
  •     (princ "\n共选中了0个实体。")
  •   ss
  • (defun get_filter (/ tmp pop txt txt1 rc txt2 txt3 pop_1 pop_2 pop_3)
  •   (cond  ((= "1" (get_tile "hand")) (setq hand "1"))
  •     ((= "1" (get_tile "pre")) (setq hand "2"))
  •     ((= "1" (get_tile "all")) (setq hand "3"))
  •   (foreach tmp klst
  •     (if  (/= "1" (get_tile (car tmp)))
  •       (setq klst (vl-remove tmp klst))
  •       (setq fjlst (vl-remove tmp fjlst))
  •   (setq kl_pre (append (list (dxf 0 entl)) klst fjlst))
  •   (foreach tmp klst
  •     (setq pop (get_tile (cadr tmp)))
  •     (cond
  •       ((member (car tmp) '("0" "1" "2" "3" "6" "7" "8"))
  •         (setq txt  (get_tile (caaddr tmp))
  •           txt1 (cadr (caddr tmp))
  •         (if (= txt txt1)
  •           (setq txt (dxf (read (car tmp)) entl))
  •         (cond ((= pop "0")
  •                 (setq filter (append (cons '(-4 . "<OR")
  •                                        (cons (cons (read (car tmp)) txt)
  •                                          '((-4 . "OR>"))
  •                                filter
  •           ((= pop "1")
  •             (setq filter (append (cons '(-4 . "<NOT")
  •                                      '((-4 . "NOT>"))
  •                            filter
 楼主| 发表于 昨天 20:30 | 显示全部楼层
  •           filter (append
  •                    (cons (cons -4
  •                            (nth (read pop)
  •                      (list (cons (read (car tmp)) (read txt)))
  •                    filter
  •          '("38" "39" "40" "41" "42" "43" "44" "48" "50" "51" "52")
  •           rc    (read (get_tile (car (last tmp))))
  •         (if (/= txt txt1)
  •           (setq txt (atof txt))
  •         (if (and  (or (= (type rc) 'REAL) (= (type rc) 'INT))
  •               (= pop "0")
  •           (setq filter
  •             (append
  •               (cons  '(-4 . "<=")
  •                 (list (cons (read (car tmp)) (+ txt (abs rc))))
  •               (cons  '(-4 . ">=")
  •                 (list (cons (read (car tmp)) (- txt (abs rc))))
  •               filter
  •           (setq
  •             filter (append
  •                      (cons
  •                        (cons
  •                          -4
  •                          (nth (read pop) '("=" "<" ">" "<=" ">=" "<>"))
  •                        (list (cons (read (car tmp)) txt))
  •                      filter
  •       ((member (car tmp) '("10" "11"))
  •         (setq txt1  (get_tile (caaddr tmp))
  •           txt2  (get_tile (car (cadddr tmp)))
  •           txt3  (get_tile (car (last tmp)))
  •           pop_1 (nth (read pop) '("=" "<" ">" "<=" ">=" "<>"))
  •           pop_2 pop_1
  •           pop_3 pop_1
  •         (if (= txt1 "")
  •           (setq pop_1 "*")
  •         (if (= txt2 "")
  •           (setq pop_2 "*")
  •         (if (= txt3 "")
  •           (setq pop_3 "*")
  •         (if (/= txt1 (cadr (caddr tmp)))
  •           (setq txt1 (atof txt1))
  •           (setq txt1 (car (dxf (read (car tmp)) entl)))
  •         (if (/= txt2 (cadr (cadddr tmp)))
  •           (setq txt2 (atof txt2))
  •           (setq txt2 (cadr (dxf (read (car tmp)) entl)))
  •         (if (/= txt3 (cadr (last tmp)))
  •           (setq txt3 (atof txt3))
  •           (setq txt3 (caddr (dxf (read (car tmp)) entl)))
  •         (setq filter
  •           (append
  •             (cons
  •               (cons -4 (strcat pop_1 "," pop_2 "," pop_3))
  •               (list (cons (read (car tmp)) (list txt1 txt2 txt3)))
  •             filter
  •   (if fjlst
  •     (progn
  •       (if (null filter)
  •         (setq filter (list (assoc 0 entl)))
  •       (setq fjflt (list 'and))
  •           txt  (get_tile (caaddr tmp))
  •         (if (/= txt txt1)
  •           (if (/= "INSERT" (dxf 0 slent))
  •           (setq txt (eval (caddr (dxf (car tmp) lst5))))
  •               (= pop "0")
  •           (setq  fjflt
  •             (append
  •               fjflt
  •               (list (list 'and
  •                       (list '<=
  •                         (caddr (dxf (car tmp) lst5))
  •                         (+ txt (abs rc))
  •                       (list '>=
  •                         (- txt (abs rc))
  •           (setq  fjflt
  •             (append
  •               fjflt
  •               (list
  •                 (list
  •                   (read
  •                   txt
  • (defun show_list (key lst)
  •   (start_list key)
  •   (mapcar 'add_list lst)
  •   (end_list)
  • (defun write (f ktmp code value txt width / tmp)
  •   (setq tmp (strcat txt (vl-princ-to-string code)))
  •   (write-line
  •     (strcat ":edit_box{value=\"" value
  •       "\";key=\""     tmp
  •       "\";edit_width="   width
  •       ";allow_accept=true;}"
  •     f
  •   (setq ktmp (cons (list tmp value) ktmp))
  • (defun dxf (i ent)
  •   (if (= (type ent) 'ENAME)
  •     (setq ent (entget ent))
  •   (cdr (assoc i ent))
  • (defun chsget (c01 / c02 c03 c04 c05)
  •   (if c01
  •     (progn
  •       (setq c02  0
  •         c03  (sslength c01)
  •       (while (< c02 c03)
  •         (setq c04 (ssname c01 c02)
  •           c02 (1+ c02)
  •         (setq c05 (cons c04 c05))
  •   c05
  • (defun len (ent)
  •     (setq ent (vlax-ename->vla-object ent))
  •   (if
  •     (wcmatch
  •       (vla-get-ObjectName ent)
  •       "AcDbPolyline,AcDbEllipse,AcDbCircle,AcDbArc,AcDbLine,AcDb2dPolyline,AcDbSpline"
  •     (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent))
  • (defun VxGetAtts (Obj)
  •   (if (= (type Obj) 'ENAME)
  •     (setq Obj (vlax-ename->vla-object Obj))
  •   (if (= (vla-get-ObjectName obj) "AcDbBlockReference")
  •     (mapcar
  •       '(lambda (Att)
  •          (cons (vla-get-TagString Att)
  •            (vla-get-TextString Att)
  •       (vlax-invoke Obj "GetAttributes")
  • (defun KLDC_1 (/ attl alen lval ltag aflst aa cc a11 a12 a13)
  •   (setq attl (VxGetAtts slent))
  •   (if attl
  •     (progn
  •       (setq alen (length attl))
  •       (while (> alen 0)
  •         (setq a11   (list (cons 'nth (cons (- alen 1) '((VxGetAtts slent)))))
  •           a12   (cons 'if (list '(VxGetAtts slent) (cons 'cdr a11)))
  •           a13   (cons 'if (list '(VxGetAtts slent) (cons 'car a11)))
  •           lval  (list (strcat "FJ" (rtos (* 2 alen) 2 0))
  •                   '"属性数值"
  •                   a12
  •           ltag  (list (strcat "FJ" (rtos (- (* 2 alen) 1) 2 0))
  •                   '"属性标志"
  •                   a13
  •           aflst (append (list lval ltag) aflst)
  •           alen  (1- alen)
  •       (setq aa   (assoc "INSERT" lst2)
  •         cc   (list (car aa) (cadr aa) (append '(FJ) (reverse aflst)))
  •         lst2 (subst cc aa lst2)
  • ;; (if (not (member "acopm.arx" (arx)))
  • ;;   (arxload "acopm.arx")
  • (princ)
 楼主| 发表于 昨天 20:38 | 显示全部楼层
  • ;; 场景1: 预先选中了1个对象 -> 自动作为样板,默认搜全图
  • ;; 场景2: 预先选中了多个对象 -> 需手动指定样板,但默认搜"预选"
  • ;; 场景3: 无预选 -> 默认搜全图
  • ;; 代化函数  选中亮显,AI改的
发表于 昨天 21:21 | 显示全部楼层
看了看电脑上安装的1.39b,瑟瑟发抖
发表于 昨天 22:27 | 显示全部楼层
网上有好多个修改版本的
发表于 昨天 23:41 | 显示全部楼层
感谢分享,谢谢楼主
GMT+8, 2025-12-2 06:24 , Processed in 0.259248 second(s), 26 queries , Gzip On.
