查看: 3283|回复: 2
如何给多段线增加节点
发表于 2004-4-15 15:04:00 | 显示全部楼层 |阅读模式
发表于 2004-4-15 19:20:00 | 显示全部楼层
使用AppendVertex添加节点。
发表于 2004-4-15 19:51:00 | 显示全部楼层
怎么都不喜欢看帮助?这是帮助里的示例:
  1. Sub Example_AppendVertex()
  2.        ' This example creates a polyline in model space.
  3.        ' It then appends a vertex to the polyline.
  4.
  5.        Dim plineObj As AcadPolyline
  6.        Dim points(0 To 14) As Double
  7.
  8.
  9.        ' Define the 2D polyline points
  10.        points(0) = 1: points(1) = 1: points(2) = 0
  11.        points(3) = 1: points(4) = 2: points(5) = 0
  12.        points(6) = 2: points(7) = 2: points(8) = 0
  13.        points(9) = 3: points(10) = 2: points(11) = 0
  14.        points(12) = 4: points(13) = 4: points(14) = 0
  15.
  16.        ' Create a light weight Polyline object in model space
  17.        Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
  18.        ZoomAll
  19.        MsgBox "Append the vertex 4, 1, 0.", , "AppendVertex Example"
  20.
  21.        Dim newVertex(0 To 2) As Double
  22.        newVertex(0) = 4: newVertex(1) = 1: newVertex(2) = 0
  23.        plineObj.AppendVertex newVertex
  24.        ZoomAll
  25.        MsgBox "The vertex 4, 1, 0 as been appended.", , "AppendVertex Example"End Sub
GMT+8, 2025-11-28 10:19 , Processed in 0.205541 second(s), 24 queries , Gzip On.
