查看: 4157|回复: 12
vlax-add-cmd
发表于 2004-4-19 00:24:00 | 显示全部楼层 |阅读模式
您好!
请问:         (defun ze() (command "._zoom" "e"))
        (vlax-add-cmd "ze" 'ze "ze" 1)
        为什么在使用其它命令的过程中使用'ze会出错,
        而(defun ok() (prompt "\nOK!"))
        (vlax-add-cmd "ok" 'ok "ok" 1)
        在使用其它命令的过程中使用'ok不会出错?
        我该用什么方法才能达到在使用其它命令的过程中使用'ze不会出错?
发表于 2004-4-19 07:09:00 | 显示全部楼层
In help file:
Adds commands to the AutoCAD built-in command set
(vlax-add-cmd global-name func-sym [local-name cmd-flags])
With vlax-add-cmd you can define a function as an AutoCAD command, without using the c: prefix in the function name. You can also define a transparent AutoLISP command, which is not possible with a c: function.
Warning! You cannot use the c ommand function call in a transparently defined vlax-add-cmd function. Doing so can cause AutoCAD to close unexpectedly.
You can define ZE in this way:
(defun ze() (vla-ZoomExtents (vlax-get-acad-object)))
 楼主| 发表于 2004-4-20 01:33:00 | 显示全部楼层
谢谢!
请问怎样才能将'ms设为类似'ze的功能?
(defun ms() (command "._pan" (cadr (grread 1 1 3)) (getvar "viewctr")))
急需!
发表于 2004-4-20 07:01:00 | 显示全部楼层
(defun ms() (vla-ZoomCenter (vlax-get-acad-object)
(vlax-3d-point (cadr (grread 1 1 3))) (getvar "VIEWSIZE")))
 楼主| 发表于 2004-4-20 20:37:00 | 显示全部楼层
谢谢alin,您真的很厉害!
我编了一个在删pline线上节点的程序,接下来想编一个在pline线上加节点的程序,但一直不知该如何下手,您能否帮帮忙或指点一下思路?
再次谢谢!
发表于 2004-4-22 06:15:00 | 显示全部楼层
Pedit --> Edit Vertex --> Insert --> (pick point)
 楼主| 发表于 2004-4-22 19:50:00 | 显示全部楼层
谢谢!
我先试试.
 楼主| 发表于 2004-4-22 21:26:00 | 显示全部楼层
alin,您好!
我把4楼所说的ms功能加入命令集后(允许透明调用),想设定"F12"为快捷键,在运行其它CAD命令的过程中按"F12"也有效,该怎么做?
 楼主| 发表于 2004-4-23 01:38:00 | 显示全部楼层
alin:8楼的问题我已解决.请问按您6楼的提示,我怎样才能得到需加点处的最近节点序号?
或是有其它方法?若用vla-addvertex该怎么编?
发表于 2004-4-23 07:50:00 | 显示全部楼层
GMT+8, 2025-5-14 03:01 , Processed in 0.204887 second(s), 27 queries , Gzip On.
