查看: 1781|回复: 2
求助一个选择集的问题
发表于 2004-4-20 20:56:00 | 显示全部楼层 |阅读模式
Dim plobj As AcadLWPolyline Dim gpCode(0 To 0) As Integer
Dim dataValue(0 To 0) As Variant
gpCode(0) = 8
dataValue(0) = "定级网格单元"
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
ThisDrawing.Utility.GetEntity plobj, pt, "选择范围线"
plobj.GetBoundingBox minpt, maxpt
Dim pt1(0 To 2) As Double, pt2(0 To 2) As Double
pt1(0) = minpt(0): pt1(1) = minpt(1): pt1(2) = 0
pt2(0) = maxpt(0): pt2(1) = maxpt(1): pt2(2) = 0
ssetObj.Select acSelectionSetWindow, pt1, pt2, groupCode, dataCode 但是得不到想要结果,总是选择到一部分实体,不能把矩形窗口内的实体全部选择,为什么?请求各位大虾!·
发表于 2004-4-20 21:22:00 | 显示全部楼层
看看帮助吧
发表于 2004-4-22 23:22:00 | 显示全部楼层
< class=syntax>object.Select Mode[, Point1][, Point2][, FilterType][, FilterData]
< class=syntax>你试试吧
GMT+8, 2025-5-7 23:31 , Processed in 0.178885 second(s), 24 queries , Gzip On.
