查看: 1579|回复: 9
[LISP]请大虾改错!!
发表于 2004-4-21 10:07:00 | 显示全部楼层 |阅读模式
(defun c:fls()
(setq qmax 2450)
(setq q0 2)
(setq n 2)
(setq h1 0.3)
(setq h3 0.5)
(setq h5 1.73)
(setq h4 0.6)
(setq tt 1.5)
(setq b 300)
(setq w 600)
(setq hh 800)
(setq rg 500)
(setq gb 50)
(setq nr 800)
;*******************************设计计算部分***********************************
(setq a1 (/ (/ qmax n) q0));每个沉淀池的表面积
(setq d (sqrt (* (/ a1 pi) 4)));每个沉淀池的直径
(setq d (* d 1000))
(setq r (/ d 2));沉淀池半径
(setq bk (+ (* b 2) r w));沉淀池半宽
(setq h2 (* (* q0 tt) 1000));有效水深
(setq h (+ h1 h2 h3 h4 h5));沉淀池总高度
(setq pt0 (500,500,500))
(setq pt01 (polar pt00 (/ pi 2) h))
(chibi)
(nidou)
(podi)
(szjsg)
(wantou)
(bjg)
(csg)
);池壁部分
(defun chibi()
(setq pt1 (polar pt01 pi bk))
(setq pt2 (polar pt1 (* (/ pi 2) 3) hh))
(setq pt3 (polar pt2 0 w))
(setq pt4 (polar pt3 (/ pi 2) b))
(setq pt5 (polar pt4 (/ pi 3) (* b 2)))
(setq pt14 (polar pt1 pi b))
(setq pt13 (polar pt14 (* (/ pi 2) 3) (+ hh b)))
(setq pt12 (polar pt13 0 (+ w b)))
(setq pt11 (polar pt12 (* (/ pi 2) 3) (- h h4 h5 hh b h3)))
(setq pt10 (polar pt11 pi b))
(setq pt9 (polar pt10 (* (/ pi 2) 3) b))
(setq pt8 (polar pt9 0 (* b 3)))
(setq pt7 (polar pt8 (/ pi 2) b))
(setq pt6 (polar pt7 pi b))
(command "line" pt1 pt2 "")
(setq en1 (entlast))
(command "line" pt2 pt3 "")
(setq en2 (entlast))
(command "line" pt4 pt3 "")
(setq en3 (entlast))
(command "line" pt4 pt5 "")
(setq en4 (entlast))
(command "line" pt1 pt14 "")
(setq en5 (entlast))
(command "line" pt14 pt13 "")
(setq en6 (entlast))
(command "line" pt13 pt12 "")
(setq en7 (entlast))
(command "line" pt12 pt11 "")
(setq en8 (entlast))
(command "line" pt11 pt10 "")(setq en9 (entlast))
(command "line" pt10 pt9 "")
(setq en10 (entlast))
(command "line" pt9 pt8 "")
(setq en11 (entlast))
(command "line" pt7 pt8 "")
(setq en12 (entlast))
(command "line" pt7 pt6 "")
(setq en13 (entlast))
(command "line" pt6 pt5 "")
(setq en14 (entlast))
(command "pedit" en1 "" "j" en1 en2 en3 en4 en5 en6 en7 en8 en9 en10 en11 en12 en13 en14 "" "")
(setq en15 (entlast))
(command "revolve" en15 "" pt00 pt01 "")
(prin1)
);泥斗部分
(defun nidou()
(setq pt1 (polar pt00 (/ pi 2) b))
(setq pt2 (polar pt1 pi nr))
(setq pt3 (polar pt00 pi (+ nr 1500)))
(setq pt5 (polar pt4 0 b))
(setq pt6 (polar pt5 (/ pi 2) h5))
(setq pt7 (polar pt6 0 b))
(command "line" pt00 pt1 "")
(command "line" pt00 pt3 "")
(command "line" pt5 pt6 "")
(command "line" pt6 pt7 "")
(command "line" pt7 pt2 "")
(command "pedit" en1 "" "j" en1 en2 en3 en4 en5 en6 en7 en8 "" "")
(command "revolve" en9 "" pt00 pt1 "")
(command "circle" pt00 (+ rg gb) "")
(command "extrude" en2 "" b "" "")
(command "rotate3d" en2 "" "x" pt00 -90 "")
(command "subtract" en1 "" en2 "")
(prin1)
);坡底部分
(defun podi()
(setq pt21 (polar pt00 (/ pi 2) b))
(setq pt22 (polar pt21 pi nr))
(setq pt23 (polar pt00 pi (+ nr 1500)))
(setq pt24 (polar pt23 (/ pi 2) b))
(setq pt25 (polar pt24 0 b))
(setq pt61 (polar pt25 (/ pi 2) h5))
(setq pt62 (polar pt61 (* (/ pi 2) 3) b))
(setq pt63 (polar pt6 (/ pi 2) b))
(command "line" pt61 pt62 "")
(command "line" pt6 pt62 "")
(command "line" pt63 pt6 "")
(command "line" pt61 pt63 "")
(command "pedit" en1 "" "j" en1 en2 en3 en4 "" "")
(command "revolve" en5 "" pt00 pt01 "")
(prin1)
);中心进水管部分
(defun szjsg()
(setq pt1 (polar pt00 pi rg))
(setq pt2 (polar pt1 pi gb))
(setq pt5 (polar pt1 (/ pi 2) (+ h5 h4 h2)))
(setq pt6 (polar pt5 pi gb))
(command "line" pt1 pt5 "")
(command "line" pt2 pt6 "")
(command "pedit" en11 "" "j" en11 en12 en13 en14 "" "")
(command "revolve" en1"" pt00 pt01 "")
(prin1)
);弯头部分
(defun wantou()
(setq pt01 (polar pt00 (/ pi 2) (* (+ rg gb) -2)))
(setq pt02 (polar pt01 pi 1500))
(setq pt03 (polar pt01 0 1500))
(setq pt04 (polar pt00 pi 1500))
(setq pt05 (polar pt00 0 1500))
(command "circle" pt00 rg "")
(command "revolve" en1 "" pt02 pt03 90 "")
(command "revolve" en2 "" pt02 pt03 90 "")
(command "subtract" en2 "" en1 "")
(command "rotate3d" en1 "" 2 pt04 pt05 90 "")
(prin1)
);变径管部分
(defun bjg()
(setq pt01 (polar pt00 (/ pi 2) (+ h5 h4 h2)))
(setq pt1 (polar pt01 (/ pi 2) (/ h3 4)))
(setq pt2 (polar pt1 pi (+ rg gb 250)))
(setq pt3 (polar pt2 pi 50))
(setq pt5 (polar pt01 pi rg))
(setq pt4 (polar pt5 pi 50))
(command "line" pt2 pt5 "")
(command "line" pt3 pt4 "")
(command "revolve" en1 "" pt00 pt1 360)
(prin1)
);布水管部分
(defun bsg()
(setq pt1 (polar pt00 (/ pi 2) (+ h5 h2 h4 (/ h3 4))))
(setq pt2 (polar pt1 (* (/ pi 2) 3) (+ rg gb 300)))
(setq pt3 (polar pt1 (/ pi 2) (/ h3 4)))
(setq pt6 (polar pt3 pi (+ rg gb 300)))
(setq pt5 (polar pt4 pi (+ rg gb 300)))
(setq zx1 (entlast))
(setq zx2 (entlast))
(setq zx3 (entlast))
(command "line" pt6 pt3 "")
(setq zx4 (entlast))
(command "pedit" zx1 "" "j" zx1 zx2 zx3 zx4 "" "")
(setq zx (entlast))
(command "revolve" zx "" pt1 pt2 "")
(command "circle" pt1 (+ rg gb 300) "")
(command "extrude" en1 "" (/ h3 4) "")
(command "circle" pt1 (+ rg gb 250) "")
(command "extrude" en2 "" (/ h3 4) "")
(setq en1 (entlast));
(command "extrude" en2 "" (/ h3 -4) "")
(command "extrude" en3 "" (/ h3 -4) "")
(command "subtract" en3 "" en2 "")
(command "union" en1 en2 "")
(command "circle" pt2 100 "")
(command "extrude" en4 "" 100 "")
(command "rotate3d" en4 "" "x" pt2 -90 "")
(command "intersect" en4 en1 "")
(command "array" en4 "" "p" pt1 5 360 "y")
(setq en41 (entnext en4))
(setq en42 (entnext en41))
(setq en43 (entnext en42))
(setq en44 (entnext en43))
(command "union" en4 en41 en42 en43 en44 "")
(command "subtract" en1 "" en4 "")
(command "rotate3d" en1 "" "x" pt1 90)
(prin1)
);出水管部分
(defun csg()
(setq pt1 (polar pt01 pi (- bk 100)))
(setq pt3 (polar pt2 (/ pi 2) (/ rg 2)))
(setq pt4 (polar pt2 (/ pi 2) (/ gb 2)))
(setq pt5 (polar pt4 pi 2000))
(setq pt6 (polar pt3 pi 2000))
(setq pt7 (polar pt2 pi 2000))
(command "line" pt2 pt4 "")
(command "line" pt7 pt5 "")
(command "line" pt2 pt7 "")
(command "revolve" en1 "" pt3 pt6 "")
(prin1)
);排泥管部分
(defun png()
(command "line" pt5 pt7 "")
(prin1)
 楼主| 发表于 2004-4-21 10:08:00 | 显示全部楼层
提示“(500,500,500)”错误???求助!!!
发表于 2004-4-21 10:29:00 | 显示全部楼层
(setq pt0 '(500 500 500))表示座標點
 楼主| 发表于 2004-4-21 11:22:00 | 显示全部楼层
还是不行呀???
“错误: 参数类型错误: 二维/三维点: nil”
发表于 2004-4-21 12:17:00 | 显示全部楼层
这种错误你不应该放到这里来问,而要完全自己去找,这些都是一般的错误问题,你的赋值函数太多,所以你必须要保证每个赋值函数所赋的值都是正确的,,,所以你写程序必须很仔细,小心,检查的时候也要这样...包括不要把变量写错了,如: (setq pt0 (500,500,500));这个问题楼上已经说过
(setq pt01 (polar pt00 (/ pi 2) h)) 这里后面的pt00我猜测应该是前面的pt0吧...后面是否还有类似的错误,你要自己仔细找找,如果这样的问题都要别人来帮你解决,那似乎你自己就完全无法独立写程序了
 楼主| 发表于 2004-4-21 15:41:00 | 显示全部楼层
太不好意思啦,就那一处没注意
但问题好像不在这吧
我改成“(setq pt00 (getpoint "pt00"))”没问题
但写成“(setq pt00 ' (500,500,500))”还是不行呀
发表于 2004-4-21 16:11:00 | 显示全部楼层
更正(setq pt0 '(500 500 500))表示座標點
发表于 2004-4-21 17:14:00 | 显示全部楼层
wei186发表于2004-4-21 15:41:00太不好意思啦,就那一处没注意 但问题好像不在这吧 我改成“(setq pt00 (getpoint \"pt00\"))”没问题 但写成“(setq pt00 ' (500,500,500))”还是不行呀...
3楼只是教你该怎样自己去查错...还有那么多题外话你似乎没看啊
 楼主| 发表于 2004-4-21 19:59:00 | 显示全部楼层
什么题外话,不懂
楼上的你不高兴不回就是啦
发表于 2004-4-22 08:25:00 | 显示全部楼层
难道我5楼写那么多字是为了练习打字?
楼主的程序就上面几点已经完全改好了,我还写了那么多教你如何自己查错,,,不知道楼主还声那么大气做什么?
GMT+8, 2025-5-14 00:11 , Processed in 0.233191 second(s), 25 queries , Gzip On.
