查看: 10204|回复: 19
抛砖引玉
发表于 2004-4-22 12:12:00 | 显示全部楼层 |阅读模式
  1.        Module mTlsCad
  2.                Public Const strAppName As String = "TlsCad"
  3.                Public Const tString As Short = 0
  4.                Public Const tDouble As Short = 1
  5.                Public Const tPoint As Short = 2
  6.                Public Function LeftStr(ByVal String1 As Object, ByVal String2 As Object) As Object
  7.                        Try
  8.                                LeftStr = Left(String1, InStr(String1, String2) - 1)
  9.                        Catch ex As Exception
  10.                                LeftStr = False
  11.                        End Try
  12.                End Function
  13.                Public Function RightStr(ByVal String1 As Object, ByVal String2 As Object) As Object
  14.                        Try
  15.                                RightStr = Right(String1, Len(String1) - Len(String2) - InStr(String1, String2) + 1)
  16.                        Catch ex As Exception
  17.                                RightStr = False
  18.                        End Try
  19.                End Function
  20.        End Module       Public Class TlsApplication
  21.                <CommandMethod("TlsCadRun")> Public Shared Sub TlsCadRun()
  22.                        Dim pEntity As New TlsEntity
  23.                        Dim aSub As String
  24.                        Dim pACadApp As AcadApplication = Application.AcadApplication
  25.                        Dim pACadDoc As AcadDocument = pACadApp.ActiveDocument
  26.                        aSub = pACadDoc.Utility.GetString(0, "请输入函数:")
  27.                        pEntity.Init()
  28.                        pEntity.RunSub(aSub)
  29.                        pEntity.Insert()
  30.                End Sub       End Class       Public Class TlsData
  31.                Public Type As Short
  32.                Private p_sData As String
  33.                Private p_dData As Double
  34.                Private p_pData As Object
  35.                Public Property sData() As String
  36.                        Get
  37.                                sData = p_sData
  38.                        End Get
  39.                        Set(ByVal Value As String)
  40.                                Dim pnt As Object
  41.                                Dim i As Object
  42.                                Dim pStr As String
  43.                                p_sData = Value
  44.                                pStr = Left(Value, 1)
  45.                                Type = tString
  46.                                If pStr >= "0" And pStr <= "9" Then
  47.                                        If InStr(1, Value, ",") > 0 Then
  48.                                                pnt = Split(Value, ",")
  49.                                                For i = 0 To 2
  50.                                                        p_pData(i) = pnt(i)
  51.                                                Next i
  52.                                                Type = tPoint
  53.                                        Else
  54.                                                p_dData = Val(Value)
  55.                                                Type = tDouble
  56.                                        End If
  57.                                End If
  58.                        End Set
  59.                End Property
  60.                Public Property X() As Double
  61.                        Get
  62.                                X = p_pData(0)
  63.                        End Get
  64.                        Set(ByVal Value As Double)
  65.                                p_pData(0) = Value
  66.                        End Set
  67.                End Property
  68.                Public Property Y() As Double
  69.                        Get
  70.                                Y = p_pData(1)
  71.                        End Get
  72.                        Set(ByVal Value As Double)
  73.                                p_pData(1) = Value
  74.                        End Set
  75.                End Property
  76.                Public Property Z() As Double
  77.                        Get
  78.                                Z = p_pData(2)
  79.                        End Get
  80.                        Set(ByVal Value As Double)
  81.                                p_pData(2) = Value
  82.                        End Set
  83.                End Property
  84.                Public Property dData() As Double
  85.                        Get
  86.                                dData = p_dData
  87.                        End Get
  88.                        Set(ByVal Value As Double)
  89.                                p_dData = Value
  90.                        End Set
  91.                End Property
  92.                Public Property pData() As Object
  93.                        Get
  94.                                pData = p_pData
  95.                        End Get
  96.                        Set(ByVal Value As Object)
  97.                                p_pData = Value
  98.                        End Set
  99.                End Property
  100.                Public Sub New()
  101.                        Dim pnt(2) As Double
  102.                        p_pData = pnt
  103.                End Sub
  104.        End Class       Public Class TlsObject
  105.                Protected Name As String = "TlsObject"
  106.                Protected pACadApp As AcadApplication = Application.AcadApplication
  107.                Protected pACadDoc As AcadDocument = pACadApp.ActiveDocument
  108.                Protected pACadMSpace As Autodesk.AutoCAD.Interop.Common.AcadModelSpace = pACadApp.ActiveDocument.ModelSpace
  109.                Protected pObj As Autodesk.AutoCAD.Interop.Common.AcadObject
  110.                Protected Overridable Sub Save()
  111.                        Dim hDataType(1) As Short, hData(1) As Object
  112.                        hDataType(0) = 1001 : hData(0) = strAppName
  113.                        hDataType(1) = 1000 : hData(1) = Name
  114.                        pObj.SetXData(hDataType, hData)
  115.                End Sub
  116.                Public Overridable Sub Insert()
  117.                End Sub
  118.                Public Overridable Sub Change()
  119.                End Sub
  120.        End Class
 楼主| 发表于 2004-4-22 12:13:00 | 显示全部楼层
Public Class TlsEntity
Inherits TlsObject
Private pTlsVals As New Collection
'变量集合
Private Shared pSubs As New Collection
'函数集合
Private Shared pBlock As Autodesk.AutoCAD.Interop.Common.AcadBlock
Private pMirrorStart, pArrayStart As Short
Private dDataType(50) As Short, dData(50) As Object
Public Sub New()
Dim i As Object
Dim pData As TlsData
Name = "TlsEntity"
pData = New TlsData : pData.sData = "0,0,0" : pTlsVals.Add(pData, "PS")
'定义初始点
pData = New TlsData : pData.sData = "0" : pTlsVals.Add(pData, "Start")
'旋转或镜像开始
pData = New TlsData : pData.sData = "0" : pTlsVals.Add(pData, "End")
'旋转或镜像结束
pData = New TlsData : pData.sData = "01" : pTlsVals.Add(pData, "CSX")
pData = New TlsData : pData.sData = "02" : pTlsVals.Add(pData, "XSX")
pData = New TlsData : pData.sData = "03" : pTlsVals.Add(pData, "ZXX")
pData = New TlsData : pData.sData = "04" : pTlsVals.Add(pData, "XX")
'图层定义
dDataType(0) = 1001 : dData(0) = "EntityDefine"
dDataType(1) = 1000 : dData(1) = ""
For i = 2 To 30
dDataType(i) = 1040 : dData(i) = 0
Next i
For i = 31 To 50
dDataType(i) = 1070 : dData(i) = 0
Next i
'扩张数据初始化 End Sub
Public Sub Init()
'块初始化
OpenFile()
pBlock = pACadDoc.Blocks.Add(pnt, "*U")
End Sub
Public Property EntityName() As String
'实体名属性
Get
EntityName = dData(1)
End Get
dData(1) = Value
End Set
End Property
Private Property XData(ByVal Index As Short) As Double
'实体参数属性
Get
XData = dData(Index + 10)
End Get
dData(Index + 10) = Value
End Set
End Property
Protected Overrides Sub Save()
MyBase.Save()
pObj.SetXData(dDataType, dData)
End Sub
Public Overrides Sub Insert()
Dim pnt As Object
Try
pnt = pACadDoc.Utility.GetPoint(, "请输入插入点:")
pObj = pACadMSpace.InsertBlock(pnt, pBlock.Name, 1, 1, 1, 0)
pObj.Rotate(pnt, pACadDoc.Utility.GetAngle(pnt, "请输入旋转角度:"))
Save()
End Try
End Sub
Private Sub StrCal(ByVal String1 As Object)
'函数运算器
Dim i As Object
Dim pCals As Collection
Dim pStrack1 As New Collection
Dim pStrack2 As Collection
Try
pCals = CutStr(String1)
'分解一行语句
For i = 1 To pCals.Count
If pCals(i).sData <> ")" Then
'不是)时顺序入栈
pStrack1.Add(pCals(i))
Else
'遇")"时顺序出栈到"("
pStrack2 = New Collection
Do While pStrack1(pStrack1.Count).sData <> "("
pStrack2.Add(pStrack1(pStrack1.Count))
pStrack1.Remove(pStrack1.Count)
Loop
pStrack1.Add(GetVal(pStrack2))
'计算结果并入栈
End If
Next i
End Try
End Sub
Private Function CutStr(ByVal String1 As Object) As Collection
'分解一行语句
Dim i, j As Object
Dim pStrack As Object
Dim pCals As New Collection
Try
pStrack = Split(String1, " ")
'先按空格分解
If Not IsArray(pStrack) Then Exit Try
For Each i In pStrack
If InStr(1, i, "(") = 1 Then
'有"("时
pData = New TlsData
pData.sData = "("
pCals.Add(pData)
If RightStr(i, "(") <> "" Then
pData = New TlsData
pData.sData = RightStr(i, "(")
pCals.Add(pData)
End If
ElseIf InStr(1, i, ")") > 1 Then
'有")"时
pData = New TlsData
pData.sData = LeftStr(i, ")")
pCals.Add(pData)
For j = 1 To Len(RightStr(i, ")")) + 1
pData = New TlsData
pData.sData = ")"
pCals.Add(pData)
Next j
ElseIf Trim(i) <> "" Then
'去除空字符
pData = New TlsData
pData.sData = i
pCals.Add(pData)
End If
Next i
Finally
CutStr = pCals
End Try
End Function
 楼主| 发表于 2004-4-22 12:14:00 | 显示全部楼层
Private Function GetVal(ByVal Strack As Collection) As TlsData
'计算函数结果
Dim pData As New TlsData
Dim Count As Integer
Dim pMinCount As Integer
Dim i As Object
Try
Count = Strack.Count
For i = Count To 1 Step -1
pCals.Add(Strack(i))
Next i
pMinCount = 2 : If pCals(1).sData.ToUpper = "SUB" Or pCals(1).sData.ToUpper = "CALL" Then pMinCount = 3
If UCase(pCals(1).sData) = "VALUE" Or UCase(pCals(1).sData) = "SUB" Then
For i = pMinCount To Count
If InStr(pCals(i).sData, "#") > 0 Then
pTlsVals.Add(pData, LeftStr(pCals(i).sData, "#"))
Else
pTlsVals.Add(pData, pCals(i).sData)
End If
Next i
Exit Function
End If
If pCals(i).Type = tString Then
pCals(i).dData = pTlsVals(pCals(i).sData).dData
pCals(i).pData = pTlsVals(pCals(i).sData).pData
pCals(i).Type = pTlsVals(pCals(i).sData).Type
End If
Next i
Select Case pCals(1).sData.ToUpper
Case "="
If Count = 6 Then
pTlsVals(pCals(2).sData).X = pCals(3).X + pCals(4).dData
pTlsVals(pCals(2).sData).Y = pCals(3).Y + pCals(5).dData
pTlsVals(pCals(2).sData).Z = pCals(3).Z + pCals(6).dData
Else
pTlsVals(pCals(2).sData).dData = pCals(3).dData
pTlsVals(pCals(2).sData).pData = pCals(3).pData
End If
pData = pTlsVals(pCals(2).sData)
Case "+"
pData.sData = "0"
pData.dData = pCals(2).dData + pCals(3).dData
Case "-"
pData.sData = "0"
If Count = 3 Then
pData.dData = pCals(2).dData - pCals(3).dData
Else
pData.dData = -pCals(2).dData
End If
Case "*"
pData.sData = "0"
pData.dData = pCals(2).dData * pCals(3).dData
Case "/"
pData.sData = "0"
pData.dData = pCals(2).dData / pCals(3).dData
Case "^"
pData.sData = "0"
pData.dData = pCals(2).dData ^ pCals(3).dData
Case "CALL"
Dim pTlsEntity As New TlsEntity
Dim pValues As String
pValues = pCals(2).sData + "("
For i = 3 To pCals.Count - 1
pValues = pValues + Convert.ToString(pCals(i).dData) + ","
Next i
pValues = pValues + Convert.ToString(pCals(pCals.Count).dData) + ")"
pTlsEntity.RunSub(pValues)
Case "LINE"
 楼主| 发表于 2004-4-22 12:15:00 | 显示全部楼层
pBlock.AddLine(pCals(2).pData, pCals(3).pData).Layer = pTlsVals(pCals(4).sData).sData
Case "CIRCLE"
pBlock.AddCircle(pCals(2).pData, pCals(3).dData).Layer = pTlsVals(pCals(4).sData).sData
Case "ELLIPSE"
Dim obj As Autodesk.AutoCAD.Interop.Common.AcadEllipse
obj = pBlock.AddEllipse(pCals(2).pData, pCals(3).pData, pCals(4).dData)
obj.StartAngle = pCals(5).dData / 45 * System.Math.Atan(1)
obj.EndAngle = pCals(6).dData / 45 * System.Math.Atan(1)
obj.Layer = pTlsVals(pCals(7).sData).sData
Case "ARC"
pBlock.AddArc(pCals(2).pData, pCals(3).dData, pCals(4).dData / 45 * System.Math.Atan(1), pCals(5).dData / 45 * System.Math.Atan(1)).Layer = pTlsVals(pCals(6).sData).sData
Case "MIRROR"
If pCals(2).sData = "Start" Then
pMirrorStart = pBlock.Count
Else
For i = pMirrorStart To pBlock.Count - 1
pBlock.Item(i).Mirror(pCals(2).pData, pCals(3).pData)
Next i
End If
Case "ARRAY"
pArrayStart = pBlock.Count
Else
If Count = 4 Then
For i = pArrayStart To pBlock.Count - 1
pBlock.Item(i).ArrayPolar(pCals(3).dData, pCals(4).dData, pCals(2).pData)
Next i
Else
pBlock.Item(i).ArrayRectangular(pCals(2).dData, pCals(3).dData, 1, pCals(4).dData, pCals(5).dData, 0)
Next i
End If
End If
Case "HATCH"
End Select
Finally
GetVal = pData
End Try
End Function
Private Sub OpenFile()
'读取函数文件
Dim i As Object
Dim ts As StreamReader
Dim Data As String
Dim allSub As Object
Dim aSub As Collection
Dim FileName As String
For i = 1 To pSubs.Count
pSubs.Remove(1)
Next i
Try
ts = File.OpenText(Directory.GetCurrentDirectory & "\TlsCad.Sub")
allSub = Split(ts.ReadToEnd, vbCrLf)
For i = 0 To UBound(allSub)
Data = allSub(i)
If InStr(Data, "(Sub") = 1 Then
'向函数集合加入新函数
aSub = New Collection
pSubs.Add(aSub, CutStr(Data)(3).sData)
pSubs(pSubs.Count).Add(Data)
Else
End If
Next i
Finally
ts.Close()
End Try
End Sub
Public Sub RunSub(ByVal String1 As String)
Dim i As Object
Dim pValues As Object
Try
EntityName = Trim(LeftStr(String1, "(")).ToUpper
aSub = pSubs(EntityName)
StrCal(aSub(1))
'分配函数变量
pValues = Split(LeftStr(RightStr(String1, "("), ")"), ",")
If IsArray(pValues) Then
'初始化函数变量
For i = 0 To UBound(pValues)
pTlsVals(i + 8).dData = pValues(i)
XData(i) = pValues(i)
Next i
End If
For i = 2 To aSub.Count
'依次运行语句
StrCal(aSub(i))
Next i
End Try
End Sub End Class
 楼主| 发表于 2004-4-22 12:21:00 | 显示全部楼层
这是我编的通用参数驱动程序,用的还是ActiveX方法 将下面的文本存为TlsCad.sub文件和编译后的Dll文件放在同一目录下就可以使用了 (Sub TYFT_EHA Dn H h1 d)
(Value a1 a2 a3 a4 a5 a6 p1# p2#)
(= a3 (- (= a2 (/ (= a1 (+ Dn (* d 2))) 2))))
(= a4 (/ (* (- H h1 ) 2) Dn))
(= a5 (/ (* (+ (- H h1) d) 2) a1))
(= a6 (/ Dn 2))
(= p2 (= p1 ps a3 0 0) 0 h1 0)
(Line p1 p2 CSX)
(= p2 (= p1 p1 d 0 0) 0 h1 0)
(Line p1 p2 CSX)
(= p2 (= p1 p1 Dn 0 0) 0 h1 0)
(Line p1 p2 CSX)
(Line p1 p2 CSX)
(= p2 (= p1 ps a3 0 0) a1 0 0)
(Line p1 p2 CSX)
(= p1 ps 0 h1 0)
(= p2 ps a6 0 0)
(Ellipse p1 p2 a4 0 180 CSX)
(= p2 ps a2 0 0)
(Ellipse p1 p2 a5 0 180 CSX)
(End Sub)
(Sub TYFT_EHB Dn H h1 d)
(= Dn (- Dn (* 2 d)))
(= H (- H d))
(= a6 (/ Dn 2))
(Line p1 p2 CSX)
(Line p1 p2 CSX)
(Line p1 p2 CSX)
(Line p1 p2 CSX)
(Line p1 p2 CSX)
(= p1 ps 0 h1 0)
(= p2 ps a6 0 0)
(= p2 ps a2 0 0)
(End Sub) 命令格式: TlsCadRun tyft_eha(300,100,25,4)
发表于 2004-4-22 12:50:00 | 显示全部楼层
好贴!
发表于 2004-4-22 14:46:00 | 显示全部楼层
不明白怎么用?
 楼主| 发表于 2004-4-22 15:21:00 | 显示全部楼层
把代码全部复制到TlsCad.vb文件内,加入下列代码 Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports System.IO
编译为Dll文件,用NetLoad加载一下
发表于 2004-4-22 16:49:00 | 显示全部楼层
我水平低,还不能看懂,有一个问题先问lzh741206一下:
  1. Public Const strAppName As String = "TlsCad"
复制代码
在VB。NET中是不是可在声明的同时赋值?!
GMT+8, 2025-11-26 14:18 , Processed in 0.276831 second(s), 24 queries , Gzip On.
