- 积分
- 10518
- 明经币
- 个
- 注册时间
- 2002-6-3
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2004-4-27 09:42:00
显示全部楼层
加载可以在acad.dvb中,或者在acaddoc.lsp编写代码来实现。定时执行,可以使用定时器,也可以通过循环来操作。如: - Sub Test()
- If Hour(Now) > 10 Then Exit Sub
- Do While Hour(Now) < 10
- DoEvents '空执行
- Loop
- Ping "192.168.0.1"
- End Sub
检测网络中的某一台电脑,实际上是Ping的操作,如果Ping的通,说明是连通的。 - Const SOCKET_ERROR = 0
- Private Type WSAdata
- wVersion As Integer
- wHighVersion As Integer
- szDescription(0 To 255) As Byte
- szSystemStatus(0 To 128) As Byte
- iMaxSockets As Integer
- iMaxUdpDg As Integer
- lpVendorInfo As Long
- End Type
- Private Type Hostent
- h_name As Long
- h_aliases As Long
- h_addrtype As Integer
- h_length As Integer
- h_addr_list As Long
- End Type
- Private Type IP_OPTION_INFORMATION
- TTL As Byte
- Tos As Byte
- Flags As Byte
- OptionsSize As Long
- OptionsData As String * 128
- End Type
- Private Type IP_ECHO_REPLY
- Address(0 To 3) As Byte
- Status As Long
- RoundTripTime As Long
- DataSize As Integer
- Reserved As Integer
- data As Long
- Options As IP_OPTION_INFORMATION
- End Type
- Private Declare Function GetHostByName Lib "wsock32.dll" Alias "gethostbyname" (ByVal HostName As String) As Long
- Private Declare Function WSAStartup Lib "wsock32.dll" (ByVal wVersionRequired&, lpWSAdata As WSAdata) As Long
- Private Declare Function WSACleanup Lib "wsock32.dll" () As Long
- Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (hpvDest As Any, hpvSource As Any, ByVal cbCopy As Long)
- Private Declare Function IcmpCreateFile Lib "icmp.dll" () As Long
- Private Declare Function IcmpCloseHandle Lib "icmp.dll" (ByVal HANDLE As Long) As Boolean
- Private Declare Function IcmpSendEcho Lib "ICMP" (ByVal IcmpHandle As Long, ByVal DestAddress As Long, ByVal RequestData As String, ByVal RequestSize As Integer, RequestOptns As IP_OPTION_INFORMATION, ReplyBuffer As IP_ECHO_REPLY, ByVal ReplySize As Long, ByVal TimeOut As Long) As Boolean
- Private Sub Form_Load()
- 'KPD-Team 2000
- 'URL: http://www.allapi.net/
- 'E-Mail: KPDTeam@Allapi.net
- Const HostName = "www.allapi.net"
- Dim hFile As Long, lpWSAdata As WSAdata
- Dim hHostent As Hostent, AddrList As Long
- Dim Address As Long, rIP As String
- Dim OptInfo As IP_OPTION_INFORMATION
- Dim EchoReply As IP_ECHO_REPLY
- Call WSAStartup(&H101, lpWSAdata)
- If GetHostByName(HostName + String(64 - Len(HostName), 0)) <> SOCKET_ERROR Then
- CopyMemory hHostent.h_name, ByVal GetHostByName(HostName + String(64 - Len(HostName), 0)), Len(hHostent)
- CopyMemory AddrList, ByVal hHostent.h_addr_list, 4
- CopyMemory Address, ByVal AddrList, 4
- End If
- hFile = IcmpCreateFile()
- If hFile = 0 Then
- MsgBox "Unable to Create File Handle"
- Exit Sub
- End If
- OptInfo.TTL = 255
- If IcmpSendEcho(hFile, Address, String(32, "A"), 32, OptInfo, EchoReply, Len(EchoReply) + 8, 2000) Then
- rIP = CStr(EchoReply.Address(0)) + "." + CStr(EchoReply.Address(1)) + "." + CStr(EchoReply.Address(2)) + "." + CStr(EchoReply.Address(3))
- Else
- MsgBox "Timeout"
- End If
- If EchoReply.Status = 0 Then
- MsgBox "Reply from " + HostName + " (" + rIP + ") recieved after " + Trim$(CStr(EchoReply.RoundTripTime)) + "ms"
- Else
- MsgBox "Failure ..."
- End If
- Call IcmpCloseHandle(hFile)
- Call WSACleanup
- End Sub
这是一个Ping操作的例子,可以参考一下。 |
