查看: 1351|回复: 1
[求助]请帮助看看错在哪里?
发表于 2004-4-27 16:44:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click() Dim AcadApp As AcadApplication
Dim StyObj1 As AcadTextStyle
Dim Bold As Boolean
Dim Italic As Boolean
Dim charSet As Long
Dim typeFace As String
Dim PitchAndFamily As Long
Set StyObj1 = AcadApp.ActiveDocument.TextStyles.Add("A1")
typeFace = "宋体"
Bold = True
Italic = True
charSet = 1
PitchAndFamily = 1 Or 16
StyObj1.SetFont typeFace, Bold, Italic, charSet, PitchAndFamily Dim StyObj2 As AcadTextStyle
Set StyObj2 = AcadApp.ActiveDocument.TextStyles.Add("A4")
StyObj2.fontFile = "C:\WINDOWS\Fonts\STCaiyun.tif"
Dim textObj As AcadText
Dim textString As String
Dim insertionPoint(0 To 2) As Double
Dim height As Double textString = "AutoCAD二次开发"
height = 20
insertionPoint(0) = 5: insertionPoint(1) = 2: insertionPoint(2) = 0 AcadApp.ActiveDocument.ActiveTextStyle = StyObj1
Set textObj = AcadApp.ActiveDocument.ModelSpace.AddText(textString, insertionPoint, height)
textObj.Update 错误出现在Set StyObj1 = AcadApp.ActiveDocument.TextStyles.Add("A1")
一行,提示为:变量或with块变量未设置,不知道为什么?? 顺便问一下:vb/vba的代码窗口不支持鼠标滚轮么? 谢谢指教.
发表于 2004-4-27 18:04:00 | 显示全部楼层
Dim AcadApp As AcadApplication Set StyObj1 = AcadApp.ActiveDocument.TextStyles.Add("A1")
AcadApp 未实例化,应用GetObject或CreateObject对AcadApp赋值 好像有一个VB鼠标滚轮伴侣的软件,你找找看
GMT+8, 2025-5-25 22:34 , Processed in 0.147197 second(s), 23 queries , Gzip On.
