查看: 1877|回复: 3
检查了好多遍都没有问题,可运行就是不行!
发表于 2004-4-27 20:10:00 | 显示全部楼层 |阅读模式
程序的目的是将3D多段线的所有节点的Z坐标去掉,然后生成一2D多段线。思路应该没有问题,可老提示坐标越界。哪位帮我看看到底是怎么回事。   用下面这个图形做测试。
  1. Sub test3Dto2D()
  2. '创建选择集
  3. Dim selset As AcadSelectionSet
  4. Dim cor3 As Variant
  5. Dim n As Integer
  6. Dim a As Integer
  7. a = 0
  8. Set selset = ThisDrawing.SelectionSets.Add("sset")
  9. selset.Select acSelectionSetAll         '遍历选择集并将每一个对象镜相
  10. Dim entry As AcadObject
  11. Dim pl As AcadLWPolylineFor Each entry In selset
  12.      If entry.EntityName = "AcDb3dPolyline" Then
  13.                cor3 = entry.Coordinates
  14.                n = (UBound(cor3) + 1) * 2 / 3
  15.                Dim pt() As Double
  16.                ReDim pt(0 To n - 1) As Double                       For i = 0 To (n - 2) Step 2
  17.                                pt(i) = cor3(a)
  18.                                pt(i + 1) = cor3(a + 1)
  19.                                a = a + 3
  20.                        Next i
  21.
  22.                Set pl = ThisDrawing.ModelSpace.AddLightWeightPolyline(pt)
  23.                entry.Delete
  24.        End If
  25. Next entryselset.Delete '避免下次重复End Sub
发表于 2004-4-27 20:33:00 | 显示全部楼层
在 entry.Delete后面加上 a=0
 楼主| 发表于 2004-4-27 20:36:00 | 显示全部楼层
嘿嘿!多谢,我太粗心了!
发表于 2004-4-27 20:42:00 | 显示全部楼层
  1. Sub tn = (UBound(cor3) + 1) * 2 / 3
  2.                Dim pt() As Double
  3.                ReDim pt(0 To n - 1) As Double
  4.                        For i = 0 To (n - 2) Step 2
这里太乱了,改为sub test3Dto2D()
'创建选择集
Dim cor3 As Variant
Dim n As Integer
               n = (UBound(cor3) + 1) / 3
               Dim pt() As Double
               ReDim pt(0 To n * 2 - 1) As Double                       For i = 0 To n - 1
                               pt(i * 2) = cor3(i * 3)
                               pt(i * 2 + 1) = cor3(i * 3 + 1)
                       Next i
               entry.Delete
       End If
GMT+8, 2025-6-15 04:06 , Processed in 0.620932 second(s), 23 queries , Gzip On.
