查看: 2279|回复: 1
[VBA]三维实体干涉检查
发表于 2004-4-29 11:40:00 | 显示全部楼层 |阅读模式
三维实体干涉检查:试着编了下断代码,为何检测不出?那句有错? Private Sub CommandButton1_Click()
On Error Resume Next
Me.Hide
Dim returnobj(2) As AcadEntity
Dim objnumber As Integer
Dim basepnt As Variant
objnumber = objnumber + 1
ThisDrawing.Utility.GetEntity returnobj(objnumber), basepnt, "选择实体" returnobj(objnumber).Highlight (True)
Me.Show
If Err.Number <> 0 Then
Err.Clear
objnumber = objnumber - 1
MsgBox ("未选中实体,重选")
Exit Sub
End If Dim interferenceobj As Acad3DSolid
If objnumber = 2 Then
Set interferenceobj = returnobj(1).CheckInterference(returnobj(2), True)
interferenceobj.Delete
If Err.Number = 0 Then
MsgBox ("两三维实体干涉")
interference = True
objnumber = 0
Else
MsgBox ("两三维实体不干涉")
interference = False
objnumber = 0
Err.Clear
End If
End If
End Sub
发表于 2004-4-29 12:06:00 | 显示全部楼层
差For循环,只能选择一次,你怎么判断
GMT+8, 2025-6-15 04:27 , Processed in 0.139912 second(s), 23 queries , Gzip On.
