查看: 2078|回复: 4
怎么简化代码
发表于 2004-4-29 21:21:00 | 显示全部楼层 |阅读模式
这是我写的一个画一些水平方向平行的线,我觉得太罗嗦了,怎么样可以简化一些吗? ;------------这个文件主要是画一些部件的主视图------------------ ;画一段机架返回该机架的起点和终点到左边的距离
(defun C:DrawQ/TY25D1XX-jj (PBase1 PBase2 LDAll P0 W ViewSel TypeChain
/ p1 p2 HalfWidth
List-Cen-Date List-DN-Date list-0-Date Num)
Base1 本段机架主视图的基点.
Base2 本段机架俯视图的基点.
;LDAll 本段机架的长度.
0 图纸的基点.
;HalfWidth 机架内面的半宽.
;ViewSel 视图选择 = 1 只画主视图 = 2 只画俯视图 = 3 都画.
;TypeChain 链条位置类型,(内外链类型). (setq LDAll (float LDAll)
W (float W)
) (if (or (= ViewSel 1) (= ViewSel 3))
;-------------画主视图机架-------------
;画3条中心线.
(command "layer" "s" "cen" "")
(setq p1 (mapcar '+ PBase1 (list 0 14.5)))
(setq p2 (mapcar '+ PBase1 (list LDAll 14.5)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 127.5)))
(setq p2 (mapcar '+ PBase1 (list LDAll 127.5)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 159.82)))
(setq p2 (mapcar '+ PBase1 (list LDAll 159.82)))
;画DA层的线3条
(command "layer" "s" "DA" "")
(setq p1 (mapcar '+ PBase1 (list 0 3)))
(setq p2 (mapcar '+ PBase1 (list LDAll 3)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 136)))
(setq p2 (mapcar '+ PBase1 (list LDAll 136)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 139)))
(setq p2 (mapcar '+ PBase1 (list LDAll 139)))
;画0层的线11条
(command "layer" "s" "0" "")
(setq p1 (mapcar '+ PBase1 (list 0 0)))
(setq p2 (mapcar '+ PBase1 (list LDAll 0)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 10)))
(setq p2 (mapcar '+ PBase1 (list LDAll 10)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 19)))
(setq p2 (mapcar '+ PBase1 (list LDAll 19)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 29.09)))
(setq p2 (mapcar '+ PBase1 (list LDAll 29.09)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 35.1)))
(setq p2 (mapcar '+ PBase1 (list LDAll 35.1)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 104.4)))
(setq p2 (mapcar '+ PBase1 (list LDAll 104.4)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 112.91)))
(setq p2 (mapcar '+ PBase1 (list LDAll 112.91)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 123)))
(setq p2 (mapcar '+ PBase1 (list LDAll 123)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 132)))
(setq p2 (mapcar '+ PBase1 (list LDAll 132)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 142)))
(setq p2 (mapcar '+ PBase1 (list LDAll 142)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 147)))
(setq p2 (mapcar '+ PBase1 (list LDAll 147)))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase1 (list 0 154)))
(setq p2 (mapcar '+ PBase1 (list LDAll 154)))
) ;----------------------画俯视图的机架-----------------
(if (= TypeChain "外")
(setq List-Cen-Date '(57.5)
List-DN-Date '(3 81 84)
list-0-Date '(0 37 52 63 78 99.5)
(setq List-Cen-Date '(26.5)
list-0-Date '(0 6 21 32 47 99.5)
(setq Num (length List-Cen-Date)
n 0
(repeat Num
(setq Y-Value (+ HalfWidth (Nth n List-Cen-Date)))
(setq p1 (mapcar '+ PBase2 (list 0 Y-Value)))
(setq p2 (mapcar '+ PBase2 (list LDAll Y-Value)))
(setq n (+ n 1))
(if (or (= ViewSel 2) (= ViewSel 3))
;1 画后面的机架.
(setq HalfWidth (/ (- W 199) 2)) (if (= TypeChain "外" )
(Progn
;画1条中心线.
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 57.5)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 57.5)))))
(command "line" P1 P2 "") (setq bbb (cdr p1))
;画3条虚线.
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 3)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 3)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 81)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 81)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 84)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 84)))))
;画6条实线.
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 0)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 0)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 37)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 37)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 52)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 52)))))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 63)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 63)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 78)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 78)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 99.5)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 99.5)))))
;2 画前面的机架.
;画1条中心线.
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 57.5)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 57.5)))))
;画3条虚线.
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 3)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 3)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 81)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 81)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 84)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 84)))))
;画6条实线.
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 0)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 0)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 37)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 37)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 52)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 52)))))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 63)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 63)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 78)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 78)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 99.5)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 99.5)))))
(Progn
;画1条中心线.
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 26.5)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 26.5)))))
;画3条虚线.
;画6条实线.
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 6)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 6)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 21)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 21)))))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 32)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 32)))))
(setq p1 (mapcar '+ PBase2 (list 0 (+ 0 (+ HalfWidth 47)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (+ 0 (+ HalfWidth 47)))))
;2 画前面的机架.
;画1条中心线.
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 26.5)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 26.5)))))
;画3条虚线.
;画6条实线.
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 6)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 6)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 21)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 21)))))
(command "line" P1 P2 "") (setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 32)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 32)))))
(setq p1 (mapcar '+ PBase2 (list 0 (- 0 (+ HalfWidth 47)))))
(setq p2 (mapcar '+ PBase2 (list LDAll (- 0 (+ HalfWidth 47)))))
;返回的值.
(list
(cons "Start" (- (car p1) (car p0)))
(cons "End" (- (car p2) (car p0)) )
发表于 2004-4-30 20:21:00 | 显示全部楼层
其实能管用就行~~一味追求精简代码没有必要。
看到你用了很多Command函数,也许用Apply函数可能会精简一点。先创建一个列表,随便举个例子,比如 (setq        plist (list pt1 pt2 pt3 pt4...))....
创建表的时候当然可以用循环什么的。。。。看程序啦
最后用一句
(apply 'command (cons "pline" plist))
(command "")
这样也许会简单一点~~仅供参考。
发表于 2004-5-1 04:40:00 | 显示全部楼层
2楼的真是个好方法
发表于 2004-5-1 17:45:00 | 显示全部楼层
数据是否能做表
这样程序写起来可能会简单些
 楼主| 发表于 2004-5-1 17:53:00 | 显示全部楼层
4楼的方法很启发,我现在就是把数据(线的图层和起点的Y坐标放到一个偏移)放到表里,得到了很多简化,只用了2条command line 命令。谢谢。
GMT+8, 2025-5-14 02:26 , Processed in 0.200889 second(s), 25 queries , Gzip On.
