- 积分
- 24608
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2004-5-2 18:39:00
显示全部楼层
这是改进版 - Private Function MToS(MText As Variant) As Variant
- '炸开MText并返回一个Text数组
- Dim i As Integer
- Dim ss As AcadSelectionSet
- Dim pTexts() As AcadObject
- ThisDrawing.ActiveSelectionSet.Clear
- ThisDrawing.SendCommand "Explode" & vbCr & "(handent " & Chr(34) _
- & MText.Handle & Chr(34) & ")" & vbCr & vbCr Set ss = ThisDrawing.ActiveSelectionSet
- ReDim pTexts(ss.Count - 1) As AcadObject
- For i = 0 To ss.Count - 1
- Set pTexts(i) = ss(i)
- Next i
- MToS = pTexts
- End Function
- Public Function Sort(Texts As Variant, TextHeight As Double) As Collection
- '将选择集、Text数组或Text集合按X轴和Y轴进行排序,返回一个集合的集合
- Dim Total As New Collection
- Dim pPnts As Collection
- Dim Judge As Boolean
- Dim i As AcadObject, j As Collection, k As Integer, l As Integer
- Dim p1, p2, p3, p4
- For Each i In Texts
- Judge = False
- For Each j In Total
- p1 = j(1).InsertionPoint: p2 = i.InsertionPoint
- If Abs(p1(1) - p2(1)) < TextHeight Then
- For k = 1 To j.Count
- p3 = j(k).InsertionPoint
- If p3(0) >= p2(0) Then
- j.Add i, , k
- Judge = True
- Exit For
- End If
- Next k
- If Not Judge Then j.Add i: Judge = True
- Exit For
- End If
- Next j
- If Not Judge Then
- Set pPnts = New Collection
- pPnts.Add i
- For l = 1 To Total.Count
- p4 = Total(l)(1).InsertionPoint
- If p4(1) < p2(1) Then
- Total.Add pPnts, , l
- Judge = True
- Exit For
- End If
- Next l
- If Not Judge Then Total.Add pPnts
- End If
- Next i
- Set Sort = Total
- End Function
- Public Sub UnExplodeMText()
- '将选择的多个Text或MText按X轴和Y轴连接为一个MText,即炸开MText的逆过程
- On Error Resume Next
- Dim pFilterType(0) As Integer, pFilter(0) As Variant
- Dim Ents(0) As AcadObject, l As AcadObject
- Dim pHeight As Double
- Dim pText As String
- Dim pObjs As New Collection
- Dim i, j, k As Integer
- Set ss = ThisDrawing.SelectionSets.Add("*UnExplodeMText*")
- If Err Then
- Set ss = ThisDrawing.SelectionSets("*UnExplodeMText*")
- Err.Clear
- End If
- ss.Clear
- pFilterType(0) = 0: pFilter(0) = "Text,MText"
- ss.SelectOnScreen pFilterType, pFilter
- For Each l In ss
- pObjs.Add l
- Next l
- ss.Delete
- Debug.Print pObjs.Count
- i = 1
- Do While i <= pObjs.Count
- If UCase(pObjs(i).ObjectName) = "ACDBMTEXT" Then
- For Each j In MToS(pObjs(i))
- pObjs.Add j, , , i
- Next j
- pObjs.Remove i
- End If
- i = i + 1
- Loop
- pHeight = pObjs(1).Height
- For Each i In Sort(pObjs, pHeight)
- For Each j In i
- pText = pText & j.TextString
- Next j
- pText = pText & "\P"
- Next i
- For k = 1 To pObjs.Count
- pObjs(k).Delete
- Next k
- ThisDrawing.ModelSpace.AddMText(ThisDrawing.Utility.GetPoint(, "请输入插入点:"), 0, pText).Height = pHeight
- ErrClear:
- End Sub
