查看: 2231|回复: 2
[LISP]在图纸上自动标注相对于基点的其他点的坐标值
发表于 2004-5-3 09:36:00 | 显示全部楼层 |阅读模式
如果已经知道建筑总平面图上的一个基点的坐标,如何快速给总平面上的各个单体定位呢?需要在图纸上自动标注相对于基点的其他点的坐标值。
发表于 2004-5-3 09:38:00 | 显示全部楼层
用下面的這個涵數吧.
Returns the UCS 3D point at a specified angle and distance from a point
(polar pt ang dist)
Arguments
pt
A 2D or 3D point.
ang
An angle expressed in radians relative to the world X axis. Angles increase in the counterclockwise direction, independent of the current construction plane.
dist
Distance from the specified pt.
Return Values
A 2D or 3D point, depending on the type of point specified by pt.
Examples
Supplying a 3D point to polar:
Command: (polar '(1 1 3.5) 0.785398 1.414214)
(2.0 2.0 3.5)
Supplying a 2D point to polar:
Command: (polar '(1 1) 0.785398 1.414214)
(2.0 2.0)
 楼主| 发表于 2004-5-3 09:43:00 | 显示全部楼层
谢谢斑竹!
GMT+8, 2025-5-14 03:32 , Processed in 0.168482 second(s), 25 queries , Gzip On.
