查看: 1285|回复: 3
求助
发表于 2004-5-3 21:13:00 | 显示全部楼层 |阅读模式
Dim inspoint(0 To 2) As Double
inspoint(0) = 0
inspoint(1) = 0
inspoint(2) = 0
ThisDrawing.ModelSpace.InsertBlock inspoint, "c:\program files\acad2000\tch14\sys\abcd.dwg", 1, 1, 1, 0 我想修改块abcd.dwg的属性,请问如何做?先谢谢了
发表于 2004-5-4 08:59:00 | 显示全部楼层
Signature
RetVal = object.GetAttributes()
Object
MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_blockref_object.htm" target="_blank" >BlockRef, MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_externalreference_object.htm" target="_blank" >ExternalReference, MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_minsertblock_object.htm" target="_blank" >MInsertBlock
The object or objects this method applies to.
RetVal
Variant (array of AttributeReference objects)
The array of MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_attributeref_object.htm" target="_blank" >AttributeReference objects.
Remarks
This method returns an array of editable attribute references attached to the block reference.
You can only return the constant attributes for an external reference. To find the constant attributes of an external reference or block reference, use the MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_getconstantattributes.htm" target="_blank" >GetConstantAttributes method. [WEB]http://www.mjtd.com/object/acad2004/idh_getattributes.htm[/WEB]
 楼主| 发表于 2004-5-4 11:53:00 | 显示全部楼层
我还不懂,能不能给个例子
发表于 2004-5-4 20:53:00 | 显示全部楼层
上面的是帮助里的解释,下面的是帮助里的例子:
<RE class=Code>Sub Example_GetAttributes()
    ' This example creates a block. It then adds attributes to that
    ' block. The block is then inserted into the drawing to create
    ' a block reference.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "TESTBLOCK")
    ' Define the attribute definition
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim insertionPoint(0 To 2) As Double
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeVerify
    prompt = "Attribute Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "Attribute Tag"
    value = "Attribute Value"
    ' Create the attribute definition object in model space
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TESTBLOCK", 1#, 1#, 1#, 0)
    ZoomAll
    ' Get the attributes for the block reference
    Dim varAttributes As Variant
    varAttributes = blockRefObj.GetAttributes
    ' Move the attribute tags and values into a string to be displayed in a Msgbox
    Dim strAttributes As String
    Dim I As Integer
    For I = LBound(varAttributes) To UBound(varAttributes)
        strAttributes = strAttributes &amp; "  Tag: " &amp; varAttributes(I).TagString &amp; _
                        "   Value: " &amp; varAttributes(I).textString &amp; "    "
    Next
    MsgBox "The attributes for blockReference " &amp; blockRefObj.name &amp; " are: " &amp; strAttributes, , "GetAttributes Example"
    ' Change the value of the attribute
    ' Note: There is no SetAttributes. Once you have the variant array, you have the objects.
    ' Changing them changes the objects in the drawing.
    varAttributes(0).textString = "NEW VALUE!"
    Dim newvarAttributes As Variant
    newvarAttributes = blockRefObj.GetAttributes
    ' Again, display the tags and values
    strAttributes = ""
    Next
End Sub</PRE>
GMT+8, 2025-5-1 05:35 , Processed in 0.147475 second(s), 23 queries , Gzip On.
