查看: 1777|回复: 7
[求助]
发表于 2004-5-4 07:02:00 | 显示全部楼层 |阅读模式
How to find out a specific dwg file is open in the network? And who has it open?
发表于 2004-5-4 13:03:00 | 显示全部楼层
什么意思 E 看不懂
是不是说如何打开网络上的图档
发表于 2004-5-4 14:34:00 | 显示全部楼层
我也很想知道,有时打开图纸时发现这张图纸已被打开,是只读,但不知道是谁打开的。但我发现我们公司的网络有时可以看到是谁打开的,可以看到打开这张图纸的用户的用户名。但有的图纸却不行,不只是为什么?
 楼主| 发表于 2004-5-4 19:33:00 | 显示全部楼层
已经有点头绪了,DosLIB里的(dos_openp)可以知道一个图形文件是否正被打开。
Express Tools里有一个whohas.arx可以查出网络上谁打开一个指定图形文件。剩下的问题是如何将whohas结合到lisp里,使其返回打开该文件的机器用户名,让程序继续运行?各位有什么高招?急用!!!
发表于 2004-5-6 07:52:00 | 显示全部楼层
做个木马?
发表于 2004-5-10 09:04:00 | 显示全部楼层
alin大侠不知想到什么办法了?dos_openp只能返回T和Nil,也不能知道是谁打开的。不知怎么办?
 楼主| 发表于 2004-5-10 14:17:00 | 显示全部楼层
I don’t know yet. The “whohas.arx” doesn’t work quite well anyway. And you have to make sure all the machines in the network have loaded the “whohas.arx”. And, I don’t know how to incorporate this command into LISP.
发表于 2004-5-10 15:04:00 | 显示全部楼层
I found        after the computer loaded "whohas.arx" program, you open the *.dwg files which had already opened, you can see the user name and computer name in the dialog. ( I attached.)         But it seems difficult to use in Lisp.
GMT+8, 2025-5-14 02:06 , Processed in 0.179704 second(s), 26 queries , Gzip On.
